MHB Is $2 + 8\sqrt{-5}$ a Unit or Irreducible in $\mathbb{Z} + \mathbb{Z}\sqrt{-5}$?
The discussion focuses on determining whether the element $2 + 8\sqrt{-5}$ is a unit or irreducible in the ring $\mathbb{Z} + \mathbb{Z}\sqrt{-5}$. A unit is defined as an element that has a multiplicative inverse, while an irreducible element cannot be factored into two non-unit elements. The expression can be factored as $2(1 + 4\sqrt{-5})$, indicating that $2$ is not a unit since it does not have an inverse in the ring. The community emphasizes providing hints rather than complete solutions to encourage learning. Ultimately, the analysis of $2 + 8\sqrt{-5}$ leads to the conclusion that it is neither a unit nor irreducible.
abs1
prove that $2+8{\sqrt{-5}}$ is unit and irreducible or not in $\mathbb Z+\mathbb Z{\sqrt{-5}}$.
Hint: we can write $2+8{\sqrt{-5}}=2(1+4\sqrt{-5})$.
please explain in detail if possible
What is the definition of a unit?
an element alpha belong to k ia called a unit if alpha divisible by 1.
dear it is my question if u not solved it then no problem its ok .if u solved it then give me complete explanation thank u so much
irreducible element:a non zero non unit element alpha belong to k is said to be irreducible if aplha=ab.
either a is unit or b is unit.
i give u both def. of unit and irreducible thank u so much
Not quite.
From wiki:
a unit in a ring with identity $R$ is any element $u$ that has an inverse element in the multiplicative monoid of $R$, i.e. an element $v$ such that
$$uv = vu = 1_R,$$
where $1_R$ is the multiplicative identity​
Sorry, we are a math help site.
We do not usually give complete solutions.
Instead we give hints or similar to help people to learn math.
If you're up to it...
The hint I gave showed that we can split the expression in two factors that we might call $a$ and $b$.
Let's start with $2$.
Is it a unit? That is, does it have a multiplicative inverse in the given ring?
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 21 ·
