Interesting bouyancy theoretical question
The setup involves a 10-pound container of water and a 5-pound floating object suspended by a string. When placed on a scale, the total weight will be 15 pounds plus the weight of the string, as the buoyancy force does not affect the scale's reading. The forces acting on the system are analyzed through free body diagrams, confirming that the scale measures the combined weight of the container, water, and the floating object. The buoyancy force acting on the object is balanced by the tension in the string, ensuring that the scale reflects the total weight accurately. Thus, the scale reads 15 pounds, demonstrating the principles of buoyancy and force equilibrium.
amnestic
Hello, I have a question
Lets say you have a container of water that weighs 10 pounds including the water/container material
and u have a 5 pound object that can float quite easily in that water
and u attach a piece of string to that object to the bottom of the container of water to the halfway point so that the object is suspended in the water at the midway point
Now if you were to put this contraption on a scale, will it weigh 15 pounds plus the weight of the string
or will it be between 10 to 15 pounds due to the bouyancy force upwards on the object
ENGAGE!
It would weigh 15 pounds plus the weight of the string. The bouyancy force is not acting on the scale.
Let's say that the string has negligible mass and displaces a negligible volume water, the float weighs 5 pounds and a volume equal to 6 pounds of water, the water weighs 9 pounds, and the container weighs 1 pound.
A free body diagram of the float shows that the tension in the string (1 lb down) is equal to the force of the water on the float (6 lb up) minus the weight of the float (5 lb down). A free body diagram of the water shows that the force of the container on the water (15 lb up) is equal to the weight of the water (9 lb down) plus the force of the float on the water (6 lb down). A free body diagram of the container shows that the force of the scale on the container (15 lb up) is equal to the force of the water on the container (15 lb down) plus the weight of the container (1 lb down) minus the tension in the string (1 lb up). A free body diagram of the scale shows that the force of the container on the scale is 15 lb up.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
