Integration - Change of Variable
6 replies · 2K views
BOAS
[/B]
Use integration by substitution to evaluate the integral,
[itex]I = \int^{x}_{x_{0}} (3 + 4t)^{\frac{5}{3}} dt[/itex]
I am confused by this question, and think that the limits on the integral might be a typo. Does it make sense for them to be [itex]x, x_{0}[/itex]? I think that the question means for them to be [itex]t, t_{0}[/itex] but I'm not sure that it isn't me not understanding something properly.
Ordinarily,
I would make the substitution [itex]u = 3 + 4t[/itex], and say that [itex]du = 4 dt[/itex].
[itex]I = \int^{3+4t}_{3+4t_{0}} (u)^{\frac{5}{3}} \frac{du}{4} = [ \frac{3}{5} \frac{u^{\frac{8}{3}}}{4}]^{3 + 4t}_{3+4t_{0}} = [ \frac{3}{5} \frac{(3+4t)^{\frac{8}{3}}}{4}]^{3 + 4t}_{3+4t_{0}}[/itex]
[itex]I = (\frac{3}{5} \frac{(3+4t)^{\frac{8}{3}}}{4}) - (\frac{3}{5} \frac{(3+4t_{0})^{\frac{8}{3}}}{4})[/itex]
It simplifies a bit further, but i'd really like confirmation that I have interpreted this question correctly.
Thanks.
What you have here is a definite integral: the integral of [itex](3 + 4t)^{5/3}[/itex] between [itex]x_0[/itex] and [itex]x[/itex]. It's no different from if you were asked to evaluate [itex]\int_a^b (3 + 4t)^{5/3}\,dt[/itex].
When writing definite integrals it is bad practice to use the same symbol as both a limit of the integral and as the dummy variable. And when a question uses a particular symbol, you should use that same symbol in your answer.
Yes, when you change the variable, you have to change the limits of integration as well.
Your integral has [itex]x_0[/itex] and [itex]x[/itex] as limits of integration and you let u= 3+ 4t. At the lower limit, [itex]t= x_0[/itex] so [itex]u= 3+ 4x_0[/itex]. At the upper limit, [itex]t= x[/itex] so [itex]u= 3+ 4x[/itex]. Your integral should be
[tex]\frac{1}{4}\int_{3+4x_0}^{3+ 4x} u^{5/3} du[/tex]
You final result, whether you integrate with respect to t or u, should be a function of x.
Hello,
does this mean that here [itex]I = (\frac{3}{5} \frac{(3+4t)^{\frac{8}{3}}}{4}) - (\frac{3}{5} \frac{(3+4t_{0})^{\frac{8}{3}}}{4})[/itex], where there is a t, I need to substitute in [itex](3+ 4x)[/itex] and [itex](3+4x_{0})[/itex]
To get [itex]I = (\frac{3}{5} \frac{(3+4(3+4x))^{\frac{8}{3}}}{4}) - (\frac{3}{5} \frac{(3+4(3 + 4x_{0})^{\frac{8}{3}}}{4})[/itex]?
Hi,
now that you've said it, I do recall my lecturer discussing dummy variables.
Thanks.
BOAS said:
Hello,
No ! Now you've done the transform twice.
You work out an expression for ## \frac{1}{4}\int_a^b u^{5/3} du## and fill in a = 3 + 4x0 and b = 3 + 4x
Thanks for clarifying that, I suspected this would be the case.
