Integrating velocity with respect to time when velocity depends on position
The discussion focuses on calculating the transit time for a particle moving from point A to point B when its velocity is a function of position, expressed as V = V(x). The key insight is that to find the time taken, one must integrate the expression dt = (1/V) dx, allowing the integration to be performed with respect to the known variable x. The example provided illustrates the relationship between velocity and position, emphasizing the need to manipulate the equations correctly to derive the desired time variable.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concept of velocity as a function of position.
  • Knowledge of differential equations and their applications in physics.
  • Basic proficiency in LaTeX for mathematical expressions (optional but beneficial).
  • Study the principles of integrating functions with respect to different variables.
  • Learn about the relationship between velocity, acceleration, and position in classical mechanics.
  • Explore the use of LaTeX for formatting mathematical equations in discussions.
  • Investigate more complex scenarios involving variable acceleration and its impact on motion.
Students and professionals in physics, engineering, and mathematics who are working on problems involving motion and integration of velocity with respect to position.
timsea81
Okay this seems like it should be simple but I'm stuck.
A particle moves from point A to point B in one dimension. The velocity of the particle changes with position according to some formula V = V(x). How long does it take for the particle to get from point A to point B?
If I could write V as a function of time, I could than integrate V=V(t) from 0 to t and that would give me the transit time. How do I do it if V depends on X?
Say, for example, V(X) = 1 + ax
dx=vdt, so dt=dx/v, integrate to find time
Thanks. That does it, and I think I understand it now. I was thinking of it backwards before.
If I have v=v(t), I can integrate v from 0 to t to get the total distance traveled. I already know time in that case. If I don't have time I'd have to solve this for t, set it equal to t, and solve. In this case v = dx/dt --> dx = v dt, so integrating v dt gives you x.
If I have v=v(x) I solve so that dx is at the end of the expression: dt = (1/v) dx so I can integrate with respect to x, the variable that I know.
why can't you guys bother to use \LaTeX on this site that provides that resource?
it helps you articulate your question or answer. and it makes it easier for anyone to read either.
Why can't you bother capitalizing the first words of your sentences, or proofreading your post to realize that the word "either" was used wrong?
I don't know latex, that's why I didn't use it. Do you similarly not know the English language?
I guess I might say "thanks for the tip" had you not worded your response as a criticism.
Likes Khal_eesi
  • · Replies 22 ·
  • · Replies 49 ·
15K
