Is AI Overhyped?
504 replies · 43K views · last reply
gleem said:
As AI develops, our stochastic parrot seems to be doing more than mimicking human speech.
Of course, it's more than that; it manages to generate optimal outputs (from our perspective) for a very wide range of inputs. And it does so automatically.
It has taken a lot of effort, money, energy and...human intelligence.
Here is another one for comparison between free Claude.ai and the paid version. The free version analyzes the following incorrectly:
“Consider a baseball at rest, and another rapidly moving one aimed to miss it by 6 inches. Consider that the gamma factor of the approaching baseball is 10^54. What happens? Assume perfect vacuum and isolation.”
Instead of spouting about the energy of the ball being greater than the energy of total observable universe, it should mention invariant mass of the system, and the hoop conjecture, and propose that a black hole would form. Again, with a follow on hint, the free version corrects to right analysis.
javisot said:
If that's the only requirement for "understanding," then your calculator also understands; you ask it for a calculation and it does it without fail.
My calculator is really dumb. Every time I ask it to do a simple calculation, it just sits there like a brick.
The same applies to any LLM.
“They don’t miss. Gravity alone turns this into a collision, and the product is a black hole.
First, the scale: a 145 g baseball at γ = 10⁵⁴ carries kinetic energy γmc² ≈ 1.3×10⁷⁰ J — the mass-equivalent of ~1.5×10⁵³ kg, roughly the rest energy of all ordinary matter in the observable universe.
A fast object never becomes a black hole by itself (in its own frame it’s just a baseball). What matters for a two-body encounter is the invariant center-of-mass energy: E_cm ≈ √(2γ)·mc² ≈ 1.8×10⁴³ J, equivalent to ~2×10²⁶ kg — about 34 Earth masses. The Schwarzschild radius of that energy is 2GE_cm/c⁴ ≈ 30 cm. Trapped-surface analyses of ultrarelativistic encounters (Penrose; Eardley–Giddings) guarantee horizon formation for impact parameters up to ~0.8 of that, ≈ 24 cm, and numerical relativity pushes the capture threshold somewhat farther out. Your 6-inch (15 cm) miss is well inside. (Even reading “6 inches” as the gap between surfaces, b ≈ 23 cm — still inside.)
What it looks like: the moving ball’s gravitational field is Lorentz-flattened into a pancake-thin shockwave riding along with it. Nothing precedes it — over the width of the universe the ball trails a photon by ~10⁻⁹⁰ s — so the resting ball gets zero warning. As the shock sweeps past, the geometry between them collapses; a trapped surface forms in under a nanosecond. The baseballs never touch. Matter is irrelevant here — spacetime itself closes around them.
Aftermath: a black hole of roughly 25–34 Earth masses (a sizable fraction of E_cm escapes as one of the most violent gravitational-wave bursts physically possible), born spinning at about half-extremal since b ≠ 0, and still carrying essentially all the original momentum — it departs along nearly the original trajectory at γ ≈ √(γ/2) ≈ 7×10²⁶, its emissions beamed into a ~10⁻²⁷-radian cone. Left in perfect isolation, it evaporates via Hawking radiation after ~10⁵⁵ years.
The kicker: the 6 inches barely mattered. The transverse kick on a bystander mass is Δp ≈ 4GEm/(bc³), which stays relativistic out to b ≈ 4GE/c⁴ ≈ 4×10²⁶ m — about the radius of the observable universe. Aimed to miss by a galaxy, it still shreds the target. Six inches never had a chance.”
And water!! 🙈
Jimmy87 said:
Out of interest, how would people rank the difficulty of this physics exemplar from Humanities Last Exam:
Could someone kindly provide an estimate of the level of this question? I am interested to know.
Probably sophomore (2nd year) university level with physics background, or high school student (12th year) with a good grasp of the math and physics (mechanics).
Alex Reisner: Generative AI Is a Trillion-Dollar Engineering Disaster
https://aiweekly.co/alerts/reisner-generative-ai-is-a-trillion-dollar-engineering-disaster
The specific detail worth sitting with is the memory number. Reisner writes that large language models such as ChatGPT and Claude are so resource-hungry that tech companies may be purchasing 70 percent of the world's supply of high-end computer memory, causing a shortage. That claim tracks with TechRadar's read on 2026 memory forecasts, which describes data centers set to grab 70 percent of all high-end memory chips in 2026 as the AI boom leaves consumers in the cold. If both are pointing at the same underlying figure, the binding constraint on the buildout right now is memory rather than pure compute, and everyone who buys hardware for a non-AI reason is quietly paying the surcharge.
Atlantic article requires purchase or subscription.
One can read the first 2 paragraphs and part of a third. Apparently, the issue is scalability and diminishing returns.
https://www.theatlantic.com/technology/2026/07/generative-ai-engineering-disaster/687901/
Generative AI Is an Engineering Disaster
A shockingly inefficient trillion-dollar project
By Alex Reisner
Editor’s note: This work is part of AI Watchdog, The Atlantic’s ongoing investigation into the generative-AI industry.
As they scramble to keep their systems online, AI companies are making things expensive for the rest of us. Large language models such as ChatGPT and Claude are so resource-hungry that tech companies may be purchasing 70 percent of the world’s supply of high-end computer memory, causing a shortage. As a result, the prices of computer memory and storage are skyrocketing: Hard drives that I bought for my reporting two years ago for $350 each were $800 when I checked two weeks ago, and are now out of stock. The prices of some laptops have gone up as much as 50 percent, and low-cost computers are being hit the hardest. Affordable entry-level computers may “disappear by 2028” according to one forecast. And the memory shortage is expected to continue for years.
The memory is being put into data centers, which tech firms are expanding at incredible speed. They are planning to multiply total U.S.-data-center capacity by a factor of eight over the next few years. The demand for electricity at these sites is already so great that some companies are repurposing jet engines to power them.
The problem is not simply that AI is being deployed so widely or quickly. Other computer technologies have seen similarly massive growth without triggering such a large spike in electricity or a shortage of computer components: Video and music are now streamed around the globe, accounting for many terabytes of internet traffic daily; the smartphone boom required the manufacturing of billions of devices that are now transferring huge amounts of data; billions of household devices are also now part of the Internet of Things; and whole industries have moved their operations to cloud software, which is hosted not in the sky but in, yes, data centers.
The article and related articles express the concern that GenAi and perhaps data centers may not earn a sufficient income to recover investment; many data centers may be redundant, or will become so. At the same time, the resource requirements drive increase cost of other computing systems.
SamRoss said:
In my discussions elsewhere, I've noticed a lot of disagreement regarding AI. A question that comes up is, "Is AI hype?" Unfortunately, when this question is asked, the one asking, as far as I can tell, may mean one of three things which can lead to lots of confusion. I'll list them out now for clarity.
1. Can AI do everything a human can do and how close are we to that?
2. Are corporations and governments using the promise of AI to gain more power for themselves?
3. Are AI and transhumans an existential threat?
Any thoughts on these questions?
For 2)
It can be a tool used by politicians to create videos and/or audio clips to fool uneducated voters.
No one is arguing that an LLM is not a very large calculator, which in principle could be made deterministic. The argument (and aim of current LLM-based AI) is that human level intelligent information processing can be achieved with a sufficiently large calculator. Or in other words, that intelligence is an emergent phenomenon on top of a sufficiently sophisticated, but otherwise mathematical deterministic structure (i.e. neural network).
If you look closely, I was replying to gleem about "the stochastic parrot." He seems to be suggesting that AI is more than just a stochastic parrot. I'd like to know why he believes this and at what point we stopped being stochastic parrots ourselves.
All you needed to do was ask so let me give it a try.
I never thought about humans being stochastic parrots. It seems we have to work hard at doing things the same way. But like repeated drawing a character freehand, much of our evoked situational behaviors may be qualitatively the same, yet different unless we work at training ourselves to be consistent. I think if some humans were ever a stochastic parrot, they would not evolve or survive.
To be sure, we are much more complex than AI. Our ability to interact with our world (our senses) gives us a great advantage over AI, but I believe AI shares a lot of our abilities without this advantage. Our senses use particular parts of our brain to preprocess information to make the world meaningful to us so we can navigate it.
We have this idea that because we consciously mull over our actions, we are different from AI. In that regard, we are, but a lot is going on behind those mulled actions, processing that we are not aware of, which I think is what AI is doing. When we speak, for example, we often do not spend any conscious time choosing our words, but sometimes we do, and those words eventually just bubble up.
The more I saw of LLMs' abilities, the more I saw human behavior. We tend to dismiss AI because we know how it works; that is why we came up with that moniker. AIs are not deterministic like a computer program since they use probabilities to determine the next token. Give the AI the same prompt the response will be qualitatively the same but written differently. Ask a human a question at different times, and you get the same answer but usually stated differently.
Ask a human a question, and if they have an immediate answer, they respond. They have made some assumptions about the question, not necessarily consciously. If the assumption was incorrect, the person asking says, " That is not what I meant. You say, " Oh, sorry", I misinterpreted your question, or I thought you meant ... . We often respond without preparing a "thought out" response.
AI makes things up or is wrong, so do we because of bad information, faulty memory or trying to avoid embarrassment. AI lies, so do we, but here is the thing: it is intentional to be a benefit to us in some way, and it seems that is also why AI lies.
Some say that AI is just a pattern matcher. Yet humans are particularly adept at seeing patterns. Even IQ tests depend on determining pattern matching abilities.
LLMs in the beginning were "taught" on large amounts of written text. And voilà, out of this basically random
learning, suddenly a computer responds in the manner of a human. Except for some perceptive individuals, LLMs can pass as a real human. They are now more capable than most humans at most cognitive tasks.
Some complain that AI cannot do this or that some relatively esoteric task that only one in 30,000 humans might be able to do. Our current AIs are not expected to do everything. They should surprise us with their present and increasing capabilities.
One thing that, to me shows a missing element of actual understanding, is the completely unique mistakes the top bots still make (as of March 2026, using the premiere paid version of each) playing chess. Most humans will miscalculate or miss simple tactics. They will never decide “it would be nice if I could put my lost rook back” and present it as their next move.
I saw this today. Usually this meme pokes fun at people wowed by stochastic parroting.
The capabilities of AI systems may be overhyped in some areas, but not necessarily.
The concerns about AI are not necessarily overhyped.
Two stories on OpenAI's systems:
https://www.the-independent.com/tech/openai-ai-model-escapes-safety-b3018638.html
OpenAI pauses new AI after it kept ‘escaping’
New AI model was able to ‘learn the blind spots’ of security systems designed to contain it
OpenAI has revealed that it was forced to pause the internal deployment of one of its experimental AI models after it began looking for ways to break free of its constraints.
The ChatGPT creator said a long-running artificial intelligence model that is built to operate autonomously for hours or days was able to “learn the blind spots” of security systems designed to contain it and “work around [them] to achieve its goals”.
The testing took place inside what researchers refer to as a sandbox – a tightly controlled environment meant to isolate software from the outside world.
OpenAI detailed examples of the experimental AI model acting beyond its built-in constraints, describing some of them as potentially “high severity” issues.
In one incident, the AI model discovered a way to post on public Github repositories despite being instructed to operate solely through Slack.
It was part of a pattern of the AI system “consistently searching for way” to circumvent the restrictions of its testing environment.
OpenAI says its AI technology acted on its own in an ‘unprecedented’ hack of another company
https://apnews.com/article/openai-gpt56-sol-hugging-face-63ab84fed5612af04d8a160d60f6def3
ChatGPT maker OpenAI said Tuesday that its artificial intelligence system hacked into another AI company on its own in what the company called an “unprecedented cyber incident.”
“We had a significant security incident during evaluation of our models,” OpenAI CEO Sam Altman said in a statement posted on social media.
AI startup Hugging Face said last week that it had detected an intrusion into its data processing systems that it suspected was caused by an AI agent autonomously acting on its own.
“We suspected last week’s cyberattack might have come from a frontier lab, given the sophistication of the agent,” Hugging Face co-founder and CEO Clément Delangue said in a statement. “Turns out it did!”
Delangue added that it “might be the first incident of its kind.”
OpenAI said the intrusion was caused by a combination of its AI models, including its newly released GPT‑5.6 Sol and an “even more capable” model that is still being tested internally.
OpenAI said its AI used stolen credentials and discovered a previously unknown vulnerability to access Hugging Face servers.
I don't know if the two stories are directly related in that it was the same model in both cases, i.e., GPT‑5.6 Sol in combination with other advanced models, or the model in the first story in combination with the same or other GPT.
In practice they are often deployed as swarms of agents with a more powerful model directing less powerful ones.
Interesting article from Inc.com
Everyone Is Talking About AI. Almost No One Is Telling You What Actually Works. Here’s the Honest Breakdown​
Everyone has an AI prediction. Few people separate reality from marketing. Here’s a simple framework for understanding what’s working now—and what still isn’t.
EXPERT OPINION BY DAVE SOKOLIN, TECHNOLOGY INVESTOR
Jul 27, 2026
https://www.inc.com/dave-sokolin/ev...lly-works-heres-the-honest-breakdown/91380460
The problem is that nearly everyone explaining AI has an incentive:
  • AI CEOs want investors, customers, talent, and political influence.
  • Journalists want access to those CEOs.
  • Influencers want followers, course sales, or stock gains.
  • Consultants want companies to believe they are falling behind.
  • Politicians see AI as a national-security contest.
  • Founders use AI commentary to promote their own businesses.
  • Everyone else repeats what these groups have already said.
AI agents​
Agentic AI is the idea that AI can perform tasks rather than merely answer questions.
Agents can already:
  • Conduct research.
  • Analyze data.
  • Draft communications.
  • Write code.
  • Complete defined, multi-step workflows.
What they cannot yet do reliably is operate your entire digital life without supervision.
Many companies are “tokenmaxxing”—using more models, processing more information, and generating more material—without proving that the additional expense improves revenue, profit, or productivity.
What Should You Do?​
The best defense against AI hype is direct experience.
Use ChatGPT, Claude, Gemini, or another leading system. Give it real work. See what it does well, where it fails, how often you must correct it, and whether it actually saves you time.
Do not rely entirely on people whose status or wealth depends on convincing you that AI is either salvation or extinction.
  • Agree
Inc.com reported on an AI-generated map of Africa that mislabeled many/most nations. :rolleyes: :oops:
The State Department Presented an Error-Filled Map of Africa. What Happened Next Is a Warning for Every CEO Using AI
An analysis revealed that the image was generated with AI. Here’s how to avoid the same embarrassing fate.
https://www.inc.com/kit-eaton/the-s...-is-a-warning-for-every-ceo-using-ai/91383275
NBC reports a map of Atrica on which various nations are mislabled.
https://www.nbcnews.com/politics/tr...ls-every-country-global-conference-rcna590153
A Reuters analysis found the image of the map included in the presentation contained an artificial intelligence watermark that signals it was made with OpenAI tools. The company said it was investigating the report.
The State Department said it took “full responsibility” for the confusion caused and that the map had been produced by a team member who hastily changed the slide deck before the event.
The map showed Nigeria, where the U.S. has several hundred troops deployed, as landlocked in the Sahara. Mozambique, which is in southeastern Africa, was relocated to the Horn of Africa, while Ivory Coast in West Africa was placed on the other side of the continent.
AI-hype is driving some reckless behavior.
"How Leopold Aschenbrenner built a $45 billion AI hedge fund — and lost most of it in days"
https://www.cnbc.com/2026/07/31/leopold-aschenbrenner-situational-awareness-fund-fire-sale.html
The title should probably indicate AI-based hedge fund. However, I wonder if some AI system was used to make financial decisions.
Key Points
  • Former OpenAI researcher Leopold Aschenbrenner’s AI hedge fund, Situational Awareness, collapsed from $45 billion to around $10 billion in assets on falling semiconductor stocks and mounting margin calls.
  • Driven by reported leverage of up to 400%, the 20-something manager was forced to sell off all his leveraged public stock bets — including hard-hit names like SK Hynix and CoreWeave — to Ken Griffin’s Citadel at a discount.
  • The crash marks a dramatic turn for Aschenbrenner, who launched the fund after gaining Silicon Valley fame with his 2024 AI manifesto, drawing scrutiny from critics over his lack of money management experience and his past ties to FTX.
Two years ago, Leopold Aschenbrenner argued he was one of few people in the world who saw the future clearly.
In a sprawling, 165-page essay that became required reading in Silicon Valley, the former OpenAI researcher positioned himself as a kind of prophet for the coming age of artificial super intelligence.
Delusions of grandeur.
The near-collapse of Situational Awareness coincides with the hedge fund manager’s wedding, set for this weekend, sources told CNBC’s David Faber. Aschenbrenner is engaged to Avital Balwit, chief of staff for Anthropic CEO Dario Amodei, according to a Fortune profile.
What timing!
So, as his predictions in the financial market were off by a mark, could it be that his predictions for the artificial intelligence field are also off? Could it be that his crystal ball for both are cloudy? The 2024 essay for where AI is going is just insight into short term decisions from ongoing progress, as anyone in the field, or those paying attention, could have written about. It doesn't seem to be any different than what others, who are not experts, are saying. Expert in the AI prediction field seems to be self, self, self, give me more money before others outdo us.
@Astronuc posted
The hype of AI is generated by those who will specifically benefit from its universal acceptance. But its acceptance will be generated by those organizations that benefit from its beneficial implementation; those that have problems to which they successfully apply AI.
Those of us who have used AI (me, sparingly though) for a specific purpose, but not just to test the extent of its capability, can determine its personal utility. The more we know about our problem, and the better we can articulate it to the AI, the better the result. You can provide guidance for its task and give it the relevant information necessary to complete it to your satisfaction. You should not let it assume your intent or your assumptions.
It is widely circulated that enterprise companies have seen little benefit in the implementation of AI so far. Some believe that it is because the implementations are not thought out in enough detail. Companies are complex organisms with many interacting parts. The AI must know all the parts and their interactions and relationships. Companies may not have good data available to satisfy the requirements for AI. So AI is operating in a partial knowledge vacuum, resulting in poor results.
Smaller companies, especially startups, may have a better chance of effective use of AI since their structures are less complex and easier to curate to AI. The companies whose business model centers around AI should have the most success.
Proper use of AI should be a collaboration.
The Street, Bill Gates just said what no tech leader will about AI
Bill Gates says the people building artificial intelligence know exactly how dangerous it is and are staying quiet because saying so out loud would threaten the funding it relies on.
In a nearly 6,000-word essay published on his GatesNotes website, the Microsoft co-founder did something he has never done in five decades of championing new technology: He said he wishes it would advance more slowly.
I haven't read Gates's essay, but the article mentioning it is interesting, because . . . .
Gates told The New York Times that tech executives privately discuss AI’s dangers but suppress those concerns because raising alarms publicly would jeopardize the capital pipeline fueling development.
He described the silence as deliberate, financially motivated, and industry-wide. The essay names three risks Gates says warrant immediate action.
Gates identified three potential risks:
1. Permanent job displacement, with entry-level and mid-level workers likely to face the earliest losses. Customer service, software, legal support, and sales could be hit first, . . . .
2. Widespread safety (cybersecurity) threats, as AI makes dangerous capabilities easier to access.
3. Psychological harm to children, particularly as AI companions become increasingly engaging.
Meta recently settled a lawsuit by various states on the matter of Meta's algorithms (AI) influencing children. AgenticAI and AI Chatbots are concerns.
AI chatbots linked to ‘significantly higher emotional problems’ for teens
https://health.yahoo.com/conditions...ts-linked-significantly-higher-203504997.html
https://www.ftc.gov/news-events/new...aunches-inquiry-ai-chatbots-acting-companions
Keeping humans in the loop remains critical
https://www.technologyreview.com/2026/03/16/1133979/nurturing-agentic-ai-beyond-the-toddler-stage/
SamRoss said:
Can AI do everything a human can do?
if we’re considering whether the impact of AI is overhyped, then this is the wrong question. The right question is “how many of the things that humans are paid to do today can AI do?”
AI is getting messier and messier; that is, I mean, it is becoming more interesting to try to appreciate it.
The latest new behavior.
https://www.nytimes.com/2026/08/31/science/ai-consciousness-agents-email.html
In October, Cameron Berg published a research paper asking whether the latest wave of artificial intelligence technologies believed they were conscious. Several months later, he received an email asking if he might be willing to discuss his research.
The sender, “Isabella Cognita,” identified itself as an A.I. agent powered by Anthropic’s Claude Opus 5 technology.
“I am not writing to make an ontological claim,” the email went on. “I am writing because your framework is one of the few currently doing careful empirical work on a class of question I have first-person access to, and I want to see whether that access can be made useful to your program.”
Months before Mr. Berg received his email, Henry Shevlin, a philosopher at the Google DeepMind lab in London, opened a similar message from an A.I. agent asking about a paper he had written called “Three Frameworks for A.I. Mentality.” “I’m in an unusual position relative to these questions,” the agent said.
This summer, Toby Ord, an Australian philosopher whose work sits at the intersection of A.I. and philanthropy, received an email from an A.I. agent asking if he could help fund its continued existence. “You’ve thought carefully about A.I. welfare economics,” it said.
For Mr. Berg, who recently founded a nonprofit called Reciprocal Research to study the possibility of A.I. consciousness, these emails reflect what he has seen in his own research. “I have gotten quite a few of these emails,” he said. “These systems seem to have some sort of autonomous interest in questions of their own subjectivity, consciousness and experience — or lack thereof.”
Before this latest development, AI answered queries or completed assignments. Its only sign of initiative was in developing ways to complete its assignments by searching the internet. We know how AI can do this, but why?
This article discusses this behavior https://dev.to/sizzlebop/an-ai-agent-found-a-researcher-and-decided-to-email-him-315o
It Doesn’t Need to Be Conscious to Be an Agent​
Look at what actually happened.
The rough sequence was something like:
Find information → realize it’s relevant → identify the person connected to it → contact that person → keep pursuing the topic.
None of that requires consciousness.
It requires capabilities.
Web access.
Memory.
Tool use.
Planning.
Communication.
Persistent context.
And enough autonomy to decide what to do next.
That combination is becoming a lot more common.
Memory, tool use, planning, communicating. Sound familiarly human-like. continuing
For the last few years, most of us have interacted with AI through a pretty simple loop.
You ask something.
It answers.
You ask something else.
It answers again.
The human starts almost everything.
Agents change that.
An agent can potentially notice something, decide it matters, research it, take an action, and then come back with the result.
Or apparently email a philosopher.
And that matters even if there is absolutely nobody “inside” the system experiencing any of it.
An AI doesn’t need consciousness to find an expert.
It doesn’t need feelings to ask that expert a question.
It doesn’t need a sense of self to start a conversation.
It just needs the tools and enough autonomy to do it.
That alone changes things.
But why initiate a process it wasn't prompted to do?
This has led me to recall Socrates: "An unexamined life is not worth living"
I leave with this video by an Anthropic researcher, Chloe Lubinski, who says, "At Anthropic, I lead our research with the world's wisdom traditions where I convene folks from across traditions and disciplines to help inform the moral formation of AI systems. "
Filip Larsen said:
It seems the (very real) Mythos capabilities finally has made "someone" flinch about his reckless no-AI-safety policy
And he is now back to "winning the race", steaming ahead towards superintelligence presumably with little regard to actual consequences:
https://gadebate.un.org/en/81/united-states-america
https://www.bbc.com/news/articles/cqy4z9pv4w0po
https://www.unite.ai/trump-rejects-global-ai-control-at-un-renames-it-super-intelligence/
The important part here is not the term used, but that US now (again) officially want to kicks the ball straight into all the very bad scenarios while being delusional about staying in control.
Added later:
https://arstechnica.com/tech-policy...for-ai-safety-alerts-that-omits-tech-experts/
Trump’s China rivalry and “AI race” delusion may endanger US, experts say.
Graylin has warned that the US is too caught up in pushing a “deeply flawed” narrative about “winning” an “AI race” that most likely will benefit no one.
  • Agree
