Inverse rotatory water sprinkler
  • Context: High School
  • Thread starter Thread starter basheer uddin
    Inverse Water
13 replies · 2K views
basheer uddin
an S-shaped lawn sprinkler (an S-shaped pipe on a pivot) in which water squirts out at right angles to the axis and makes it spin in a certain direction is taken and if you had a lake, or swimming pool (a big supply of water) and you put the sprinkler completely under water, and sucked the water in, instead of squirting it out, which way would it turn? Would it turn the same way as it does when you squirt water out into the air, or would it turn the other way?
What do you think?
I don't want to influence others with my thoughts, just to fix it: 29d64d3f6b992f1ce286086f3855ae8d71956b75 generated from [noparse]http://www.hashgenerator.de/[/noparse] with my reply
clockwise in the s shape looking from above?
because conserving angular momentum, water flows in an anti-clockwise direction the nozzle
(on the whole it moves in an anti-clock wise direction,replacing upper half of s by an upside down L)
so tube must move clockwise.
but looking at it from the point of view of basic forces, force due to change in direction of water on the tube is same in both the cases(water squirting out and flowing into the tube),
so direction of torque must be same?
The water leaves with zero angular momentum, and I would not expect water in the lake to rotate opposite to the sprinkler, so based on angular momentum conservation, I expect no rotation.
Why?
To extend my first statement: You can generate a force like a rocket, but you cannot generate a (significant) net force by sucking in any medium.
Thanks, that confirms my expectation. I did not consider the short period where it gets switched on, as this is negligible for realistic setups - and afterwards, there is no torque.
can we obtain the equations in the ideal case?
using bernouilli's principle?
i am unable to derive it myself
can you?
i don't care it is complicated.
if the solution is long send a link in pdf please.
in your leisure;-)
yes,but it is evaluated in steady state condition in which the external torque is zero.
but it is good enough for me.
thanks
