Integration by partial fractions
5 replies · 3K views
Xcron
I started this section off quite well and I did very well on the problems where there are only linear factors but when I got to the problems with quadratic factors, I began getting wrong answers. I though that perhaps I would receive some advice or my error/mistake could be corrected if possible.
The problem is:
[tex]\int\frac{4x^4-43x^3+200x^2-442x+383}{(x-3)(x^2-6x+13)}dx[/tex]
It comes with a small help thing that says: [tex](x-3)(x^2-6x+13) = <br /> x^3-9x^2+31x-39[/tex]
Ok so the first thing I did was use long division and I got [tex]4x-7[/tex] as the answer of the long division. Next I proceeded to do:
[tex]4x^4-43x^3+200x^2-442x+383 = A(x^2-6x+13) + (Cx+D)(x-3)[/tex].
Next, I plugged in 3 for the value of x so that I could solve for A and I got its value to be 5. Next, I plugged in 0 for the value of x so that I could get A and D alone and solve for D. I got its value to be -106, which is horribly wrong for some reason, I think. Next I plugged in 1 for the value of x and solved for C nd its value came out to be 75, which is also horribly wrong probably..I made a mistake somewhere in there I think...after that, I set up the new integral:
[/tex]\int\(4x-7+\frac{5}{x-3}+\frac{75x-106}{x^2-6x+13})dx[/tex].
I solved that and got my final answer to be:
[tex]2x^2-7x+5\ln|x-3|+\frac{75}{2}\ln|x^2-6x+13|+<br /> \frac{119}{2}\arctan(\frac{x-3}{2})+C[/tex].
This answer is wrong and the correct answer is:
[tex]2x^2-7x+5\ln|x-3|+4\ln|x^2-6x+13|+<br /> \frac{9}{2}\arctan(\frac{x-3}{2})+C[/tex].If I am making some kind of mistake, then I must be inherently making it because all my other answers to problems with quadratic factors is coming out wrong...please help me.
You should have a remainder after you divide:
[tex]4 x - 7 + \frac{13 x^2 - 69 x + 10}{x^3 - 9 x + 31 - 39}[/tex]
That's an awfully tedious problem.
Yes, I do have a remainder after I divide. After the long division, I have:
[tex]4 x - 7 + \frac{13 x^2 - 69 x + 110}{x^3 - 9 x^2 + 31x - 39}[/tex]
What do I do with it? I was just looking over that because I noticed something about it in the book, but I can't quite grasp what the remainder would be used for..
You'll want to split the remainder into partial fractions and then you can integrate everything.
Ok, I just tried that and I finally got the right answer...I guess that's what my error was. After the long division, I need to use the remainder..heh..
Upon further analysis, I realized that the answer is still wrong, this is why:
after the division and the [tex]a^2 + x^2[/tex] trig substitution, the integral is:
[tex]2x^2-7x+5\ln|x-3|+<br /> \int\frac{16\tan\theta+24-15}{4\sec^2\theta}2\sec^2\theta d\theta[/tex]
then:
[tex]x^2-7x+5\ln|x-3|+8\ln|sec\theta|+\frac{9}{2}\theta[/tex]
The 8 in front of the natural log is supposed to be a four, anyone know why I have an 8?...
