Integration Problem: Solving ∫ 1/r³ dr/dt
  • Thread starter Thread starter kashiark
    Integration
4 replies · 2K views
kashiark
∫ 1/r³ dr/dt
∫ xa dx = x(a+1)/(a+1)
I have no clue how to solve it like this. I don't have the equation for r in terms of t, so I can't just substitute. How would I do it?
kashiark said:
∫ 1/r³ dr/dt
is that how the question is actually written & what are you integrating with respect to?
it doesn't really make sense how you have written it, do you mean:
[tex]\int dt (\frac{1}{r(t)^3}\frac{dr}{dt})[/tex]
if so have a think about how chain rule differentiation works & how you could try & reverse it using FTC...
OK if it were like that, wouldn't the dt's just divide out allowing you to integrate with respect to r?
∫ dt(1/r³ dr/dt)
∫ 1/r³ dr
-1/(2r²) + C
you can, but its a bit of an abuse of notation, athough it gives the same answer, a better way to think of it is to write:
[tex]\frac{d}{dt} (-\frac{1}{2r(t)^2}) = \frac{1}{r(t)^3}\frac{dr}{dt}[/tex]
then the intergal becomes
[tex]\int dt (\frac{d}{dt} (-\frac{1}{2r(t)^2}))[/tex]
so by FTC, the anti-derivative is
[tex]= (-\frac{1}{2r(t)^2}) +C[/tex]
though the question was to you - how is it written in the actual problem?
It's not on a worksheet or anything; I was just messing with a particular physical situation, and I came to something in that form that I needed to integrate.
