Inverse trigonometric equation
21 replies · 5K views
utkarshakash
Solve
[itex]cot^{-1} x - cot^{-1} (n^2 - x+1)=cot^-1(n-1)[/itex]
I can write the above equation as θ+α=β where the symbols represent the respective inverse functions. Now I take tan of both sides. Simplifying I get
[itex](n^2+1-2x)(n-1) = x(n^2-x+1)[/itex]
Are you asking how to solve that equation?
utkarshakash said:
Solve
I get nearly the same thing:
[itex](n^2+1-2x)(n-1) = 1+x(n^2-x+1)[/itex]
Yes I have to find the value of x
But what should be the next step?
Multiply each side out.
Get everything to the left side.
You have a quadratic equation in x.
But its discriminant is way too big!
Too big in what sense ?
What do you get for the discriminant ?
How are you getting that 'extra' 1 in the RHS. OK I'm only posting what I got from my answer i.e. without that '1'.
D=[itex]n^4+6n^2-8n+2[/itex]
Wow! I showed that "extra" 1 way back in post #3. Now you mention it?
I got it because,
[itex]\displaystyle \left(1+\frac{1}{x(n^2-x+1)}\right)x(n^2-x+1)=x(n^2-x+1)+1\ .[/itex]
How did you not get it?
I got it because,
Hey there is a much better solution than this. Instead of taking tan if I take cot of both sides I get a very simple result and here's it
[itex]x= \dfrac{n(n+1)}{2}[/itex]
And yes you said right. There was a calculation error in my solution. It should have that extra 1
That is interesting. I'll have to take a look at it.
I still get a quadratic equation in x, so that can't be the solution.
[itex]\displaystyle \cot(A+B)=\frac{\cot(A)\,\cot(B)-1}{\cot(A)+\cot(B)}[/itex]
OMG I made the silliest mistake ever. :bugeye: Instead of taking cot of both sides I just removed the 'inverse thing' and simply calculated the value of x from there. OK sticking to my previous solution I take tan of both sides and get the same thing what you got(with that extra 1) and get the discriminant as
[itex]-4n^3+6n^2-8n+9[/itex]
What I got for a discriminant was
[itex]n^4+6n^2-8n+9\ .[/itex]
I just rechecked it using WolframAlpha on
and it confirmed my result.
OK so what should I do after getting discriminant?
Nothing special. It's just a quadratic equation in x; solve it with the usual formula. If it's messy, it's messy.
You can't simply say that :cry:I cannot get rid of that square root. Please help me. Its not even a perfect square. Should I leave it this way?
If n=0, then the discriminant is a perfect square. I found no other cases. Also, the discriminant is positive for all values of n.
So as haruspex said, it's a messy result.
OK so you want me to continue with that square root.
That's about all there is to do, but you can't do much simplifying.
OK Thanks!
