Integrate (xsinx - cosx)/x^2 with Intro Calc Techniques
  • Thread starter Thread starter The Head
    Integrate Intro
The integral of (xsinx - cosx)/x^2 cannot be solved using elementary techniques, as it involves the sinc function, which has not yet been covered in introductory calculus. The discussion highlights attempts to use integration by parts, leading to a loop involving the integrals of cos(x)/x^2 and sin(x)/x. Participants suggest that a possible typo in the original problem may be the cause of confusion, specifically regarding the sign in the numerator. The integral calculator provided an answer involving the sine integral function, which is outside the scope of the current curriculum. Clarification on the problem's formulation is recommended for further progress.
The Head
Evaluate ∫((xsin(x) - cos(x))/x^2. Hint: Use Integration by Parts for sin(x)/x
Problem also attached if that's clearer
IBP: ∫u dv = uv- ∫v du
I'm pretty confused here because after getting stuck on this problem, I tossed it into an integral calculator and it said the answer was 2 Si(x) + cos(x)/x + C. In intro calc we definitely haven't learned the Si(x) function or even gotten to any of the Taylor polynomial stuff yet.
I tried IBP for sin(x)/x and got -cos(x)/x - ∫cos(x)/x^2 dx. At first this looked promising, since that is my second term. So I had in total now: -cos(x)/x - 2∫cos(x)/x^2 dx.
To do the integral portion, I integrated again (by parts) to find -2∫cos(x)/x^2 dx= 2*cos(x)/x +2∫sin(x)/x dx.
Putting it all together, the original integral = -cos(x)/x + 2*cos(x)/x +2∫sin(x)/x dx= cos(x)/x +2∫sin(x)/x dx. I seem to be getting into a loop, where the integral of cos(x)/x^2 is related to the integral of the sin(x)/x, but can't seem to simplify the terms.
Help on how to proceed?
Thanks for confirming it can't be solved-- I'll try to see what's up with the problem.
scottdave said:
Perhaps there is a typo.
I'd guess the minus sign in the numerator was supposed to be a plus sign.
Likes SammyS and archaic
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 27 ·
