Integration/Solving A Constant To Divide An Area
  • Thread starter Thread starter Lancelot59
    Area Constant
13 replies · 2K views
Lancelot59
With this particular problem you are given the functions y=x[tex]^{2}[/tex], y=4, and y=b.
The object is to solve for a value of b that will split the area between y=4 and y=x[tex]^{2}[/tex] in half.
[PLAIN]http://www4c.wolframalpha.com/Calculate/MSP/MSP263419aghg2f97i2944e0000580a2hgi735b957c?MSPStoreType=image/gif&s=42&w=399&h=201
The approach I took was to include y=b in the integral, and then subtract the top half from the bottom half and equate that to zero.
[tex]\int_{-2}^{2} {(4-x^2-b)}\ = \int_{-2}^{2} {(b-x^2)}[/tex]
All I did then was solve the integrals, and isolate b to get an answer of 4. However the answer is 4^2/3. I'm also stuck on a similar problem where I need to solve for a constant where two functions have to enclose a specific area.
Your integral for the top half is incorrect. Using the "vertical slices" method, the lower limit on [itex]y[/itex] is [itex]y=b[/itex] when [itex]-\sqrt{b}<x<\sqrt{b}[/itex], and [itex]y=x^2[/itex] when [itex]|x|\geq\sqrt{b}[/itex]. So, you might want to either use horizontal slices for the top half, or not bother computing that integral at all and instead compute the area between [itex]y=x^2[/itex] and [itex]y=4[/itex] and set that equal to twice your bottom half.
Horizontal slices sounds like a better idea. I did come up with the +-root b being the limits, but I decided to go with negative two and two instead...apparently that didn't work. I guess just integrating for one half only works out nicely. Then I can just go from zero to 4.
Okay, so I did it with respect to Y instead:
[tex] \int_{0}^{b} {\sqrt{y}}\ = \int_{0}^{4} {\sqrt{y}}\ - \int_{0}^{b} {\sqrt{y}}[/tex]
then got here:
[tex] [\sqrt{b} - \sqrt{0}] = [\sqrt{4} - \sqrt{0}] - [\sqrt{b} - \sqrt{0}][/tex]
then:
[tex] 2\sqrt{b}= \sqrt{4}[/tex]
[tex] 2\sqrt{b}= 2[/tex]
[tex] b= 1[/tex]
Things aren't going very well.
I found the desired area to be 8/3 (I just chopped it in half and did 0 to 2). Then integrated [tex]\frac{8}{3}=\int_{0}^{\sqrt b} <br /> b-x^2 dx[/tex]
Solved for b...
You mean
[tex]\int_{0}^{\sqrt b}<br /> { [b-x^2]} dx [/tex]
? I'll give it a try.
Yes, My tex skills are a little rusty. i edited it and fixed it..
Mine are horrible. I just figured it out within the last hour to ask this question. :p
Also, that doesn't work. The answer is supposed to be the cube root of 16...I am confused.
set it equal to 8/3! It works!
And the 8/3 is half the parabola from 0 to 2? Attempt # 4ish...
Well, here's what I did:
[tex] \frac{8}{3}=\int_{0}^{\sqrt b} <br /> b-x^2 dx[/tex]
[tex] \frac{8}{3}=[b-{\sqrt b}^2] - [b-{\sqrt 0}^2][/tex]
[tex] \frac{8}{3}= b-b-b[/tex]
[tex] \frac{8}{3}= -b[/tex]
I'm really confused now.
[tex] <br /> \frac{8}{3}=\int_{0}^{\sqrt b} <br /> b-x^2 dx<br /> <br /> =bx-\frac{1}{3}x^3[/tex] from 0 to [tex]\sqrt b[/tex]
I suggest you review basic integration. You're just plugging the numbers into the integrand instead of integrating.
...Fail. I've been doing that a lot recently. I don't know why.
