Will heating hydrogen gas in a vacuum chamber create plasma?
  • Level: High School
  • Thread starter Thread starter evan manalu
    Hydrogen
18 replies · 5K views
evan manalu
if I have vacuum chamber from steel then filled with hydrogen gas
and cook it like cooking soup
will the hydrogen ionized and become plasma?
can heat like that ionize hydrogen gas?
thanks..
No, the steel will melt before you obtain temperatures high enough to ionize the hydrogen.
This is really something you should be able to check with a simple Google search. Simply search for the ionization energy and compare to the Boltzmann constant.
Ionize energy hydrogen 13.5eV
And Boltzmann const 1.3806488 × 10-23 m2 kg s-2 K-1
Can you show me how to compare it..
Thanks before..
Thanks before..
Use the Boltzmann constant in units of eV/K. What is the SI unit of temperature?
How about volt?
How volt to ionize hydrogen with distance of electrode 10cm
Any equation to explain this?
evan manalu said:
How about volt?
Impractical as well, if you want to know why there is this so called barrier-suppression ionization where a DC field modifies the Coulombic potential so that one side is suppressed below the unperturbed ground state energy. For hydrogen atom the critical field required to realize barrier-suppression ionization is 3.2x1010 V/m from which you can calculate the voltage. A more feasible way is by electron impact ionization.
evan manalu said:
celsius
Wrong. The SI unit of temperature is Kelvin.
eV is not Volt, it is electron Volts, i.e., a measure of energy defined as the energy gained by an electron under acceleration of a 1 V electric potential.
thanks..
Since they sell Hydrogen gas discharge tubes,
http://www.fishersci.com/ecomm/servlet/itemdetail?storeId=10652&langId=-1&catalogId=29104&productId=11417015&distype=0&fromSearch=0&hasPromo=0
At the right level of vacuum, flowing a current through hydrogen should ionize it.
I don't think you could do this in a conductive chamber, but rather something
where you could direct the electrical charge through the gas.
Without going into too much details, and just ignore "eV" for now, If you you cook hydrogen gas in a "magical" tank that will never melt, you will be able to ionize hydrogen gas eventually.
How will you realize this magical tank?
My understanding only:
tank is only in our perception, an H2 that is going to be ionized only cares about the impact force of whatever particle/energy that is going to hit that h2. A hot surface of a tank, another hot gas, whatever really.
You can use RF waves to ionize hydrogen, or you can use a high voltage to cause the atoms to break down, or you can use a particle beam to collide with the hydrogen gas.
Radio Waves don't have what it takes to ionize hydrogen, can it?
I think I shouldn't have said RF waves, but you can use radiofrequency driven capacitors to generate a plasma, and you can use microwaves to heat a gas to plasma temperatures.
