Integration (Enclosed Area & Rotation Volume)
The discussion focuses on calculating the area enclosed by the parametric curve defined by x=3+cos(t) and y=4sin(t), which represents an ellipse. The area is determined to be 4π, derived from the integral A=-4 ∫ y dx from 0 to π/2, where the negative sign accounts for the direction of integration. Additionally, the volume generated by revolving the area between the cycloid defined by x=t-sin(t) and y=1-cos(t) about the y-axis is expressed using the shell method as v=2π ∫ xy dx, specifically v=2π ∫ (t-sin(t))(1-cos(t))^2 dt.
  • Understanding of parametric equations and their geometric interpretations.
  • Familiarity with the concept of integration in calculus.
  • Knowledge of the shell method for calculating volumes of revolution.
  • Basic understanding of Green's Theorem and its application in area calculations.
  • Study the derivation of area formulas for ellipses and their parametric representations.
  • Learn about the shell method for volume calculations in calculus.
  • Explore Green's Theorem and its applications in vector calculus.
  • Investigate the properties and applications of cycloids in geometry.
Students and educators in calculus, mathematicians interested in geometric applications of integrals, and anyone studying parametric equations and their implications in area and volume calculations.
Latios1314
1) Find the area enclosed by the curve x=3+cos(t) and y=4sin(t).
My tutor gave me a hint which confuses me.
A=-4 integral y dx where the upper limit is pi/2 and the lower limit is 0.
I do not understand the -4 part. why must we multiply the integral by -4?
2) Find the volume of the solid generated by revolving about the y-axis the area between the first arc of the cycloid x=t-sin(t), y=1-cos(t) and the x-axis. Use the shell method.
v=2pi integral xy dx
=2pi integral (t-sin(t)) (1-cos(t))^2 dt
I'm stuck at this point.
could anyone help me with these two questions?
anyone?=/
If x= 3+cos(t) and y= 4 sin(t), then cos(t)= x- 3 and sin(t)= y/4 so that (x- 3)^2+ y^2/16= sin^2(t)+ cos^2(t)= 1. The figure is an ellipse with center at (3, 0), minor semi-axis on the x-axis, of length 1, and major semi-axis parallel to the y-axis, of length 4. The area of such an ellipse is \pi times the product of the two semi-axes, here, 4\pi.
A "standard" parameterization for a circle would be "x= R cos(t), y= R sin(t)" where R is the radius and t goes around the full circle, from 0 to 2\pi. Using different "R" for x and y (1 and 4) gives an ellipse rather than a circle. Going from 0 to \pi/2 gives you 1/4 of the ellipse. Because of the symmetry, multiplying that by 4 will give the area of the entire ellipse. The negative is because with x= R cos(t) (or x= cos(t)+ 3), dx= -R sin(t)dt.
You can also see this as a special case of Greens Theorem:
\int\int_D \left(\frac{\partial M}{\partial x}- \frac{\partial N}{\partial y}\right) dxdy= \oint Ndx+ Mdy
In particular, if we take M= 0 N= y the left side becomes \int\int_D -1 dxdy which is just the negative of the area of region D. The right side becomes \oint y dx where the integral is around the circumference of the region.
However, this problem has nothing to do with "volume of rotation" or even "volume".
