Proving a Trigonometric Identity Involving Inverse Functions
The discussion focuses on proving the trigonometric identity involving inverse functions, specifically the equation relating x and y through the parameters a, b, and c. The initial approach involved assuming x equals y and transforming the equation into a trigonometric form, but the solver faced challenges in connecting the transformations. It was suggested that the equation might not have a unique solution, as indicated by a Wolfram Alpha analysis. Ultimately, a successful method was found by treating the equation as a quadratic with roots x and y or by using auxiliary angles to simplify the trigonometric equation. The conversation highlights the complexity of trigonometric identities and the importance of exploring different mathematical strategies.
cr7einstein
After having struggled yesterday with this as much as I could, I am posting this problem here-
if ##ax+bsec(tan^{-1}x)=c## and ##ay+bsec(tan^{-1}y)=c##, then prove that ##\frac{x+y}{1-xy}=\frac{2ac}{a^2-c^2}##.
My attempt- Comparing both the equations, ##x=y## clearly(it is a dummy variable, sort of). So we basically need to find ##\frac{2x}{1-x^2}##. Put ##x=tan\theta##; so the given equation becomes-
##a tan\theta +b sec\theta=c##. From here, I don't know what to do. I tried to put it in the form of ##a sin\theta -(c) cos\theta=-b##, then divide and multiply it with ##\sqrt{(a^2+c^2)}## and put it in the auxiliary form(using ##a=rcos\theta,c=rsin\theta##); but alas; no help. By just working backwards, we see that the transformations ##a=rcos\theta## and ##c=rsin\theta## give the answer; and these are also the transforms I need to get my auxiliary form I mentioned above. But how do I connect them beats me. and Please help; I'd really appreciate it. Thanks in advance!
Do you know a relationship between tan and sec?
I doubt that it is necessarily true that x=y, that will hold only if one proves that the equation ##ax+bsec(tan^{-1}x)=c## has unique solution and I doubt a trigonometric equation has unique solution.
From what i can see from wolfram solver, the equation does not has unique solution in real numbers, at least not in all cases.
http://www.wolframalpha.com/input/?i=ax+bsec(arctan(x))=c
@Delta² and @haruspex I found the answer-make the equation a quadratic with roots being x and y; then use properties of sum and products. OR, make an equation with an auxiliary angle, and then solve the resulting trig equation. Thanks for the time though!
Likes Delta2
Ok.
Fwiw, I was hinting at using sec2=1+tan2, from which sec(tan-1(x))=√(1+x2). Maybe that's what you did.
Likes Delta2
@haruspex yes that's what I did...and even going by my initial attempt as stated in the problem, I got the same result.
