Is a 40w Bulb Efficient at 120v?
  • Level: High School
  • Thread starter kgal
    Bulb Power
8 replies · 4K views · last reply
kgal
How many watts should a 40w bulb use at 120v?
THe bulb would be marked as using 40W at a specified voltage. If you don't know that information, you can't answer the question.
In the U.S. standard voltage is 120 volts, so light bulbs will use the wattage as marked.
Due to what I believe is partly an historic anomaly, bulbs in the UK are rated at 240V, but 230V is the EU voltage standard which should be delivered to UK homes.
I think in part it is usual to rate the bulb at a higher voltage as the life expectancy [of filament bulbs] drops exponentially once above the rated voltage. So bulbs may be sold into a market with voltage ratings slightly in excess of the specified volts.
Electrical supply into homes is rarely that accurate, at least in UK. My own house suffered for years at variable under-voltage. We share a relatively small spur with an industrial estate. It dropped (I kid you not) to 183V on one occasion I was measuring it myself. I complained to the elec co and they did some work. I then had >250V for several months until I complained enough they installed £70,000 of new kit in the local sub-station.
That's a power use figure, like one on a frig or work tool...it's not an indicator
of how much light it produces...
Hence the question "How many watts should a 40w bulb use..."
:confused:
:confused:
As previously stated, forty watts at the voltage specified by the manufacturer.
Due to a variety of factors, the measured power consumption will vary from the advertised value.
Yes, I know that, but Naty 1 didn't appear to get the question.
