Mubeen
- 8
- TL;DR
- ultra short pulse
what will happen if two one femtosecond(1 fs) laser pulse interferes?
The discussion centers on the interference of two femtosecond (1 fs) laser pulses. Participants agree that interference will occur, but the resulting fringe pattern will be complex and transient due to the short duration of the pulses. Key factors include the mutual coherence of the pulses and their relative amplitudes, which affect the visibility and depth of the fringes. Techniques such as frequency-resolved optical gating are relevant for analyzing pulse duration and shape in this context.
PREREQUISITESOptical physicists, laser engineers, and researchers in ultrafast optics seeking to understand the complexities of laser pulse interference and its practical implications.
This is a very complicated question, actually. There's a lot going on with the "internal" coherence of the pulse itself, and unless you know the mutual coherence between the pulses, it's impossible to analyze.Mubeen said:TL;DR Summary: ultra short pulse
A simple case of 'not too short' pulses will only produce a pattern when the arrivals are near coincident and the depth of the fringes will depend on the relative amplitudes of the pulses over time. On boresight and coincident timing, the fringes should be deep but for other angles, the relative amplitudes will be different over time (because of the pulse delay in addition to the simple carrier phase effect). This is the same sort of effect that you get with Young's slits where the sources are finite widths and not omnidirectional and the fringes get weaker off axis.Mubeen said:iam curious to know whether the fringes will have good contrast?.
This seems to be approximately one cycle of light. So, for Young's Slits for example, I would expect to see the bright central band but no other fringes. This is because if a diffracted path has a delay of one wavelength there is nothing there - it is after the pulse. In addition, the screen will be dimly illuminated by the diffracted light from the two slits, but interference will not occur due to the time difference being too great.Mubeen said:TL;DR Summary: ultra short pulse
IS the process just simple multiplication? The modulation envelope varies with time so it's not just loke multiplying the element pattern by the array pattern. It's a transitory phenomenon.tech99 said:multiplied by the modulation envelope
Can you back up that verbal description with some maths that contains x,y and t? It's true that only in one place and one time are the E fields equal in amplitude and phase but what happens at other times and in other directions. I think the problem with non-continuous waves is that the concept of simple interference could be actually misleading.tech99 said:One ray is progressively delayed as we move from the centre line, so it is sweeping in time across the modulation envelope. The other ray is progressively advanced, so sweeps the other way in time. We then have interference between these two. So if there is just one pulse having a length of one cycle, that is all we see.
In fact, the 'pattern' would not be stationary, which is what happens with a conventional Young's slits pattern at switch on and switch off.sophiecentaur said:that the concept of simple interference could be actually misleading.
