Integrating x^3 lnx dx - am i on the right track?
The discussion revolves around the integration of the function x^3ln(x) with respect to x. Participants are exploring methods to approach this integral, particularly focusing on substitution and integration by parts.
  • Participants discuss using u-substitution with u = ln(x) and express concerns about the effectiveness of this approach. There is a suggestion to consider integration by parts instead, with some participants questioning the necessity of u-substitution. Others explore the integration by parts method directly, discussing the roles of u and dv.
Several participants have provided guidance on the use of integration by parts, indicating that it may be a more effective method than the initial substitution attempted. There is acknowledgment of the original poster's progress and attempts, with some participants affirming that they are on the right track.
Some participants mention the challenge of integrating products and the lack of a general product integration rule, which is a point of discussion regarding the choice of methods. There is also a note about the importance of verifying results through differentiation.
drjohnsonn
integrating x^3lnxdx
i let u = lnx
du/dx = 1/x
xdu = dx
x=e^u
substituting that, i got e^(4u)udu
then i let v = 4u
dv/du = 4
1/4du = dv
substituting that, i got 1/4integral e^v vdv
I haven't gone beyond that step yet. I was hoping someone more knowledgeable than I currently am could tell me if I am on the right track or let me know at what point I went wrong. Responses very much appreciated!
i let u = lnx
du/dx = 1/x
xdu = dx
x=e^u
You're fine up to this point! Using u-substitution won't do anything helpful for you at this point; you are basically left trying to integrate the same problem. I would suggest integration by parts!
Hello drjohnsonn. Welcome to PF !
As scurty suggested, try integration by parts.
Thanks! I am quite a novice as of now and have not quite gotten to that point yet. I suppose I'll have to wait a bit before I finish working on this. But is the reason for having to integrate by parts that there is no general product integration rule?
Well, I immediately think integration by parts when I see a term that can be reduced by differentiating (u in this case) and a term that doesn't get "more complicated" by anti-differentiating (##e^{4u}## in this case). It's tough to explain, someone else might have a better general rule for when to integrate by parts.
Also, for what it's worth, you could have integrated by parts right from the start with no u-substitution. ##u = ln(x), \quad dv = x^3 \ dx##
Correct.
In fact integration by parts is based upon the product rule for differentiation.
Thanks for the advice!
Am I accurate in doing this:
u = lnx dv=x^3dx
du = 1/xdx v = Sx^3dx = x^4/4
and since Sudv = uv - Svdu
Sx^3lnxdx = 1/4(x^4)lnx - 1/4Sx^3dx = 1/4x^4lnx - 1/16x^4 + C
if i skipped something, point it out. i kind of ended up looking at the answer before i finished and hope that didn't fool me into incorrectly solving it
Looks good :smile:
There's an easy way to check: Differentiate. Differentiation is oftentimes far easier than integration (and the only time it isn't is when both are easy). Upon differentiation you should recover the original equation.
It's always a good idea to double check your work.
wootwoot
i let u = lnx
du/dx = 1/x
xdu = dx
x=e^u
then i let v = 4u
dv/du = 4
1/4du = dv
Yes. I think you are on the right track. Now, you can do integration by parts again to get the answer.
  • · Replies 16 ·
  • · Replies 22 ·
