Intermediate Math Challenge - May 2018
61 replies · 14K views
I will try Problem 4
I succeeded in solving it with brute force with Mathematica, but I will do an alternative that does not require bignums. That alternative was inspired by the Fibonacci series, and how member n of it can be expressed as a1*b1n + a2*b2n. So I seek a recurrence that has an exponential solution with a factor of ##\sqrt{3}+1## in it. That quantity solves equation ##x^2 - 2x - 2##, and it gives us the recurrence ##x(n) = 2x(n-1) + 2x(n-2)##. For x(0) = 2 and x(1) = 2, ##x(n) = (\sqrt{3}+1)^n + (-\sqrt{3}+1)^n##. However, that recurrence guarantees that x(n) will be an integer for all nonnegative integer n.
So, ##(\sqrt{3}+1)^{5000} = x(5000) - (-\sqrt{3}+1)^{5000}##. That final term is approximately ##5.08 \cdot 10^{-678}##, and that makes the first 677 digits after the decimal point all 9's. Thus, the 100th digit after the decimal point is 9.
I actually had Fibonacci in the back of my head when putting the question in. Well done.
A lot of problems can be solved if you find the right pairing.
edit:
It may be worth pointing out that the magnitude of the second term is so small that the problem can actually be done without a calculator.
You know that that ##1.5 ^2 = 2.25 \lt \big(\sqrt{3}\big)^2## but you also know that
##\big(\sqrt{3}\big)^2 = 3 =\frac{48}{16} \lt \frac{49}{16} \to \sqrt{3} \lt \frac{7}{4}##, telling you that ##\big \vert 1 - \sqrt{3}\big \vert \lt \frac{3}{4}##, and after raising to an even exponent of course the result is positive.
But the trick to the problem was finding the pairing.
I'll take a stab at solving problem 5.
The first thing I do is to find the commutators of the Dn's. For convenience, I will redefine them by doing Dn = old Dn+1 -- ##D_n = x^{n+1} \frac{d}{dx}##.
Combining the operators,
$$ D_m(D_n(f(x))) = D_m( x^{n+1} f'(x) ) = x^{m+n+2} f''(x) + (n+1) x^{m+n+1} f'(x) $$
Thus, the commutator ##[D_m,D_n] = (n-m)D_{n+n}##.
This I recognize as the Virasoro algebra.
I now consider what finite subalgebras are possible. From the commutators I deduce some constraints.
  • The zero operator, D0, does not affect the presence or absence of any other operators.
  • If two operators are positive, Dm and Dn with m and n > 0, then their commutator contains an operator Dm+n with a higher arg value. Repeating the commutation with this new operator gives another one with even higher arg value. Thus, if more than one operator is positive, there are thus an infinite number of positive operators.
  • The same argument shows that if two operators are negative, Dm and Dn with m and n < 0, then they generate an infinite number of negative operators.
  • So there is at most one positive operator and at most one negative operator.
  • Their commutator must be a multiple of the zero operator, or else they will make more than one positive or negative operator.
Thus, the possible finite subalgebras of this algebra are
  • One element: Dn for any n.
  • Two elements: D0 and Dn for any nonzero n.
  • Three elements: Dn, D-n, and D0 for any nonzero n.
The three-element one's commutators:
## [D_0, D_n] = n D_n ##
## [D_0, D_{-n}] = - n D_{-n} ##
## [D_{-n}, D_n] = 2n D_0 ##
These can be combined into
## [D_0, D_n+D_{-n}] = n (D_n - D_{-n}) ##
## [D_n-D_{-n},D_0] = - n (D_n + D_{-n}) ##
## [D_n+D_{-n}, D_n-D_{-n}] = 4n D_0 ##
The pattern of signs points to the algebra SO(2,1).
So the possible finite subalgebras are the one-element ones, the nontrivial two-element ones, and the three-element SO(2,1).
I had realized that
\frac{1}{2} (\sum_{m=0}^{5000} \frac{5000!}{m! (5000-m)!} 3^{m/2} + \sum_{m=0}^{5000} (-1)^m \frac{5000!}{m! (5000-m)!} 3^{m/2} ) = \frac{1}{2} ((1 + \sqrt{3})^{5000} + (1 - \sqrt{3})^{5000} )
would give a part that was purely an integer, but I didn't make the next steps.
QuantumQuest said:
Well done. There is also another very nice way to solve it but I won't say anything more right now, as there maybe people that want to tackle it another way;)
That is literally the exact same solution I gave... No problem though. Cheers!
As we have a solution already, a hint:
A few lines with complex numbers
Yep
\frac{(2n-1)^2 (2n-3)^2 \dots 1^2}{(2n)!} = \frac{(2n-1)^2 (2n-3)^2 \dots 1^2}{(2n) (2n-1) (2n-2) (2n-3) \dots} = \frac{(2n-1) (2n-3) \dots}{2n (2n-2) \dots} = \frac{(2n-1) (2n-3) \dots}{2^n n!}
= \frac{2n (2n-1) (2n-2) (2n-3) \dots}{2^n 2n (2n-2) \dots n!} = \frac{(2n)!}{2^{2n} (n!)^2}
So I think honours go to Biker.
This is correct, well done.
However, the three-dimensional case is commonly noted as the simple Lie algebra of type ##A_1##, i.e. ##\mathfrak{sl}_2 \cong \mathfrak{su}_2##. The two-dimensional case is its Borel subalgebra, the maximal solvable subalgebra. It is the only non Abelian of dimension two. The one-dimensional is obviously Abelian. These are the only differential structures on the real line, if I remember it correctly. By the way, its the Witt algebra, Virasoro algebras are central extensions of Witt.
Correct me, if I'm wrong, but as I could see, you gave the result without the way how to achieve it.
I gave the way in a spoiler, But I don't really care. As long my answer was correct. The pleasure of solving it is enough.
Sorry but where exactly is this solution? You just told me under spoiler in your post #19 just one headline of what you did. Also you had asked me for an answer which was not the final answer. Why didn't you post your full solution as lpetrich did?
Sorry, but I searched twice now for problem #6, and all I could find is post #14 with a result, not a way to the result. To be precise, it wasn't even a result, just a question. Anyway, there will be more questions. (And all of you are still invited to PM me good problems. Mine seem to be to easy for you :wink:.)
The problems don't really need to show steps, If you know what to do then the rest is trivial.
I gave a solution which was the "final" solution for me, and a lot of alternative forms of the solution exist. I also said that the method is just recursive integration, and that the integration simplifies itself (last term) with the boundaries of the integral.
I really liked the problem though because it was the first time for me at least to make a recursive law in integration and i was quite happy when I noticed it, So thank you for the question.
If you solve a problem for yourself i.e. doing your own study you can do it any way you wish. But in the context of a challenge there are rules and for good reason. So, rules also apply for our challenges here. If you haven't already done so then please take a look at the rules.
It is always good for all of us to learn so you're welcome. I think that it would be even more constructive to try to come up with a different way. A different solution - when we say different we mean it, deserves also credit no matter if the problem has already been solved in one way. So, if you want try a different approach but remember that here only full solutions (i.e. including all steps) are credited.
The 3D Lie algebra A1 is something of a degenerate case. For real parameters,
so(3) ~ su(2) ~ sp(2) (or usp(2))
so(2,1) ~ su(1,1) ~ sp(2,R) ~ sl(2,R)
They are related by analytic continuation.
If you've ever worked with quantum-mechanical angular momentum, you've worked with this algebra.
What do you mean by degenerate? A term I would avoid by all means in the context of semisimple Lie algebras, as they can be defined by exactly the non-degeneracy of their Killing-forms. This adjective is highly confusing if used as you did.
The three dimensional ##\mathfrak{sl}(2)## is so to say the prototype of a simple Lie Algebra, one dimension of all what's needed. As there is only one, I've never really cared about the various realizations and ##\mathfrak{sl}(2)## is easiest to handle, although ##\mathfrak{su}_\mathbb{R}(2,\mathbb{C})## is the physics version of it.
"Degenerate" in the sense of "degeneracy" in quantum mechanics -- several algebra-family members looking alike.
fresh_42 said:
That's correct, although you could have made life much easier for an old man. I don't know all the trig formulas in mind anymore. And to demonstrate the integration by parts would have been a nice service for the younger among us. However, the argument with the odd function was nice, so I'll not complain about the wrong round-off of the result, although an exact solution would have been better:
\int_{-1}^0 \,x \cdot \sqrt{x^2+x+1} \,dx = -\frac{1}{4} - \frac{3}{16} \log 3 \approx -0.45598980\ldots \approx -0.456
I got this result using the substitution ##u=x +1/2## and the entries in a table of integrals for $$\int_\frac{-1}{2}^\frac{1}{2}u\sqrt{u^2 + \frac{3}{4}}du -\frac{1}{2}\int_\frac{-1}{2}^\frac{1}{2}\sqrt{u^2 + \frac{3}{4}}du$$
Hello QuantumQuest. You said there is a nice way to do problem 6. Did you mean this:
First write
I = \int_0^\pi \sin^{2n} \theta d \theta = \frac{1}{2} \int_{-\pi}^\pi \sin^{2n} \theta d \theta
where we have used that ##\sin^{2n} \theta## is an even function in ##\theta##. This can then be converted into a contour integral around the unit circle by the change of variables
z = e^{i \theta} \qquad dz = i e^{i \theta} d \theta
and writing
\sin \theta = \frac{1}{2i} \Big( z - \frac{1}{z} \Big)
so that
\begin{align}
I & = \frac{1}{2} \oint \Big[ \frac{1}{2i} \Big( z - \frac{1}{z} \Big) \Big]^{2n} \frac{dz}{iz}
\nonumber \\
& = \frac{1}{2i} \frac{(-1)^n}{2^{2n}} \oint \Big( z - \frac{1}{z} \Big)^{2n} \frac{dz}{z}
\nonumber
\end{align}
This countour integral is easily solved by finding the coefficient of ##\frac{1}{z}## using the binomial expansion:
\begin{align}
I & =
\frac{1}{2i} \frac{(-1)^n}{2^{2n}} \oint \Big( \cdots +
\begin{pmatrix}
2n \\ n
\end{pmatrix}
z^n \Big( - \frac{1}{z} \Big)^n + \cdots \Big) \frac{dz}{z}
\nonumber \\
& = \frac{1}{2i} \frac{(-1)^n}{2^{2n}} \oint \Big( \cdots + \frac{(-1)^n (2n)!}{(n!)^2} + \cdots \Big) \frac{dz}{z}
\nonumber \\
& = \frac{1}{2i} \frac{(-1)^n}{2^{2n}} \times 2 \pi i \frac{(-1)^n (2n)!}{(n!)^2}
\nonumber \\
& = \frac{(2n)!}{2^{2n} (n!)^2} \pi
\nonumber
\end{align}
First day open to all. Open:
1.) Determinants.
7.) Series.
9.) Jacobi Identity.
10.) Integral.
Is the solution of problem 10 this:
By the residue theorem:
I = 2 \pi i \lim_{z \rightarrow 0} e^{kz} = 2 \pi i .
Then by the change of variables
The integral becomes
\begin{align}
I & = \int_{- \pi}^\pi e^{k e^{i \theta}} \frac{i e^{i \theta} d \theta}{e^{i \theta}}
\nonumber \\
& = i \int_{- \pi}^\pi e^{k \cos \theta + i k \sin \theta} d \theta
\nonumber \\
& = i \int_{- \pi}^\pi e^{k \cos \theta} e^{i k \sin \theta} d \theta
\nonumber \\
& = i \int_{- \pi}^\pi e^{k \cos \theta} [ \cos (k \sin \theta) + i \sin (k \sin \theta) ] d \theta
\nonumber
\end{align}
Using that ##\sin (k \sin \theta)## is an odd function in ##\theta##, we have
I = i \int_{- \pi}^\pi e^{k \cos \theta} \cos (k \sin \theta) d \theta .
Comparing this to the first answer we got for ##I##, we have
\int_{- \pi}^\pi e^{k \cos \theta} \cos (k \sin \theta) d \theta = 2 \pi .
I think I have solved problem 7.
I used the generating function technique. Define
f (x) = \sum_{n=1}^\infty \frac{(n!)^2}{n (2n)!} x^n = \sum_{n=1}^\infty a_n x^n
The sum we are after will then be equal to ##f (1)##.
Note that
a_{n+1} = \frac{(n!)^2}{n (2n)!} \times \frac{n (n+1)^2}{(n+1) (2n+2) (2n+1)} = a_n \times \frac{n}{2 (2n +1)}
or ##2 (2n+1) a_{n+1} = n a_n##. In the following we use ##a_1 = 1/2##. First
\begin{align}
x \frac{d}{dx} f (x) & = \sum_{n=1}^\infty n a_n x^n
\nonumber \\
& = \sum_{n=1}^\infty 2 (2n+1) a_{n+1} x^n
\nonumber
\end{align}
Then
\begin{align}
x^2 \frac{d}{dx} f (x) & = \sum_{n=1}^\infty 2 (2n+1) a_{n+1} x^{n+1}
\nonumber \\
& = 2 \sum_{m=2}^\infty (2m -1) a_m x^m
\nonumber \\
& = 2 \sum_{m=1}^\infty (2m -1) a_m x^m - 2 (2 \times 1 - 1) a_{1} x
\nonumber \\
& = 4 \sum_{m=1}^\infty m a_m x^m - 2 f (x) - x
\nonumber \\
& = 4 x \frac{d}{dx} f (x) - 2 f (x) - x
\nonumber
\end{align}
This gives the differential equation:
(x^2 - 4x) \frac{d}{dx} f (x) + 2f (x) + x = 0
or
\frac{d}{dx} f (x) + \frac{2}{x^2 - 4x} f (x) = - \frac{1}{x - 4} .
(with boundary condition ##f (0) = 0##). Now this is the famililar form
\frac{d}{dx} f (x) + p (x) f (x) = q (x)
that can be solved using the integrating factor method which uses
\begin{align}
\frac{d}{dx} \Big[ e^{\nu (x)} f (x) \Big] & = e^{\nu (x)} \Big[ \frac{d}{dx} f (x) + p (x) f (x) \Big]
\nonumber \\
& = e^{\nu (x)} q (x)
\nonumber
\end{align}
where ##\nu (x) = \int p (x) dx##. We will solve this with
f (x) = e^{- \nu (x)} \int e^{\nu (x)} q(x) dx .
In our case
p (x) = - \frac{1}{2} \Big( \frac{1}{x} - \frac{1}{x-4} \Big) , \qquad q (x) = - \frac{1}{x-4}
so that
\begin{align}
\nu (x) & = - \frac{1}{2} \int \Big( \frac{1}{x} - \frac{1}{x - 4} \Big) dx
\nonumber \\
& = - \frac{1}{2} ( \ln x - \ln (x-4))
\nonumber
\end{align}
meaning
e^{+ \nu (x)} = \frac{(x-4)^{1/2}}{x^{1/2}} \qquad \mathrm{and} \qquad e^{- \nu (x)} = \frac{x^{1/2}}{(x-4)^{1/2}}
and
\begin{align}
f (x) & = - \frac{x^{1/2}}{(x-4)^{1/2}} \int_0^x \frac{(x-4)^{1/2}}{x^{1/2}} \frac{1}{x-4} dx
\nonumber \\
& = i \frac{x^{1/2}}{(4-x)^{1/2}} \int_0^x \frac{dx}{(x^2 - 4x)^{1/2}} dx
\nonumber
\end{align}
(choosing the lower limit to be ##0## will ensure that ##f (0) = 0##). We now take ##x = 1##, then
\begin{align}
\sum_{n=1}^\infty \frac{(n!)^2}{n (2n)!} & = f (1)
\nonumber \\
& = i \frac{1}{\sqrt{3}} \int_0^1 \frac{dx}{(x^2 - 4 x)^{1/2}}
\nonumber
\end{align}
We evaluate the above integral. Write ##x^2 - 4 x = [x - 2]^2 - 4##. Then with the substitution ##u = x - 2## we obtain
\begin{align}
\int_0^1 \frac{dx}{(x^2 - 4 x)^{1/2}} & = \int_{-2}^{-1} \frac{du}{(u^2 - 2^2)^{1/2}}
\nonumber \\
& = \Big[ \cosh^{-1} (u/2) \Big]_{-2}^{-1}
\nonumber \\
& = \cosh^{-1} (-1/2) - \cosh^{-1} (-1) .
\nonumber
\end{align}
Using the formula ##\cosh^{-1} x = \ln [x + \sqrt{x+1} \sqrt{x-1}]##, we have
\begin{align}
\cosh^{-1} (-1/2) - \cosh^{-1} (-1) & = \ln [-1/2 + i \sqrt{3}/2] - \ln (-1)
\nonumber\\
& = i \frac{2}{3} \pi - i \pi
\nonumber\\
& = - i \frac{1}{3} \pi
\nonumber
\end{align}
Accordingly
\begin{align}
\sum_{n=1}^\infty \frac{(n!)^2}{n (2n)!} & = i \frac{1}{\sqrt{3}} \times -i \frac{\pi}{3}
\nonumber \\
& = \frac{\pi}{3 \sqrt{3}} .
\nonumber
\end{align}
Wow! It looks good at first glance, i.e. the result is correct and I couldn't find flaws. There is a simpler solution using a known series expansion, but this one is really good.
Thanks fresh_42. A thing that needs to be checked is if we are allowed to differentiate the series term by term. This is easy to establish.
There is the theorem:
The derivative of the series sum ##f (x) = \sum_i^\infty u_n (x)## equals the sum of the individual term derivatives,
\frac{d}{dx} f (x) = \sum_{n=1}^\infty \frac{d}{dx} u_n (x) ,
provided the following conditions hold:
u_n (x) \quad \mathrm{and} \quad \frac{d u_n (x)}{dx} \quad \mathrm{are \; continuous \; in} \; [a,b]
\sum_{n=1}^\infty \frac{d u_n (x)}{dx} \quad \mathrm{is \; uniformally \; convergent \; in} \; [a,b] .
In our case it is obvious that ##u_n (x) = a_n x^n## and ##\frac{u_n (x)}{dx} = n a_n x^{n-1}## are continuous in ##[0,1]##. So we just have to check that ##\sum_{n=1}^\infty \frac{d u_n (x)}{dx}## is uniformally convergent.
We can do this using the Weierstrass M test. This states that if we can construct a series of numbers ##\sum_1^\infty M_n##, in which ##M_n \geq |v_n (x)|## for all ##x \in [a,b]## and ##\sum_1^\infty M_n## is convergent, the series ##\sum_1^\infty v_n (x)## will be uniformally convergent in ##[a,b]##.
In our case an obvious candidate for the ##M_n##'s are ##n a_n = \frac{(n!)^2}{(2n)!}##. The ratio test tells you the series ##\sum_1^\infty M_n## is convergent:
\lim_{n \rightarrow \infty} \frac{(n+1) a_{n+1}}{n a_n} = \lim_{n \rightarrow \infty} \frac{(n+1)^2}{(2n+2) (2n+1)} = \frac{1}{4} < 1 .
We then just need to note that
M_n = n a_n \geq |n a_n x^{n-1}| = \Big| \frac{d u_n (x)}{dx} \Big| \quad \mathrm{for \; all} \;\; x \in [0,1] .
##Also, it might have been "nicer" to write
f (x) = \frac{x^{1/2}}{(4-x)^{1/2}} \int_0^x \frac{dx}{(4 - x^2)^{1/2}}
and
\begin{align}
f (1) & = \frac{1}{\sqrt{3}} \int_0^1 \frac{dx}{(4x - x^2)^{1/2}}
\nonumber \\
& = \frac{1}{\sqrt{3}} \int_0^1 \frac{dx}{[2^2 - (x - 2)^2]^{1/2}}
\nonumber \\
& = \frac{1}{\sqrt{3}} \int_{-2}^{-1}\frac{du}{[2^2 - u^2]^{1/2}}
\nonumber \\
& = \frac{1}{\sqrt{3}} \Big[ \sin^{-1} (u/2) \Big]_{-2}^{-1}
\nonumber \\
& = \frac{1}{\sqrt{3}} \Big( \sin^{-1} (1) - \sin^{-1} (1/2) \Big)
\nonumber \\
& = \frac{1}{\sqrt{3}} \Big( \frac{\pi}{2} - \frac{\pi}{6} \Big)
\nonumber \\
\nonumber
\end{align}
but it is equivalent.
I think I have solved problem 1:
I split the proof into the parts:
Part (a) A few facts about real skew symmetric matrices.
Part (b): Proof for ##n## even.
(i) Looking at case ##n = 2##.
(ii) Proving a key inequality. This will prove case ##n=2##
(iii) Proving case for general even ##n## (then easy).
Part (c) Case of odd ##n##.
(i) Proving case for ##n = 3## (easy because of part (b)).
(iii) Proving case for general odd ##n## (easy because of part (b)).
Part (a):
Few facts about real skew matrices:
They are normal: ##A A^\dagger = A A^T = -A A = A^T A = A^\dagger A## and so the spectral theorem holds. There is a unitary matrix ##U## such that ##U^\dagger A U = D## where ##D## is a diagonal matrix. The entries of the diagonal of ##D## are the eigenvalues of ##A##.
The eigenvalues are pure imaginary.
As the coefficients of the characteristic polynomial, ##\det (A - \lambda I) = 0##, are real the eigenvalues come in conjugate pairs. If the dimension, ##n##, of the matrix ##A## is odd then 0 must be one of the eigenvalues.
Part (b) (i):
We first take the simplest case of even ##n##: ##n = 2##. We can write
U^\dagger A U = D =
\begin{pmatrix}
\lambda & 0 \\
0 & - \lambda
\end{pmatrix} .
First consider
\begin{align}
& \prod_{i=1}^k \det \big( A + x_i I \big) =
\nonumber \\
& = \det \big[ \big( A + x_1 I \big) \big( A + x_2 I \big) \dots \big( A + x_k I \big) \big]
\nonumber \\
& = \det \big[ U^{-1} \big( A + x_1 I \big) U U^{-1} \big( A + x_2 I \big) U U^{-1} \dots U U^{-1} \big( A + x_k
I \big) U \big]
\nonumber \\
& = \det \Big[
\begin{pmatrix}
\lambda + x_1 & 0 \\
0 & - \lambda + x_1
\end{pmatrix}
\begin{pmatrix}
\lambda + x_2 & 0 \\
0 & - \lambda + x_2
\end{pmatrix}
\dots
\begin{pmatrix}
\lambda + x_k & 0 \\
0 & - \lambda + x_k
\end{pmatrix}
\Big]
\nonumber \\
& = \det
\nonumber \\
\begin{pmatrix}
(\lambda + x_1) (\lambda + x_2) \dots (\lambda + x_k) & 0 \\
0 & (- \lambda + x_1) (- \lambda + x_2) \dots (- \lambda + x_k)
\end{pmatrix}
\nonumber \\
& = (- \lambda^2 + x_1^2) (- \lambda^2 + x_2^2) \dots (- \lambda^2 + x_k^2)
\nonumber \\
& = (\theta^2 + x_1^2) (\theta^2 + x_2^2) \dots (\theta^2 + x_k^2) \qquad \qquad \qquad \qquad \qquad \qquad (1)
\nonumber
\end{align}
where we have introduced ##\lambda = i \theta## where ##\theta## is real.
Now consider
\begin{align}
& \det \Big( A + (\prod_{i=1}^k x_i)^{1/k} I \Big) =
\nonumber \\
\det \Big[
\begin{pmatrix}
\lambda + (x_1 x_2 \dots x_k)^{1/k} & 0 \\
0 & - \lambda + (x_1 x_2 \dots x_k)^{1/k}
\end{pmatrix}^k
\Big]
\nonumber \\
& = \det \Big[
\begin{pmatrix}
\end{pmatrix}
\Big]^k
\nonumber \\
& = \big[ - \lambda^2 + (x_1^2 x_2^2 \dots x_k^2)^{1/k} \big]^k
\nonumber \\
&= \big[ \theta^2 + (x_1^2 x_2^2 \dots x_k^2)^{1/k} \big]^k
\qquad \qquad (2)
\nonumber
\end{align}
Comparing eq (1) and eq (2), we see that proving the main result for ##n = 2## then amounts to proving the inequality:
(\theta^2 + x_1^2) \dots (\theta^2 + x_k^2) \geq [\theta^2 + (x_1^2 \dots x_k^2)^{1/k}]^k
\qquad \qquad \qquad \qquad (3)
We prove this, for general value of ##\theta##, in the next subsection. See next spoiler!
Part (b) (ii):
We wish to prove (3):
The proof is an essentially inductive argument. Our base case ##k = 2## is easy:
\begin{align}
(\theta^2 + x_1^2) (\theta^2 + x_2^2) & = \theta^4 + \theta^2 x_1^2 + \theta^2 x_2^2 + x_1^2 x_2^2
\nonumber \\
& \geq \theta^4 + 2 \theta^2 (x_1 x_2) + x_1^2 x_2^2
\nonumber \\
& = [\theta^2 + (x_1^2 x_2^2)^{1/2}]^2
\nonumber
\end{align}
where we used ##a^2 + b^2 \geq 2 ab##.
Next we prove that whenever the result holds for ##k##, it holds for ##2k## as well. That is, we'll first prove the result for powers of ##2: k = 2, 4, 8, 16, \dots##. Assume we know the result holds for some ##k##. Now consider ##2k## positive numbers ##x_1^2, \dots , x_k^2## and ##y_1^k , \dots y_k^2##. We use the induction hypothesis and the base case to find
\begin{align}
& (\theta^2 + x_1^2) \dots (\theta^2 + x_k^2) (\theta^2 + y_1^2) \dots (\theta^2 + y_k^2)
\nonumber \\
& \geq [\theta^2 + (x_1^2 \dots x_k^2)^{1/k}]^k [\theta^2 + (y_1^2 \dots y_k^2)^{1/k}]^k
\nonumber \\
& = [\theta^4 + \theta^2 (x_1^2 \dots x_k^2)^{1/k} + \theta^2 (y_1^2 \dots y_k^2)^{1/k} + (x_1^2 \dots x_k^2
\nonumber \\
& \geq [\theta^4 + 2 \theta^2 (x_1^2 \dots x_k^2 y_1^2 \dots y_k^2)^{1/2k} + (x_1^2 \dots x_k^2
\nonumber \\
& = [\theta^2 + (x_1^2 \dots x_k^2 y_1^2 \dots y_k^2)^{1/2k}]^{2k}
\nonumber
\end{align}
where we used ##a^2 + b^2 \geq 2 ab##. This is the required result. We now know the theorem to be true for infinitely many ##k##.
Next we prove that whenever the result is true for ##k##, it's also true for ##k - 1##. This will prove the result for all the in-between integers. Let ##k \geq 4## and assume the result holds for ##k##. Consider the ##k-1## positive numbers ##x_1^2 , x_2^2 , \dots , x_{k-1}^2##. Define ##x_k^2## to be ##(x_1^2 x_2^2 \dots x_{k-1}^2)^{1/(k-1)}##. We then have
\begin{align}
& (\theta^2 + x_1^2) (\theta^2 + x_2^2) \dots (\theta^2 + x_{k-1}^2) (\theta^2 + x_k^2)
\nonumber \\
& \geq [\theta^2 + (x_1^2 \dots x_{k-1}^2 x_k^2)^{1/k} ]^k
\nonumber \\
& = [\theta^2 + \{ (x_1^2 \dots x_{k-1}^2)^{1/(k-1)} \}^{(k-1)/k} \; (x_k^2)^{1/k} ]^k
\nonumber \\
& = [\theta^2 + \big( x_k^2 \big)^{(k-1)/k} \; (x_k^2)^{1/k} ]^k
\nonumber \\
& = [\theta^2 + x_k^2]^k
\nonumber
\end{align}
Rearranging we have
\begin{align}
& (\theta^2 + x_1^2) (\theta^2 + x_2^2) \dots (\theta^2 + x_{k-1}^2) \geq [\theta^2 + x_k^2]^{k-1}
\nonumber \\
& \qquad \equiv [\theta^2 + (x_1^2 x_2^2 \dots x_{k-1}^2)^{1 / (k-1)} ]^{k-1}
\nonumber
\end{align}
which is the required result.
Which means we have established (3) and proven the main result for ##n = 2##, i.e.,
\prod_{i=1}^k \det \big( A + x_i I \big) \geq \det \Big( A + (\prod_{i=1}^k x_i)^{1/k} I \Big) \qquad n = 2 .
We will prove the main result for arbitrary even ##n## in the next subsection. See next spoiler!
Part (b) (iii):
We now prove the main result for general even ##n##. We can write
U^\dagger A U = D =
\begin{pmatrix}
\lambda_1 & 0 & 0 & 0 & \dots & \dots & 0 & 0 \\
0 & - \lambda_1 & 0 & 0& \dots & \dots & 0 & 0 \\
0 & 0 & \lambda_2 & 0& \dots & \dots & 0 & 0 \\
0 & 0 & 0 & - \lambda_2& \dots & \dots & 0 & 0 \\
\vdots & \vdots & \vdots & \vdots & \ddots & \vdots & \vdots & \vdots \\
\vdots & \vdots & \vdots & \vdots & \dots & \ddots & \vdots & \vdots \\
0 & 0 & 0 & 0 & \dots & \dots & \lambda_{n/2} & 0 \\
0 & 0 & 0 & 0 & \dots & \dots & 0 & - \lambda_{n/2} \\
\end{pmatrix} .
So that
\begin{align}
& \prod_{i=1}^k \det (A - x_i I)
\nonumber \\
& = \prod_{i=1}^k \det
\nonumber \\
\begin{pmatrix}
\lambda_1 + x_i & 0 & \dots & \dots & 0 & 0 \\
0 & - \lambda_1 + x_i & \dots & \dots & 0 & 0 \\
0 & 0 & \dots & \dots & \lambda_{n/2} + x_i & 0 \\
0 & 0 & \dots & \dots & 0 & - \lambda_{n/2} + x_i \\
\end{pmatrix}
\nonumber \\
\Big( \prod_{i=1}^k
\det
\begin{pmatrix}
\lambda_1 + x_i & 0 \\
\end{pmatrix} \Big)
\dots
\Big( \prod_{i=1}^k
\begin{pmatrix}
\end{pmatrix} \Big)
\nonumber \\
& = \big( \prod_{i=1}^k (\theta_1^2 + x_i^2) \big) \dots \big( \prod_{i=1}^k(\theta_{n/2}^2 + x_i^2) \big)
\nonumber
\end{align}
where we have introduced ##\lambda_l = i \theta_l## where ##\theta_l## is real..
Next consider
\qquad \det \Big( A + (\prod_{i=1}^k x_i)^{1/k} I \Big)^k
\quad = \det
\begin{pmatrix}
\lambda_1 + (x_1 \dots x_k)^{\frac{1}{k}} & 0 & \dots & \dots \\
0 & - \lambda_1 + (x_1 \dots x_k)^{\frac{1}{k}} & \dots & \dots \\
\vdots & \vdots & \ddots & \vdots \\
\end{pmatrix}^k
\quad = \prod_{l=1}^{n/2} \det
\Big[
\begin{pmatrix}
\lambda_l + (x_1 x_2 \dots x_k)^{1/k} & 0 \\
0 & - \lambda_l + (x_1 x_2 \dots x_k)^{1/k}
\end{pmatrix}^k
\Big]
\quad = \big[ \theta_1^2 + ( x_1^2 x_2^2 \dots x_k^2 )^{1/k} \big]^k
\dots
\big[ \theta_{n/2}^2 + ( x_1^2 x_2^2 \dots x_k^2)^{1/k} \big]^k
We easily have from (3) that
\begin{align}
& \big( \prod_{i=1}^k (\theta_1^2 + x_i^2) \big)
\dots
\big( \prod_{i=1}^k (\theta_{n/2}^2 + x_i^2) \big)
\geq
\nonumber \\
& \qquad \qquad \qquad \qquad \qquad
\big[ \theta_1^2 + (x_1^2 x_2^2 \dots x_k^2)^{\frac{1}{k}} \big]^k
\dots
\big[ \theta_{n/2}^2 + (x_1^2 x_2^2 \dots x_k^2)^{\frac{1}{k}} \big]^k
\nonumber
\end{align}
which proves the main result for even ##n##:
\prod_{i=1}^k \det \big( A + x_i I \big) \geq \det \Big( A + (\prod_{i=1}^k x_i)^{1/k} I \Big) \qquad n \;
\mathrm{even} .
In the next section we prove the main result for odd ##n##. See next spoiler!
Part (c) (i):
We now consider the case ##n = 3##. We write
U^\dagger A U = D =
\begin{pmatrix}
0 & 0 & 0 \\
0 & \lambda & 0 \\
0 & 0 & - \lambda
\end{pmatrix} .
First consider
= \det \big[ U^{-1} \big( A + x_1 I \big) U U^{-1} \dots U U^{-1} \big( A + x_k I \big) U \big]
\quad = \det \Big[
\begin{pmatrix}
x_1 & 0 & 0 \\
0 & \lambda + x_1 & 0 \\
0 & 0 & - \lambda + x_1
\end{pmatrix}
\dots
\begin{pmatrix}
x_k & 0 & 0 \\
0 & \lambda + x_k & 0 \\
0 & 0 & - \lambda + x_k
\end{pmatrix}
\Big]
= \det
\begin{pmatrix}
x_1 x_2 \dots x_k & 0 & 0 \\
0 & (\lambda + x_1) \dots (\lambda + x_k) & 0 \\
0 & 0 & (- \lambda + x_1) \dots (- \lambda + x_k)
\end{pmatrix}
= (x_1 x_2 \dots x_k) \times
\quad \det
\begin{pmatrix}
\end{pmatrix} .
= (x_1 x_2 \dots x_k) (\theta^2 + x_1^2) \dots (\theta^2 + x_k^2)
Now consider
\begin{align}
& \det \Big( A + (\prod_{i=1}^k x_i)^{1/k} I \Big)^k =
\nonumber \\
& = \det
\Big[
\begin{pmatrix}
(x_1 x_2 \dots x_k)^{\frac{1}{k}} & 0 & 0 \\
0 & \lambda + (x_1 x_2 \dots x_k)^{\frac{1}{k}} & 0 \\
0 & 0 & - \lambda + (x_1 x_2 \dots x_k)^{\frac{1}{k}}
\end{pmatrix}
\Big]^k
\nonumber \\
& = (x_1 x_2 \dots x_k) \det
\Big[
\begin{pmatrix}
\end{pmatrix}
\Big]^k
\nonumber \\
& = (x_1 x_2 \dots x_k ) \big[ \theta^2 + (x_1^2 x_2^2 \dots x_k^2)^{1/k} \big]^k
\nonumber
\end{align}
As the OP's question assumes that ##\{ x_1, \dots , x_k \}## are positive numbers, and using the result (3), we
have:
(x_1 x_2 \dots x_k) (\theta^2 + x_1^2) \dots (\theta^2 + x_k^2) \geq (x_1 x_2 \dots x_k ) \big[ \theta^2 + (x_1^2
which establishes the main result for ##n = 3##:
\prod_{i=1}^k \det \big( A + x_i I \big) \geq \det \Big( A + (\prod_{i=1}^k x_i)^{1/k} I \Big) \qquad n = 3 .
Part (c) (ii):
We now turn to the general case of any odd ##n##. We can write
U^\dagger A U = D =
\begin{pmatrix}
0 & 0 & 0 & 0 & 0 & \dots & \dots & 0 & 0 \\
0 & \lambda_1 & 0 & 0 & 0 & \dots & \dots & 0 & 0 \\
0 & 0 & - \lambda_1 & 0 & 0& \dots & \dots & 0 & 0 \\
0 & 0 & 0 & \lambda_2 & 0& \dots & \dots & 0 & 0 \\
0 & 0 & 0 & 0 & - \lambda_2& \dots & \dots & 0 & 0 \\
\vdots & \vdots & \vdots & \vdots & \vdots & \ddots & \vdots & \vdots & \vdots \\
\vdots & \vdots & \vdots & \vdots & \vdots & \dots & \ddots & \vdots & \vdots \\
0 & 0 & 0 & 0 & 0 & \dots & \dots & \lambda_n & 0 \\
0 & 0 & 0 & 0 & 0 & \dots & \dots & 0 & - \lambda_n \\
\end{pmatrix} .
First consider
\begin{align}
\nonumber \\
\nonumber \\
\begin{pmatrix}
x_i & 0 & 0 & \dots & 0 & 0 \\
0 & \lambda_1 + x_i & 0 & \dots & 0 & 0 \\
0 & 0 & - \lambda_1 +x_i & \dots & 0 & 0 \\
\vdots & \vdots & \vdots & \ddots & \vdots & \vdots\\
0 & 0 & 0 & \dots & \lambda_{(n-1)/2}+ x_i & 0 \\
0 & 0 & 0 & \dots & 0 & - \lambda_{(n-1)/2} + x_i \\
\end{pmatrix}
\nonumber \\
& = (x_1 x_2 \dots x_k ) \big( \prod_{i=1}^k (\theta_1^2 + x_i^2) \big)
\dots
\big( \prod_{i=1}^k (\theta_{(n-1)/2}^2 + x_i^2) \big)
\nonumber
\end{align}
Now consider
\begin{align}
\nonumber \\
& = \det
\begin{pmatrix}
(x_1 \dots x_k)^{\frac{1}{k}} & 0 & 0 & \dots \\
0 & \lambda_1 + (x_1 \dots x_k)^{\frac{1}{k}} & 0 & \dots \\
0 & 0 & - \lambda_1 + (x_1 \dots x_k)^{\frac{1}{k}} & \dots \\
\vdots & \vdots & \vdots & \ddots & \vdots \\
\end{pmatrix}^k
\nonumber \\
(x_1 x_2 \dots x_k ) \big[ \theta_1^2 + (x_1^2 x_2^2 \dots x_k^2)^{1/k} \big]^k
\dots
\big[ \theta_{(n-1)/2}^2 + (x_1^2 x_2^2 \dots x_k^2)^{1/k} \big]^k
\nonumber
\end{align}
\begin{align}
& (x_1 x_2 \dots x_k ) \big( \prod_{i=1}^k (\theta_1^2 + x_i^2) \big)
\dots
\geq
\nonumber \\
\dots
\nonumber
\end{align}
which establishes the main result for general odd values of ##n##:
\prod_{i=1}^k \det \big( A + x_i I \big) \geq \det \Big( A + (\prod_{i=1}^k x_i)^{1/k} I \Big) \qquad \mathrm
{for \; odd \;} n .
##Completeting the proof of problem 1.
Part (a):
Part (b) (i):
U^\dagger A U = D =
\begin{pmatrix}
\lambda & 0 \\
0 & - \lambda
\end{pmatrix} .
First consider
\begin{align}
\nonumber \\
\nonumber \\
I \big) U \big]
\nonumber \\
& = \det \Big[
\begin{pmatrix}
0 & - \lambda + x_1
\end{pmatrix}
\begin{pmatrix}
0 & - \lambda + x_2
\end{pmatrix}
\dots
\begin{pmatrix}
0 & - \lambda + x_k
\end{pmatrix}
\Big]
\nonumber \\
& = \det
\nonumber \\
\begin{pmatrix}
\end{pmatrix}
\nonumber \\
\nonumber \\
\nonumber
\end{align}
Now consider
\begin{align}
\nonumber \\
\det \Big[
\begin{pmatrix}
\end{pmatrix}^k
\Big]
\nonumber \\
& = \det \Big[
\begin{pmatrix}
\end{pmatrix}
\Big]^k
\nonumber \\
\nonumber \\
\qquad \qquad (2)
\nonumber
\end{align}
Part (b) (ii):
\begin{align}
\nonumber \\
\nonumber \\
\nonumber
\end{align}
\begin{align}
\nonumber \\
\nonumber \\
\nonumber \\
\nonumber \\
\nonumber
\end{align}
\begin{align}
\nonumber \\
\nonumber \\
\nonumber \\
\nonumber \\
\nonumber
\end{align}
Rearranging we have
\begin{align}
\nonumber \\
\nonumber
\end{align}
Part (b) (iii):
U^\dagger A U = D =
\begin{pmatrix}
\end{pmatrix} .
So that
\begin{align}
\nonumber \\
\nonumber \\
\begin{pmatrix}
\end{pmatrix}
\nonumber \\
\Big( \prod_{i=1}^k
\det
\begin{pmatrix}
\end{pmatrix} \Big)
\dots
\Big( \prod_{i=1}^k
\begin{pmatrix}
\end{pmatrix} \Big)
\nonumber \\
\nonumber
\end{align}
Next consider
\quad = \det
\begin{pmatrix}
\end{pmatrix}^k
\Big[
\begin{pmatrix}
\end{pmatrix}^k
\Big]
\dots
\begin{align}
\dots
\geq
\nonumber \\
\dots
\nonumber
\end{align}
\mathrm{even} .
Part (c) (i):
U^\dagger A U = D =
\begin{pmatrix}
0 & 0 & 0 \\
0 & \lambda & 0 \\
0 & 0 & - \lambda
\end{pmatrix} .
First consider
\quad = \det \Big[
\begin{pmatrix}
x_1 & 0 & 0 \\
\end{pmatrix}
\dots
\begin{pmatrix}
x_k & 0 & 0 \\
\end{pmatrix}
\Big]
= \det
\begin{pmatrix}
\end{pmatrix}
\quad \det
\begin{pmatrix}
\end{pmatrix} .
Now consider
\begin{align}
\nonumber \\
& = \det
\Big[
\begin{pmatrix}
\end{pmatrix}
\Big]^k
\nonumber \\
\Big[
\begin{pmatrix}
\end{pmatrix}
\Big]^k
\nonumber \\
\nonumber
\end{align}
have:
which establishes the main result for general odd values of ##n = 3##:
Part (c) (ii):
U^\dagger A U = D =
\begin{pmatrix}
\end{pmatrix} .
First consider
\begin{align}
\nonumber \\
\nonumber \\
\begin{pmatrix}
\end{pmatrix}
\nonumber \\
\dots
\nonumber
\end{align}
Now consider
\begin{align}
\nonumber \\
& = \det
\begin{pmatrix}
\end{pmatrix}^k
\nonumber \\
\dots
\nonumber
\end{align}
\begin{align}
\dots
\geq
\nonumber \\
\dots
\nonumber
\end{align}
{for \; odd \;} n .
Thanks! I was worried I'd have to type up a solution if no one solved it by month end!
The solution looks about right. Proving the ##n=2## case is definitely the key unlocking the problem, which you tackled in your second spoiler. I'm a bit short on time right now but will take a closer look later on.
