Integrating on Compact Manifolds
AnalysisQuest
This problem is in Analysis on Manifolds by Munkres in section 25. [itex]R[/itex] means the reals
Suppose [itex]M \subset R^m[/itex] and [itex]N \subset R^n[/itex] be compact manifolds and let [itex]f: M \rightarrow R[/itex] and [itex]g: N \rightarrow R[/itex] be continuous functions.
Show that [itex]\int_{M \times N} fg = [\int_M f] [ \int_N g ][/itex]
The hint states to consider the case where supports of f and g are contained in coordinate patches.
I know the general formulation of integration over a compact manifold when the support of the function is contained in a single coordinate patch. Also, I know how to integrate functions on manifolds using partitions of unity.
I know the general idea. First I must prove that this holds when the support of f and g are in a single coordinate patch. Then using partitions of unity, I want to notice the integral is just the sum of integrals over finitely many coordinate patches. What I can't get is the part where the support of f and g are in a single coordinate patch:
Suppose [itex]supp(f) \subset V[/itex] with [itex]\phi : U \rightarrow V \subset M[/itex] and [itex]supp(g) \subset V'[/itex] with [itex]\psi : U' \rightarrow V' \subset N[/itex].
Then [itex]\int_{M\times N} fg = \int_{U \times U'} (fg) \circ (\phi\times\psi) V_k(\phi \times \psi)[/itex] but I don't know how to deal with this...
I think you just want to use Fubini's theorem. The integral of |fg| exists because f and g are continuous on compact sets, so they are uniformly continuous and bounded. Doesn't that work?
The problem is that I don't know how to split up the k-volume term and I don't know how to deal with phi x psi. Unless what I've done so far is completely wrong. I've been stuck for days now and I'm just frustrated and missing something obvious, I think.
I think you are over complicating it. If you are working on a single coordinate patch and you've applied a partition of unity then the functions you are integrating are continuous and the domains over which you are integrating have compact support. The Jacobean is differentiable. Everything is bounded. I think you can just say it's Fubini's theorem on R^m x R^n. I don't think you need to do anything complicated.
