Integration using Leibnitz theorem
The discussion revolves around proving the integral identity $$\int_{-\pi/2}^{\pi/2}\frac{log(1+b\sin x)}{\sin x}dx=\pi \arcsin(b)$$ for ##|b|\le1## using Leibnitz's theorem. Participants explore the differentiation of the integral with respect to the parameter b, leading to the expression for f'(b) and subsequent integration attempts. Several errors in calculations and misunderstandings about the integration process are identified, particularly regarding the manipulation of trigonometric identities and the correct application of Leibnitz's theorem. Ultimately, the correct result aligns with the textbook answer, confirming that $$f(b)=\pi\sin^{-1}b$$ when the constant of integration is properly accounted for. The discussion highlights the importance of careful mathematical manipulation and verification in solving integral equations.
Titan97
Prove that $$\int_{-\pi/2}^{\pi/2}\frac{log(1+b\sin x)}{\sin x}dx=\pi \arcsin(b)$$
Where ##|b|\le1##
$$\frac{d}{dx}\big(\int_a^bf(t)dt\big)=\int_a^b\frac{\partial f(t)}{\partial x}dx$$
Let $$f(b)=\int_{-\pi/2}^{\pi/2}\frac{log(1+b\sin x)}{\sin x}dx$$
Using Leibnitz theorem, $$f'(b)=\int_{-\pi/2}^{\pi/2}\frac{1}{1+b\sin x}dx$$
Now, ##\sin(x)=\frac{2\tan(x/2)}{1+\tan^2(x/2)}##
After simplifying and substituting ##\tan(x/2)=u##, I got
$$f'(b)=\frac{2}{\sqrt{1-b^2}}\big[\arctan{\frac{\sqrt{1+b}}{\sqrt{1-b}}}+\arctan{\frac{\sqrt{1-b}}{\sqrt{1+b}}}\big]$$
Now, for ##b=0##, its clear that ##f(b)=0##.
So $$f(b)=\frac{2}{\sqrt{1-b^2}}\big[\arctan{\frac{\sqrt{1+b}}{\sqrt{1-b}}}+\arctan{\frac{\sqrt{1-b}}{\sqrt{1+b}}}\big]$$
After putting ##b=\cos\phi## since ##|b|\le 1##, I got ##f(b)=\frac{\pi}{\sin({\arccos(b)})}## which is wrong.
Also, the new ##f(b)## does not satisfy ##f(0)=0##
Is my method correct?
How did you get this:
That's not what I get when I take ##\frac{\partial}{\partial b}## of the integrand in ##f(b)## .
Sorry. Its ##log(1+b\sin x)##. I have edited the question.
You made a mistake.
$$f'(b)=\frac{2}{\sqrt{1-b^2}}\big[\arctan{\frac{\sqrt{1+b}}{\sqrt{1-b}}}+\arctan{\frac{\sqrt{1-b}}{\sqrt{1+b}}}\big] $$
After this is your mistake.
$$ \rightarrow \ f(b)=\frac{2}{\sqrt{1-b^2}}\big[\arctan{\frac{\sqrt{1+b}}{\sqrt{1-b}}}+\arctan{\frac{\sqrt{1-b}}{\sqrt{1+b}}}\big]$$
It is $$f'(b)$$ and NOT $$f(b)$$
Okay I think I started nitpicking, I am sorry. I think you messed up the last Integration part.
$$ \int f'(b) db = \int ((\frac{2}{\sin \phi})\arctan(\tan (\frac{\pi}{2}- \phi) + \arctan (\tan \phi)) \times (-sin \phi) d(\phi)$$
Integrate. Put f(0) = 0.
Likes Titan97
Thank you for pointing out the error. So,
$$f'(cos\phi)=\frac{2}{\sin\phi}\cdot(\arctan\cot\phi-\arctan\tan\phi)=\frac{\pi}{\sin\phi}$$
Integrating ##d(f(\cos\phi))=g(\phi)d\phi##,
$$f(\cos\phi)=\pi\log\tan\frac{\phi}{2}+C$$
$$f(b)=\pi\log\sqrt{\frac{1-b}{1+b}}$$
Now I get a different answer.
Don't put $$\arctan (tan (\frac{\pi}{2} - \phi))$$ as $$(\arctan\cot\phi)$$ I wrote $$\arctan (tan (\frac{\pi}{2} - \phi))$$ deliberately, cause I have some devious plans for it. Apply some manipulation
(like taking out ph...):wink:
When I substituted ##b=cos\phi##, I got ##\arctan\cot\phi## and not ##\arctan\tan(\frac{\pi}{2}-\phi)##
Then ##\arctan x= \frac{\pi}{2}-\cot^{-1}x##.
I see the problem there.
  1. Make a right angled triangle, take an angle as phi.
  2. Since sum of angles of triangle is pi hence the other angle has to be pi/2 - phi.
  3. Find tan of phi is perpendicular upon base [Let's say = AB/BC, ABC is triangle and B is right angle and C is phi].
  4. cot of (pi/2 -phi) is base upon perpendicular [From above we get cot (pi/2-phi) = AB/BC]
  5. From point 3. and 4. we have tan (phi) = cot (pi/2 -phi).
  6. I leave to you to prove cot (phi) = tan (pi/2 -phi).
So even if you are ready to accept point 6 without proving it, you get, the manipulation I did. Can you get the answer from where I left? It is almost done, I am surprised that you did it so far and something so trivial is stopping from getting the answer. I think you should revise some basic trigonometry.
Proof:
##tan\phi=x##
##cot(\frac{\pi}{2}-\phi)=tan\phi=x##
##\frac{\pi}{2}-\phi=\cot^{-1}x##
##\phi=\frac{\pi}{2}-\cot^{-1}x##
##\tan^{-1}x=\frac{\pi}{2}-\cot^{-1}x##
Titan97 said:
Proof:
##tan\phi=x##
Why did you put that proof here? Are you even reading what I am writing? Look I don't understand what are you trying to say. If your confusion is cleared then good, if it is still there, then I am going to ask you to elaborate it, clearly. And by the way why did you put that proof here?
I hope you do know $$\tan^{-1} (cot \phi) = \tan^{-1}(tan (\frac{\pi}{2}-\phi))= \frac{\pi}{2}-\phi$$
This is my confusion:
Umrao said:
∫f′(b)db=∫((2sinϕ)arctan(tan(π2−ϕ)+arctan(tanϕ))×(−sinϕ)d(ϕ)
$$f'(\cos\phi)=\frac{\pi}{\sin\phi}$$
Integrating with respect to ##d\phi## I get wrong answer. But in the quoted message, why did you take ##f'(b)## when the function is ##f'(\cos\phi)##?
Can't you integrate directly?
Finally, deciphered. Yet another mistake in calculation and hopefully this will be my last thread to this post.
Mistake -1. ##f'(cos\phi)=\frac{2}{\sin\phi}\cdot(\arctan\cot\phi-\arctan\tan\phi)=\frac{\pi}{\sin\phi}##. Since R.H.S. is correct so you made a typo on computer here (started nitpicking again, sorry :biggrin:) It is ##f'(cos\phi)=\frac{2}{\sin\phi}\cdot(\arctan\cot\phi+\arctan\tan\phi)=\frac{\pi}{\sin\phi}## Notice the plus sign after tan inverse of cot of phi.
Mistake -2(Actual one)
$$f'(\cos\phi)=\frac{\pi}{\sin\phi}d\phi$$
I was typing while you posted this message but thanks to it I can clearly tell you where you made the mistake, otherwise it was getting very hard to do so with
You can do it with cos as function too
Note: In the quote you have written incorrectly ##f'(\cos\phi)=\frac{\pi}{\sin\phi}d\phi## no ##d\phi##
$$\rightarrow f'(\cos\phi)d(cos\phi)=\frac{\pi}{\sin\phi}d(cos\phi)$$
$$\rightarrow \int f'(\cos\phi)d(cos\phi)= \int \frac{\pi}{\sin\phi}d(cos\phi)$$
$$\rightarrow \int f'(\cos\phi)d(cos\phi)= \int \frac{\pi}{\sin\phi} \times (-\sin\phi)d(\phi)$$
$$\rightarrow f(cos\phi) = -\pi (\phi) +c$$
$$\rightarrow f(b)=-\pi (\cos^{-1}b) +c$$
$$\rightarrow f(b)=-\pi (\frac {\pi}{2} - \sin ^{-1}b) +c$$
$$\rightarrow f(b) =-\frac {\pi^2}{2}+ (\pi\sin^{-1}b) +c$$ and
##f(0)=0##But there is more to it. We both made a common mistake which does not interfere with answer.
We both got $$\arctan cot\phi + \arctan tan\phi$$ It should be $$\arctan cot\frac{\phi}{2} + \arctan tan\frac{\phi}{2}$$.
Though summation remains same but a we will have to accept that we got lucky and in some other place in some other question we will face the consequence if this mistake is not eradicated. We both got to work on it.
I hope I answered your question, so please this question Why were you confused that I wrote $$\arctan cot\phi + \arctan tan\phi = \arctan tan (\frac{\pi}{2} - \phi)+ \arctan tan\phi$$.
And how did you quote me your last reply, you have quoted me entirely wrong. It was 2/sin(##\phi##) not 2sin(##\phi##) same with (##\pi##)/2
Likes Titan97
I wrote ##\phi/2## in notebook. I was typing in early morning just after I woke up. It was basically a communication problem.
The answer given in the textbook however is ##\pi\sin^{-1}b##.
But I know how to solve it now.
Then why did you bother me with all the latex. I wasted 1.5 hours
You could have avoided LaTeX if you wanted to. I never forced you. Besides, the answer is still wrong.
Why don't you tell me where
That's the answer given in the textbook.
Put the damn value of c to get that. f(0) = 0
c = (pi^2)/2
Likes Titan97
  • · Replies 105 ·
