Solve Ellipsoid Problem: Integrate cos(theta)*sqrt[cos^2(theta) - (x^2/a^2)]
  • Thread starter Thread starter Yura
    Intergration
The discussion revolves around integrating the equation cos(theta)*sqrt[cos^2(theta) - (x^2)/(a^2)] with respect to d(theta). A participant suggests that integration by parts may not be necessary and recommends using substitution instead, specifically replacing cos^2(theta) with 1 - sin^2(theta) and letting v = sin(theta). The original poster expresses frustration with their attempts at integration by parts, finding it increasingly complex. They seek clarification on whether their approach is correct and which values to assign for u and v' in integration by parts. The conversation highlights the importance of substitution methods in solving the integration problem effectively.
Yura
someone asked the ellipsiod problem before and i didnt under stand anythign in the repsonces >< but i had already gotten this far that my equation (simplified) is
i need to integrate this equation with respect to d(theta)
or even just this part: sqrt[cos^2(theta) - (x^2)/(a^2)]
(if intergration by parts is required)
i tried using by parts but i ended up with a lot of numbers getting more and more complex
i at least need to know if by using integration by parts is heading in the right direction for this
and if it is, then which values do i set for the v' and u?
i've tried both ways but neither seems to be gettig me anywhere, I've had to do so many different intergrations by part for each because there are more within each one.
or is there some rule that i should be using to solve for this intergration?
thanks in advance
I cannot imagine why integration by parts would be required- it's an easy substitution: replace cos^2(theta) with 1- sin^2(theta) and then let v= sin(theta)
thanks in advance
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 22 ·
