Is the Sequence xn=1/(n-2) Convergent for All Values of n?
  • Thread starter Thread starter kelvin490
    Convergent
The sequence xn=1/(n-2) converges to zero as n approaches infinity, but is undefined at n=2, making it ill-defined overall. Convergence is only applicable to sequences as n tends to infinity, rendering discussions about finite n meaningless in this context. While boundedness can be discussed for finite sequences, the presence of an undefined term at n=2 means the sequence is not bounded. If the sequence is restricted to valid terms (n≠2), properties like convergence and boundedness can be analyzed. Overall, the sequence's undefined nature at n=2 prevents meaningful discussions about its convergence or boundedness.
kelvin490
Suppose there is a sequence xn=1/(n-2). We know we n tend to infinity the sequence tends to zero. But at n=2 it is equal to infinity. Is this sequence convergent?
There is also a theorem that all convergent sequence are bounded for every n. But the sequence above is not bounded at n=2.
From definition of convergent sequence it seems that only the case that n tends to infinity is concerned, it says nothing about whether it is convergent when n is finite but xn is not.
Mathematics news on Phys.org
I presume you are taking an introductory class in limits and are having trouble with the basic definitions because for years you have assumed things that are simply not true. "\frac{1}{0} is NOT "infinity". It has NO value because "division by 0" is, literally, undefined.
The definition "says nothing about whether it is convergent when n is finite" because that makes no sense. We define convergence for a sequence only for the index going to infinity. Also it makes no sense to say that "x_n is not finite" because the terms of a sequence are, by definition, real numbers and all real numbers are finite. It is NOT true that "at n= 2, 1/(n- 2) is equal to infinity". x_2 simply has NO value.
Likes 1 person
Does it mean that for finite n, it is meaningless to say whether xn is convergent? Concept of convergence only applied for n tends to infinity?
In defining whether a sequence is bounded, n is for all values. Is xn bounded?
Yes in the sense that if I'm only give finitely many ##x_n## then convergence is a meaningless thing. For example, if I'm only given ##x_1,~x_2,~x_3,~x_4##, I cannot talk about convergence. I need to have ##x_n## close to infinity to discuss convergence.
Even better, if I leave out finitely many terms, that will not affect convergence. So if I'm given ##x_1,~x_2,~x_3,...## all the way to infinity, or if I'm given ##x_4,~x_5,~x_6,...## all the way to infinite, the concept of convergence will remain the same. If one sequence converges, so will the other and to the same value.
Of course, if I leave out infinitely many terms, then things can change. So the entire sequence ##x_1,~x_2,~x_3,...## might have a very different behavior than the sequence of odd terms ##x_1,~x_3,~x_5,...##.
Boundedness behaves very similarly to convergence in the sense that if I leave out finitely many terms, that will not affect boundedness. But leaving out infinitely many terms might.
Although for a finite sequence it is meaningless to discuss convergence, we can discuss boundedness. But it will turn out a finite sequence is always bounded.
But wait, the example in your OP! We have ##x_2 = \infty## so it's not bounded! Well, first of all, like Halls remarked, ##x_2## is not infinity, it is simply undefined.
Furthermore, I would go further and say that the entire sequence is ill-defined. That is, if I look at the sequence ##x_1,~x_2,~x_3,~x_4,~x_5,...##, then I'd say this sequence is not defined since one of the terms is undefined! So it is meaningless to discuss any properties of this sequence.
Of course, if we restrict the sequence to #x_3,~x_4,~x_5,...##, then everything is perfectly well-defined and we can talk about properties like convergence and boundedness.
Likes 1 person
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
