Integrating triple integral over region W
The discussion focuses on calculating the triple integral of the function $$f(x,y,z)=y$$ over the region W, defined by the plane $$x+y+z=2$$, the cylinder $$x^2 +z^2=1$$, and the plane $$y=0$$. Participants suggest using cylindrical coordinates for easier integration due to the circular boundary of the cylinder. The correct approach involves integrating in the $$y$$ direction first, with the remaining integral over the entire circle in the $$xz$$ plane, ultimately yielding the result $$\frac{9\pi}{4}$$.
  • Understanding of triple integrals in calculus
  • Familiarity with cylindrical coordinates
  • Knowledge of the equations of planes and cylinders
  • Experience with integration techniques in multiple dimensions
  • Learn about cylindrical coordinates and their application in triple integrals
  • Study the method of changing the order of integration in multiple integrals
  • Explore the use of computational tools like Maple for solving integrals
  • Review the geometric interpretation of triple integrals over bounded regions
Students and educators in calculus, mathematicians working with multivariable integrals, and anyone seeking to understand the integration of functions over complex geometric regions.
toforfiltum
$$f(x,y,z)=y$$ ; W is the region bounded by the plane ##x+y+z=2##, the cylinder ##x^2 +z^2=1##, and ##y=0##.
Since there is a plane of ##y=0##, I decided that my inner integral will be ##y=0## and ##y=2-x-z##. But after this I have a problem. I don't know how to proceed. How do I decide the bounds of ##x## and ##z##? Can I just use the function ##x^2+z^2=1##? If so, will it be $$\int_{-1}^1 \int_{-\sqrt(1-x^2)}^{\sqrt(1-x^2)} \int_ {0}^{2-x-z} y \,dy \, dz \, dx$$
Thanks.
Thanks.
Yes, you can do it that way. It might be easier to use polar type coordinates for the xz integral because of the circle, depending on how easy the rectangular integral is.
Yes, the rectangular integral is really horrible. It involved a lot of ##cos^4 \theta## terms.
I agree with LCKurtz. Change to cylindrical coordinates. You have to account for the place where the plane starts to intersect the cylinder. Otherwise, you'll be integrating over the entire circle near the top, and won't get the right volume.
But I think I'm supposed to be calculating it using rectangular coordinates, because this question is in the section before the change of variables topic.
Okay then. Maybe look at changing the order of integration? Let y be your outermost integral, since limits on x and z will both depend on how much of the circle is being cut off by the plane.
It looks like there are two parts here...the first part is just the cylinder before the plane intersects it.
The second part will be from y = 1 to y = 3. Try to define your x and z limits based on that.
I'm not sure I understand @RUber 's concerns and suggestions. I would say you definitely want to integrate in the ##y## direction first, and the remaining ##x,y## or ##r,\theta## integral will be over the whole circle in the xz plane. I think you should get ##\frac{9\pi}{4}## either way.
Ok, thanks for providing the correct answer for me to check. However, I got a wrong answer. What I would like to know is if the process of calculating the integral in rectangular coordinates really long? Because mine certainly is. I'm just wondering if I'm doing it correctly.
@LCKurtz Oh, it's fine. I've got the correct answer now, though only after a painfully long process. :smile:
Thanks!
Thanks!
Good job. Luckily, I didn't experience the "pain" of working it all out, since I just put your original correct triple integral into Maple. It cranked out the answer in a couple of seconds.
  • · Replies 19 ·
