Integrate: Power of cos is even and non-negative
The discussion revolves around an integration problem involving trigonometric functions, specifically focusing on the powers of cosine and sine. Participants are attempting to reconcile their solutions with those provided in a textbook, exploring substitution methods and the manipulation of trigonometric identities.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of substitution, particularly u = cos(x), and the implications of using sin²(x) = 1 - cos²(x) in their solutions. There are questions about the correctness of their approaches and the efficiency of their methods.
The conversation reflects a mix of attempts to understand the problem and validate their solutions. Some participants express confusion about the relationship between their answers and the textbook's, while others provide suggestions for substitution and manipulation of trigonometric identities. There is recognition of the need for clarity regarding the powers of sine and cosine.
Participants mention the challenge of integrating functions with odd powers of sine and cosine, and the discussion includes references to homework constraints and the learning process involved in understanding these concepts.
Chele
First off, thanks for your help. I feel like a dope because everything I'm doing looks correct to me, but my answer is not the same as the book or solution manual gives! I'm usually so good at finding my mistakes.
Thanks for taking the time to help.
http://img232.imageshack.us/img232/391/problemns1.jpg
Where did I go wrong??
http://img57.imageshack.us/img57/1832/solutionkn2.jpg
The book's answer is -1/4 (cos x)^4 + C even when I try to convert sines to cosines, I'm not getting that those two answers were the same.
After the second step, try substituting u = cos (x) instead. By the way, the two are equal, try substituting sin^2 (x) = (1-cos^2 (x)) for every sin^2 (x) in the answer and remember that \frac{1}{4} is a constant as well.
Thanks...I was able to get the book's answer, however...what is wrong with my solution?
Nothing looks wrong with your solution...i think your book just wanted you to immediately realize that u=cos(x) was a good substitution when you saw the integrand
I have to go to work, I'll try the substitution again. Maybe just bad algebra trying to substitute. I'll post later if I got it or not.
Thanks.
Substitute \sin^2{x} = 1 - \cos^2{x} into your answer, and you should get the book's. Hence what you did wasn't wrong, just inefficient.
Duh...got it...I think.
Okay, thanks. It took a moment for it to sink in. When I substituted to try to get the two answers to equal up, I got \frac{1}{4} - \frac{1}{4} cos^{4}x
I see now that the extra \frac{1}{4} is just part of the constant of integration.
If that is a correct statement, I am straight.
Thank you! :approve:
By the way, you kind of confused me with your title: "Power of cos is even and non-negative". Obviously, here, both sine and cosine are to odd powers. The cosine substitution is the "standard" one for a situation like this.
Thanks for the help... It's all new to me!
Any time you have an integrand of the form sinn(x)cosm(x) with either m or n odd, you can always factor out 1 of those (for example if sin5(x)), so that you have left an even power (sin(x) sin4(x)). Use cos2(x)= 1- sin2(x) or sin2(x)= 1- cos2(x), repeatedly if necessary, to write it in terms of the other function. (sin4(x)= (sin2(x))2= (1- cos2(x))2 and then use the substitution u= cos(x) or u= sin(x).
If both m and n are even then it is harder. Use sin2(x)= (1- 2sin(2x))/2 and cos2(x)= (1+ 2cos(2x))/2 to reduce the powers until you have an odd power of one or the other.
Umm...you know what...you are absolutely right. Cos and sin are odd and positive. I work midnight shift and I posted it after not having sleep for quite some time.
As for the even powers, I'm moving on to that homework tonight.
Again, appreciate the help. This place is a gold mine of information!
  • · Replies 16 ·
