Integrating Bulk Modulus to Find Pressure at Variable Depth
13 replies · 4K views · last reply
reddawg
See image.
pressure = density*gravity*depth
The pressure at 5000 ft according to the book is 322,000 psf. This makes sense because density*gravity*depth = 2*32.2*5000 = 322,000 psf. How do I apply the bulk modulus equation to find the pressure at 5000 ft factoring a variable density with depth (The book says its 323,200 psf which makes sense because density increases with depth, although very slightly)?
  • Textbook problem 6 (2.22) on page 71 with bulk modulus B = -V(dp/dV) = rho(dp/drho) at constant temperature, and parts (a) 1500 ft, (b) 5000 ft, (c) 15,000 ft.
That would be just [density*gravity]. So how do I apply that?
Right. $$\frac{dp}{dz}=\rho g$$
Now, from the bulk modulus equation, if the density approaches ##\rho_0## at low pressures, what is the density at pressure p?
That's where I have trouble. I always end up with just [density*gravity*depth]. Is it just (1/g)*(dp/dz) ?
The relationship between density and pressure does not involve z. It's strictly a physical property relationship (sort of like the ideal gas law, except for a liquid).
Chet
So, solving for density using the Bulk Modulus equation:
ρ = B*(Δρ/p)
ρ = B*(Δρ/p)
Actually, the equation is $$\frac{1}{\rho}\frac{d\rho}{dp}=\frac{d(\ln \rho)}{dp}=\frac{1}{B}$$ What do you get if you integrate that, subject to the initial condition ##\rho=\rho_0## at p --> 0?
I get:
(1/B)*p = ln(ρ/ρ0) when factoring in the initial conditions.
reddawg said:
I get:
Good. Now solve for ##\rho## in terms of p. What do you get?
reddawg said:
ρ = ρ0ep/B
OK. Now substitute that into the hydrostatic equation in post #4. What do you get? Can you integrate that from z =0?
(dp/dz) = ρ0gep/B
How do I rearrange that to integrate from z=0 to h?
reddawg said:
(dp/dz) = ρ0gep/B
Cmon man.
$$e^{-\frac{p}{B}}dp=\rho_0 g dz$$
