Integrating Bulk Modulus to Find Pressure at Variable Depth
13 replies · 3K views
reddawg
See image.
pressure = density*gravity*depth
The pressure at 5000 ft according to the book is 322,000 psf. This makes sense because density*gravity*depth = 2*32.2*5000 = 322,000 psf. How do I apply the bulk modulus equation to find the pressure at 5000 ft factoring a variable density with depth (The book says its 323,200 psf which makes sense because density increases with depth, although very slightly)?
What is the hydrostatic equation, expressed in terms of the derivative of pressure with respect to depth?
That would be just [density*gravity]. So how do I apply that?
Right. $$\frac{dp}{dz}=\rho g$$
Now, from the bulk modulus equation, if the density approaches ##\rho_0## at low pressures, what is the density at pressure p?
That's where I have trouble. I always end up with just [density*gravity*depth]. Is it just (1/g)*(dp/dz) ?
The relationship between density and pressure does not involve z. It's strictly a physical property relationship (sort of like the ideal gas law, except for a liquid).
Chet
So, solving for density using the Bulk Modulus equation:
ρ = B*(Δρ/p)
ρ = B*(Δρ/p)
Actually, the equation is $$\frac{1}{\rho}\frac{d\rho}{dp}=\frac{d(\ln \rho)}{dp}=\frac{1}{B}$$ What do you get if you integrate that, subject to the initial condition ##\rho=\rho_0## at p --> 0?
I get:
(1/B)*p = ln(ρ/ρ0) when factoring in the initial conditions.
reddawg said:
I get:
Good. Now solve for ##\rho## in terms of p. What do you get?
reddawg said:
ρ = ρ0ep/B
OK. Now substitute that into the hydrostatic equation in post #4. What do you get? Can you integrate that from z =0?
(dp/dz) = ρ0gep/B
How do I rearrange that to integrate from z=0 to h?
reddawg said:
(dp/dz) = ρ0gep/B
Cmon man.
$$e^{-\frac{p}{B}}dp=\rho_0 g dz$$
