How Does Integration by Parts Simplify \(\int 8x^2 \cos(2x) \, dx\)?
The discussion focuses on solving the integral \(\int 8x^2 \cos(2x) \, dx\) using integration by parts. Participants detail the steps involved, including the selection of \(u = 8x^2\) and \(dv = \cos(2x) \, dx\), leading to the expressions \(du = 16x \, dx\) and \(v = \frac{1}{2} \sin(2x)\). The conversation highlights common pitfalls, such as the confusion surrounding the differential \(dx\) and the necessity of removing it after integration. Ultimately, the correct final answer is derived, emphasizing the importance of understanding the notation and process of integration.
  • Understanding of integration techniques, specifically integration by parts.
  • Familiarity with trigonometric functions and their integrals.
  • Knowledge of differential calculus, particularly the concept of differentials.
  • Basic algebra skills for manipulating expressions and constants.
  • Study the integration by parts formula: \(\int u \, dv = uv - \int v \, du\).
  • Learn how to handle differentials in integration, focusing on when they can be omitted.
  • Explore common mistakes in integration, particularly with trigonometric functions.
  • Practice solving integrals involving products of polynomials and trigonometric functions.
Students and educators in calculus, mathematicians seeking to refine their integration skills, and anyone interested in mastering integration techniques, particularly integration by parts.
Whatupdoc
i will use "\int" as integral signs, cause latex seems to be down.
uv - \int v*du
\int 8x^2cos(2x)*dx
u = 8x^2
du = 16x*dx
dx = 1/16
dv = cos(2x)
v = 1/2sin(2x)
plug in what i found for the formula
8x^2*1/2*sin(2x) - \int 1/2*sin(2x)*16x
take out the 1/2, because it's a number.
4x^2*sin(2x) - 1/2 \int sin(2x) *16x
k this is the part where I am stuck on. do i use integration by parts on the right side agian? my attempt of u-du:
u=16x
du = 16*dx
dx = 1/16
sin(1/8*u) * u
hmm... looks wrong
I find the equation
dx=1/16
to be rather odd.
Also, the lack of a 'dx' at the end of the expression:
seems a bit disconcerting.
That said, what's wrong with dv=sin(2x) in the second parts?
"That said, what's wrong with dv=sin(2x) in the second parts?"
hmm it's suppose to be v=sin(2x)*dx right? not dv. hmm i don't see anything wrong with that part, unless I am missing something.
"I find the equation
dx=1/16
to be rather odd."
yea it's suppose to be dx=1/16*du, it's suppose to balance du right?
how would i solve the integral on the right side? \int 1/2*sin(2x)*16x
another parts sub?
dx=1/16
to be rather odd."
How about dx=1/(16 x) * du so that it agress with the equation above it?
\int sin(2x) * 16x dx
is the same as
\int 16x * sin(2x) dx
which should look somewhat familiar. (yes, parts should work.)
ok i finished the problem, but i can't seem to get it correct.
4x^2*sin(2x) - 1/2 \int sin(2x) *16x*dx
that is what i got so far form the previous post
ok using parts agian...
uv - \int v*du
u = 16x
du = 16*dx
dx = 1/16 *du
dv = sin(2x)
v = -1/2*cos(2x)
ok time to fill in what i know...
16x*-1/2*cos(2x) - \int -1/2*cos(2x)*16*dx
take out the -1/2 and 16 cause it's constant
-8x*cos(2x) +8 \int cos(2x)*dx
find the anti-derv.
-8x*cos(2x) + 4 sin(2x)*dx
put everything together...
4x^2*sin(2x) - 1/2(-8x*cos(2x) + 4 sin(2x)*dx)
4x^2*sin(2x) +4x*cos(2x) -2sin(2x)*dx
ok that's my final answer and it's correct, but the DX is still there... hmm i thought i was suppose to add in 1/16 for dx,cause that's the value that i found
You shouldn't be getting any differentials at the end of the process.
Still no Latex :)
The last integration should be something like:
\int -cos(2x) dx = -1/2 sin(2x)
I'm guessing you did:
\int -cos(2x) dx -> -1/2 sin(2x) dx
(which is incorrect) instead.
Still no Latex :)
yea, but why did the dx get removed?
In an integral, the 'dx' indicates the variable of integration, and where the expression 'inside' the integral ends.
This isn't necessarily the most satisfying answer, but really, the 'dx' gets removed when integration happens because that's the way the notation works. There's probably a historic explanation, and there may well also be an explanation based on differentials, but I haven't seen either. If you like, you could think of the \int as a sort of opening parenthesis and the 'dx' as a sort of closing parenthesis.
For now, it sufficient to know that every time that integration takes place using the usual notation, a differential (e.g. 'dx', 'dt', or 'dθ') gets removed. Integration by parts is a bit confusing in this regard because it's really a shorthand for something like the this:
/int u(x)v'(x) dx =
/int u(x)v'(x) + 0 dx =
/int u(x)v'(x) + (u'(x)v(x) - u'(x)v(x)) dx =
/int (u(x)v'(x)+u'(x)v(x)) - u'(x)v(x) dx =
/int (u(x)v'(x)+u'(x)v(x)) dx - \int u'(x)v(x) dx =
u(x)v(x) + C - \int u'(x)v(x) dx
Although I advise you against it, and it is not standard, you could develop your own notation for integration. On a computer, for example, an integral might look like "integral(f(x),x,a,b)" rather than using the symbols that you're familiar with.
  • · Replies 105 ·
  • · Replies 22 ·
  • · Replies 17 ·
