How can I calculate the cumulative mass of a disk using disk mass density?
In summary: It looks like you're on the right track. The biggest mistake I see is that your equation starts off with ##\rho(r)## when it should be m(r), the cumulative mass. Again, I haven't worked through the problem, and am assuming that @pasmith's hint is correct.If so, all you need to do to finish is 1) evaluate ##\int h e^{-r/h}dr##, and then 2) evaluate the resulting large expression at r = 0 and r = R, subtracting the first expression (with r = 0) from the latter expression.
independentphysics
Find cumulative mass of a disk
Exponential mass function
I want to find the cumulative mass m(r) of a mass disk. I have the mass density in terms of r, it is an exponential function:
ρ(r)=ρ0*e^(-r/h)
A double integral in polar coordinates should do, but im not sure about the solution I get.
independentphysics said:
Homework Statement: Find cumulative mass of a disk
Relevant Equations: Exponential mass function
ρ(r)=ρ0*e^(-r/h)
What solution do you get?
Also, what is the significance of h in your equation?
You can write an iterated integral in LaTeX like this: ##\int_{\theta = 0}^b \int_{r = 0}^a f(r, \theta)~dr~d\theta##
I am getting: ρ(r)=2*π*ρ0 * h^2 * [1 - e^(-r/h)]
h is a constant
Is your intermediate result [itex]2\pi \rho_0 \int_0^R re^{-r/h}\,dr[/itex]?
Yes, it is.
Yes, it is.
Assuming @pasmith's work is correct (I haven't worked the problem), the integral shown can be evaluated using integration by parts.
Yes, I am aware of it, but Im not sure about my final result.
Well, why don't you show us what you got, together with your work?
From [itex]2\pi \rho_0 \int_0^R re^{-r/h}\,dr[/itex]
I evaluate this integral using integration by substitution. Let u = r/h, then du/dr = 1/h and dr = h*du. Substituting, we get:
m(r) = 2π * ρ0 * h^2 * ∫ u * e^(-u) * du
Is this correct?
Is this correct?
It's technically correct, but it doesn't get you any closer to evaluating the integral. To integrate ##\int re^{-r/h}dr## you need to use integration by parts, something I mentioned before.
A substitution won't be useful here.
How do I integrate by parts the function?
Your calculus textbook should have a section on integration by parts, along with several examples.
If I choose u=r and v=e^(-r/h) so that du=1, will this do?
No.
If ##u=r## (that's fine), then ##du=dr##.
For ##v##, you need ##\displaystyle dv=e^{-r/h}\,dr##.
Integrate to get ##v##.
SammyS said:
No.
ρ(r)= ρ0*e^(-r/h)
2π results from integration of angle in polar coordinates
integrate (r*e^(-r/h) dr)
u=r
du=dr
dv=e^(-r/h)*dr
v=-h*exp(-r/h)
ρ(r)=2π * ρ0 * ( r*h*(-e^(-r/h) + int(h*e^(-r/h)dr )
Is it correct?
ρ(r)= ρ0*e^(-r/h)
u=r
du=dr
dv=e^(-r/h)*dr
v=-h*exp(-r/h)
Is it correct?
The integral I mentioned is relatively straightforward -- a simple substitution will work.
Equation:
ρ(r)=ρ0*e^(-r/h)
In polar coordinates, a 2π factor multiplies the integratal (r*e^(-r/h) dr)
u=r
du=dr
dv=e^(-r/h)*dr
v=-h*exp(-r/h)
M (r)=2π * ρ0 * h * (h + r) * (-e^(-r/h)) + c
I find c by M(0)=c
Equation:
ρ(r)=ρ0*e^(-r/h)
u=r
du=dr
dv=e^(-r/h)*dr
v=-h*exp(-r/h)
I find c by M(0)=c
Your final answer for M should involve h and R, but should not involve r.
You need to evaluate M(R) and M(0), and your final answer for M will be M(R) - M(0).
For M(0) I get ##2\pi \rho_0 h^2##.
The final answer for cumulative mass M(r) and depends on r.
R is end of the disk, which doesn't even need to exist (I've never mentioned if the disk in infinite).
M(0) is M(r=0).
The final answer for cumulative mass M(r) involves +constant an the end of the discussed integral, which is M(0).
The mass of the disc [itex]0 \leq r < R[/itex] is [tex]M(R) = 2\pi\rho_0 \int_0^R re^{-r/h}\,dr.[/tex] It follows immediately that [itex]M(0) = 0[/itex]. Since [tex]
\frac{d}{dr} re^{-r/h} = (1 - rh^{-1})e^{-r/h}[/tex] we have [tex]
re^{-r/h} = he^{-r/h} - h\frac{d}{dr} re^{-r/h}[/tex] and thus [tex]
\int_0^R re^{-r/h}\,dr = h^2(1 - e^{-R/h}) - hRe^{-R/h}.[/tex]
There is a constant (+C) after integrating the density function to obtain cumulative mass M(r), and M(0) is not 0.
You seem confused. There is no arbitrary constant in a definite integral, which is what [itex]M(R) = 2\pi\int_0^R r\rho(r)\,dr[/itex] is, and a basic result of integration theory (Riemann or Lebesgue) is that for any function [itex]f[/itex], [itex]\int_a^a f(x)\,dx = 0[/itex].
Cumulative mass in function of r is not a definite integral.
The limits are specified: the lower limit is fixed at zero, and the upper limit is the radius we are considering. That makes it a definite integral.
Likes SammyS
Yes:
You can use the indefinite integral to obtain the correct expression for the cumulative mass, M(r), of the disk. However, it makes sense that M(0) = 0 . That does not give you a value of 0 for the integration constant, C.
In Post#17, you had:
I find c by M(0)=c
Writing the LaTeX version of that, we have: ##\displaystyle \quad M(r)=2\pi \rho_0 (h^2 + rh) (-e^{-r/h}) + C##
Giving that ##\displaystyle \quad M(0)=C-2\pi \rho_0 h^2 ##.
Setting this to zero gives ##\displaystyle \quad 2\pi \rho_0 h^2 =C ##
Substitute that back into the expression for ##M(r)##, and after a little rearranging, you get:
##\displaystyle \quad M(r)=2\pi \rho_0 \left(h^2(1-e^{-r/h}) - rh\,e^{-r/h} \right)##
SammyS said:
Yes:
I was wrong, I find this correct. Thank you very much
Likes berkeman
1. How do I determine the mass density of a disk?
The mass density of a disk can be calculated by dividing the total mass of the disk by its volume. This can be done by measuring the disk's diameter and height, and using the formula for the volume of a cylinder (V = πr2h). Once the volume is determined, the mass density can be calculated by dividing the total mass by the volume.
2. What units are typically used for disk mass density?
The most common units for disk mass density are grams per cubic centimeter (g/cm3). However, other units such as kilograms per cubic meter (kg/m3) or pounds per cubic inch (lb/in3) may also be used.
3. Can the mass density of a disk vary at different points?
Yes, the mass density of a disk can vary at different points depending on the distribution of mass within the disk. For example, a disk with a higher concentration of mass towards the center will have a higher mass density at the center compared to the edges.
4. How can I calculate the total mass of a disk?
The total mass of a disk can be calculated by multiplying the density of the disk by its volume. As mentioned earlier, the volume can be determined using the formula for the volume of a cylinder. Once the total mass is calculated, it can be used to determine the cumulative mass of the disk.
5. Are there any other factors that can affect the calculation of disk mass density?
Yes, there are other factors that can affect the calculation of disk mass density. These include the shape and size of the disk, as well as the distribution of mass within the disk. Additionally, external forces such as gravity or pressure can also impact the mass density of a disk.
  • Classical Physics
