Integration for Volume Given Cross Sections
The discussion centers on calculating the volume of a storage building with a specific cross-sectional shape defined by the curve y(x) = 20 - (x^6/3,200,000). The area of each rectangular cross-section is determined by multiplying the base of 50 feet by the height given by y(x). An integration attempt yielded a volume of approximately 17,142.86 cubic feet. This result, when rounded to three significant figures, aligns with option C) 17,100. The approximation in the problem's answers confirms that the calculated volume is indeed correct.
carlodelmundo
The roof and walls of a storage building are built in the shape modeled by the curve y(x) = 20 - \frac{x^6}{3,200,000}. Each cross section cut perpendicular to the x-axis is a rectangle with a base of 50 feet and a height of y feet.
In cubic feet the volume of the building is approximately:
A) 686
B) 2,000
C) 17,100
D) 34,300
E) 50,000
Area = (50)(y(x)) = 50 ( 20 - \frac{x^6}{3,200,000} )
Given the equation above, I reasoned that the area is the base (the 50 feet) multiplied by the function y(x). I carried the following integration:
V = \int^{0}_{20} 50 * ( 20 - \frac{x^6}{3,200,000} )
I get an answer of 17142.86. Is this correct? It's a little off from the problem.
Sure it's right. If you look at the answers they are described as 'approximate' and appear to all be rounded to three significant figures. If you round your answer it certainly matches C).
Thank you!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
