Integration using residue theorem (part 2)
6 replies · 2K views · last reply
MissP.25_5
Hello.
I need some explanation here. I got the solution but I don't understand something.
Question:
Find the integral using Residue Theorem.
$$\int_{-\infty}^{\infty}\frac{dx}{(x^2+4)^2}$$
Here is the first part of the solution that I don't understand:
To evaluate ##\int_{-\infty}^{\infty}\frac{dx}{(x^2+4)^2}##, consider ##\oint_c\frac{dz}{(z^2 + 4)^2}##,
where C consists of the real axis [-R, R] with R > 2, and the upper half of Γ: |z| = R (all with counterclockwise orientation).
My question: Why is R>2?
Where are the singularities of your integrand? Where are the residues relevant for the integral? Why are you allowed to close the contour with the semi circle (and in which limit)?
The singularites are at z=2i and 2i. I think R>2 so that the singularity lies in the semicircle so that residue theorem can be applied. But I don't know why it is allowed to to close the contour with the semi circle. I don't understand why this only involves the upper part of the circle.
Just draw the integration path in the complex [itex]z[/itex] plane. The original integral was along the [itex]x[/itex] axis. Now argue, why you are allowed to add the semi-circle in the upper half-plane when taking [itex]R \rightarrow \infty[/itex], i.e., why do you get the correct value for the original integral!
I am not sure but at some point in the calculation, we're going to let ##R \to \infty## to find the value of ##\int_{-\infty}^\infty \frac{dx}{(x^2 + 4)^2}##. As ##R## increases without bound, ##C## will contain the singularity of ##f## at ##z = 2i##. So that's why we need to choose a R large enough. Why the semicircle in the upper half-plane? I guess because R is going to positive infinity and f(x) is a real number so only the real axis is actually needed. I'm not sure, though. Why do we get the same value as the original integral is because of the residue theorem itself, I guess, but I can't explain why.
Integration by summing the residues inside the path applies only to closed paths. That's the reason you need the semicircle from (R, 0) back to (-R, 0). You could have used other path- say, the line from (R, 0) to (0, R), then to (-R, 0) or the lines from (R, 0) to (R, R) then to (-R, R) then to (-R, 0) but they would be much harder to integrate. If you had used the semicircle in the lower half plane, you would get exactly the same answer.
