Integration of an inverse sqrt composite function
In summary, Geologist A signals to Geologist B by pushing a box of samples from side to side, which causes a transverse wave to propagate up the rope. The total mass of the rope is 14 kg, and it takes g = 9.8 ms^2 for the wave to travel from the bottom of the cave to the surface.
Hendrick
43
“Geologist A” at the bottom of a cave signals to his colleague “Geologist B” at the surface by pushing a 11.0 kg box of samples from side to side. This causes a transverse wave to propagate up the 77.0 m rope. The total mass of the rope is 14.0 kg. Take g = 9.8 m/s².
How long does it take for the wave to travel from the bottom of the cave to the surface?[Hint: Find an analytic expression v(z) for the wave speed as a function of distance. Then use the fact that at any given point on the rope the time dt taken to travel a small distance dz is given by: dt=dz/v(z). Then integrate to obtain the total travel time. ]
http://oasis.phy.auckland.ac.nz/oasis/a/question/187416/image.gif
u = mR/z
T(z) = u.z.g + mB.g
v(z) = (T(z)/u)^(1/2)
dt=dz/v(z)
z = the length of the rope = L (used for integrating)
v(z) = ((mR/z).z.g + mB.g/(mR/z))^(1/2)
v(z) = ((mR.g + mB.g)/(mR/z))^(1/2)
v(z) = ([(mR.g)/(mR/z)] + [(mB.g)/(mR/z)])^(1/2)
v(z) = ([(mR.g.z)/mR] + [(mB.g.z)/mR])^(1/2)
v(z) = ([mR.g.z] + [(mB.g.z)/mR])^(1/2)
dt=dz/v(z)
dt=dz/([mR.g.z] + [(mB.g.z)/mR])^(1/2)
Integration:
...f L
t= | (1/([mR.g.z] + [(mB.g.z)/mR])^(1/2)).dz
...j 0
...f L
t= | 2.([mR.g.z^2/2] + [(mB.g.z^2)/mR.2])^(1/2).dz
...j 0
I think I integrated it properly but when substituted the values
mB = mass of box
mR = mass of rope
g = 9.8 ms^2
z = 77.0 m
I didn't get the correct answer of t = 2.52s
'u' in your solution is supposed to be the mass density of the rope. It's not mR/z. The rope doesn't have a variable density, it's mR/(total length of rope), a constant. Nice problem presentation, by the way.
Dick said:
'u' in your solution is supposed to be the mass density of the rope. It's not mR/z. The rope doesn't have a variable density, it's mR/(length of rope). Nice problem presentation, by the way.
Hi Dick, z is the length of the rope (77.0m as in the problem) it was just the letter they used in the formula sheet so I carried it forth.
How was my integration? I don't think I know how to integrate nested functions (I assume it's something like the reverse of the chain-rule?).
z in your problem is the variable indicating length along the rope. I mean that u=14 kg/(77 m). It doesn't have the variable of integration in it. Until that gets fixed there isn't any point in discussing the integral.
In your notation u=mR/L not mR/z.
Oh, ok. Thanks for pointing that out :)
So:-
u = mR/L = mR/77
T(z) = u.z.g + mB.g
dt=dz/v(z)
v(z) = ((u.z.g + mB.g)/u)^(1/2)
v(z) = ([(u.z.g)/u] + [(mB.g)/u])^(1/2)
v(z) = ([g.z] + [(mB.g)/u])^(1/2)
dt=dz/v(z)
dt=dz/([g.z] + [(mB.g)/u])^(1/2)
Integration:
...f L
t= | (1/(([g.z] + [(mB.g)/u])^(1/2)).dz
...j 0
...f L
t= | 2.([g.z] + [(mB.g)/u])^(1/2).(g.z^2)/2
...j 0
Where:
mB = mass of box
mR = mass of rope
g = 9.8 ms^2
z = 77.0 m
Is this correct?
Your first integral looks just fine. I don't know how you got from there to the second one. The usual way to do an integration like this is to do a change of variable. Let v=gz+mBg/u.
Ok, I was trying to use the chain rule lol ><
So:-
Integration:
...f L
...j 0
...f L
t= | 2.([(g.z^2)/2] + [(mB.g.z)/u] + C)^(1/2)
...j 0
Where:
mB = mass of box
mR = mass of rope
g = 9.8 ms^2
z = 77.0 m
How am I doing? :smile:
Not too good. You're coming up with some pretty bizarre integration rules which aren't in the book. You have to do the change of variable thing. Eg to integrate 1/(a+bz)^(1/2) I would say v=(a+bz), so dv=b*dz. This turns the integral into 1/v^(1/2)*dv*(1/b). Now it's just integrating v^(-1/2). Does that sound familiar?
Unfortunately not very familiar at all. I haven't really dealt with composite integrals. But I'll try:
a = g.z
b = (mB.g)/u
1/(a+bz)^(1/2)
Integrating v^(-1/2).So:-
Integration:
...f L
...j 0
...f L
t= | (1/(([g.z] + [(mB.g)/u])^(1/2)).[(mB.g)/u]dz.(1/[(mB.g)/u])
...j 0
...f L
t= | 2.(([g.z] + [(mB.g)/u])^(1/2)).[(mB.g)/u].(1/[(mB.g)/u])
...j 0
Where:
mB = mass of box
mR = mass of rope
g = 9.8 ms^2
z = 77.0 m
Take a break and clear your head. While your at it look back at integration by substitution in a calc text. I can roughly see what you are trying to do - but you still seem to be trying to do some kind of a chain rule. And the (1/b) factor in the example becomes (1/g) in the problem, right? Do you see where it's coming from? And after the integration is done and the dz is gone you should also drop the integral sign - it looks pretty confusing otherwise.
1. What is the definition of "Integration of an inverse sqrt composite function"?
The integration of an inverse sqrt composite function refers to the process of finding the antiderivative of a function that is composed of an inverse function and a square root function.
2. What makes integration of an inverse sqrt composite function challenging?
Integrating inverse sqrt composite functions can be challenging because it involves applying multiple integration techniques, such as substitution, integration by parts, and trigonometric substitution, in a specific order to simplify the function and find its antiderivative.
3. How is integration of an inverse sqrt composite function different from regular integration?
The main difference between integration of an inverse sqrt composite function and regular integration is that the former involves the use of multiple integration techniques and requires a deeper understanding of the composition of functions.
4. What are some common examples of inverse sqrt composite functions?
Some common examples of inverse sqrt composite functions include f(x) = 1/√(x^2 + 1), g(x) = √(x^2 - 4), and h(x) = 1/√(x^3 + 1).
5. Why is integration of an inverse sqrt composite function important in science?
Integration of an inverse sqrt composite function is important in science because it allows us to solve complex problems involving inverse and square root functions, which are often seen in physics, engineering, and other scientific fields.
