Integrating the delta function
The discussion focuses on evaluating the integral of the Dirac delta function, specifically ∫δ(cosx - 1/2)dx from 0 to π, using the substitution u = cosx. Participants emphasize the importance of correctly applying the substitution and changing the limits of integration accordingly. After substituting, the integral transforms to -∫δ(u - 1/2)(1/√(1 - u²))du, with limits adjusted from 1 to -1. The final answer is confirmed to be 2/√3, although a participant initially misplaces a negative sign in their calculations. The thread highlights the necessity of careful substitution and understanding the properties of the delta function in integration.
captainjack2000
By using the substitution u=cosx obtain the value of the integral
\int\delta(cosx-1/2)dx between 0 and pi
I have no idea how to go any further with this apart from substituting in for u!?
What's the integral you get after doing the substitution?
So, make the substitution! We can't help you if you don't do (or show) your work.
Sorry, I realize my post was very specific. To be perfectly honest I don't really know where to start. I know that the delta function is defined as
\delta(x-a)=o if x\neqa and tends to infinity is x=a
shifting property
\intdx\delta(x-a)f(x) = f(a) where the integral is over all space.
In this case
I=\int\delta(cosx-0.5)dx where the integral is between zero and pi
=\int\delta(u-0.5)dx letting u=cosx
not sure how to proceed
You're substituting, yet after the substitution you integrate over the original variable,dx? Execute the substitution correctly first. Also put the entire expression between brackets it saves you time and is a lot neater.
You still have dx in your integral. Write everything in terms of u and du. Don't forget to change the limits of the integral too.
Ok...(my brain is obviously not working right now!)
if u=cosx
du=-sinxdx
dx=-du/sinx
but you need this independent of x? but x=cos^-1(u) ??
changing the limits:
when x=0 u=1 and when x=pi u=-1
You can write sin x = √(1 - u2). So the integral becomes
-\int_{1}^{-1} \delta(u - 1/2) \frac{1}{\sqrt{1-u^2}}du
To see that \sin \arccos u =\sqrt{1-u^2} use \cos^2x+\sin^2x=1 or use a triangle.
Cyosis said:
To see that \sin \arccos u =\frac{1}{\sqrt{1-u^2}} use \cos^2x+\sin^2x=1 or use a triangle.
You mean
\sin \cos^{-1} u = \sqrt{1-u^2}.
Yes I do thanks for pointing it out, it's fixed now.
thank you that clarifies it alot!
Therefore the solution is going to be -1/(1-1/4)^0.5 = 1/(3/4)^0.5 = 2/sqrt(3) ?
Yep, that's correct.
Your final answer is correct, but you had a minus sign in your first expression which shouldn't be there.
thank you !
  • · Replies 31 ·
