Intersection of line and plane
The discussion focuses on finding the intersection of a line and a plane using vector equations. The line is represented as r = i + j + A(2k - j), and the plane is defined by the equation r . (i + j) = 4. Participants suggest using the vector equation format r . n = p for simplification, leading to the equation 1 + (1 - A) = 4 to solve for A. There is confusion regarding the breakdown of the vector components and how to properly format vectors in the forum. Clarification is sought on deriving the value of A and the correct approach to solving the intersection problem.
apple53
Intersection of line and plane!
Okay i to find the common points of line and plane
Question r=i+j+A(2k-j) and r . (i+j) = 4
I heard that it is easier to use the vector equation in the form r . n = p
So if i do that to above
You get
1 0 1
1 + A -1 . 1 =4
0 2 0
The above doesn't sound right i won't get an x, y, z value i defo need help on this or can anyone start my off
kind regards
And also how do you wrap the vectors in brackets on this forum lol
You get
1 0 1
1 + A -1 . 1 =4
0 2 0
It's not clear to me what the first and third lines are but it looks like the second line is almost the result of putting r=i+j+A(2k-j)= i+ (1- A)jk+ 2Ak into the equation r . (i+j) = 4.
Rather than what you have, you should get 1+ (1- A)= 2- A= 4.
Solve That for A, then put that value into the equation of the line.
kind regards
Sorry about the way its laid out. your right that's what i have done
i put r=i+j+A(2k-j) into r . (i+j) = 4
which gives me
i+j+A(2k-j) . (i+j) = 4
I tried writing this in vectorial format but don't khow how to get the brackets to wrap i,j,k on this website. If you can help with that i would be gratefull
Anyway to continue on with question we break them down in components. Correct me if I am wrong
1+A(0) . 1=4
1+A(-1) . 1=4
0+A(2) . 0=4
Which is where i got previously. Which is probably wrong
Now to continue with what you did I am trying to work out how you derived the above.
I broke the vector r=i+j+A(2k-j) into its components ready to put the A values in
so you get
1+A(0)=X This gives x=1
1+A(-1)=Y
0+A(2)=Z
Just need to know how you derived A whcih i quotes above. If you did put put r=i+j+A(2k-j) into r . (i+j) = 4 To get the equation i+j+A(2k-j) . (i+j) = 4. And from this you managed to get A. Can you please explain to me step by step please
Thanks for quick reply and Kinds regards
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
