Integration Question: Differentiating a definite integral
4 replies · 3K views
ISITIEIW
So the question is…Evaluate the following…
$$\frac{d}{dx} \left(\int _1^{x^2} \cos(t^2) \, dt \right)$$
I thought i could use the FTC on this because it states…
$$\frac{d}{dx} \left(\int_0^x f(t)\, dt \right)=f(x)$$
but i can't correct? because in my question it starts at 1…is there some way to apply FTC to my problem or is there another general formula for this kind of problem
Re: Integration Question
Since the lower bound is still a constant, it doesn't change the method you use to evaluate this. It could be at 0,1,2 or any constant and still get the same result. You're going to integrate and get a constant and then take the derivative of that constant, so you end up with 0 regardless.
Here you'll need to be careful to use the chain rule when applying the FTOC. What progress have you made so far? :)
d/dx(integration of 1 to x^2 of cos(t^2)dt)
d/dx(integration of 0 to x of f(t)dt)
We are given to evaluate:
$$\frac{d}{dx}\int_1^{x^2}\cos\left(t^2 \right)\,dt$$
Now, the anti-derivative form of the FTOC tells us:
$$\frac{d}{dx}\int_{g(x)}^{h(x)}f(t)\,dt=\frac{d}{dx}\left(F(h(x))-F(g(x)) \right)$$
On the right, applying the chain rule, we obtain:
$$\frac{d}{dx}\int_{g(x)}^{h(x)}f(t)\,dt=F'(h(x))h'(x)-F'(g(x))g'(x)$$
Since $$F'(x)=f(x)$$, we may write:
$$\frac{d}{dx}\int_{g(x)}^{h(x)}f(t)\,dt=f(h(x))h'(x)-f(g(x))g'(x)$$
Applying this to the given problem, there results:
$$\frac{d}{dx}\int_1^{x^2}\cos\left(t^2 \right)\,dt=\cos\left(\left(x^2 \right)^2 \right)(2x)-\cos\left(\left(1 \right)^2 \right)(0)$$
Simplifying, we find:
$$\frac{d}{dx}\int_1^{x^2}\cos\left(t^2 \right)\,dt=2x\cos\left(x^4\right)$$
Let us evaluate $$\frac{d}{dx} \left(\int_a^x f(t)\, dt \right)$$ where $$0<a<x$$
Then since $$\int_0^x f(t)\, dt =\int_0^a f(t)\, dt+ \int_a^x f(t)\, dt $$
$$\int_a^x f(t)\, dt=-\int_0^a f(t)\, dt+\int_0^x f(t)\, dt $$
If we differentiate then since the first integral is independent of $x$ we have
$$\frac{d}{dx} \left(\int_a^x f(t)\, dt \right)=\frac{d}{dx} \left(\int_0^x f(t)\, dt \right)=f(x)$$
The "Leibniz formula", a generalization of the fundamental theorem of calculus, says
[tex]\frac{d}{dx}\int_{\alpha(x)}^{\beta(x)} f(x,t)dt= \frac{d\beta}{dx}f(x, \beta(x))- \frac{d\alpha}{dx}f(x, \alpha(x))+ \int_{\alpha(x)}^{\beta(x)} \frac{\partial f}{\partial x} dt[/tex]
