- Messages
- 19,385
- Reaction score
- 15,623
https://verticalmag.com/news/bell-360-invictus-to-use-429-engine-as-supplemental-power-unit/berkeman said:Well, in fairness, that's its listed cruise speed. Maybe it's got, like, afterburners or something to go lots faster?
205 knots is under 400mph.The aircraft is designed for speed, with the Army calling for a cruise speed of 180 knots, and a maximum of 205 knots.
Seriously? You don't think the military would LOVE to have almost instantaneous transport to a drop zone or a pickup zone (or even "just" Mach 2 if it were possible)? I don't think you've thought that through.Aaronvan said:I don't see the need for Mach 2 helicopter even if it were possible.
Finally, someone that understands aerodynamics and has relatively the same thought as me. The real problem will be those wings though. That's why nothing up to the osprey has succeeded. And the lift and forward flight engines are the same and mounted on the wings that rotate with them. If you put a real even small sized set of wings under a rotor, it either nullifies or destabilizes the lift from that rotor. As for the folding and storing of the rotors, the jet engines could provide the forward thrust while that took place, provided that while thing didn't destabilizes the flight characteristics of the aircraft. There is a crap ton of hurdles to get over to even begin building something that complicated.Dominic Santini said:Well, the best we could possibly do for it would make it a rudimentary plane with very little surface control. It'd be functional; just wouldn't be as effective at dogfighting as planes would be. So, then the problem would be that we need to fill the time gap between folding the helicopter blades (it isn't going to be speedy-- the faster the rotors need to be, the bigger it also needs to get compensatingly so) with something to counter-act gravity with. I estimate that there may be three or four minutes of getting the rotors to cease rotation, and then another minute to fold it inwards. Perhaps less.
I think no one also did reasurch on mach angles created by the main fuselage and how blades would fit inside that angle/cone and as most of the blades stick past the fuselage they would be expost to even greater forcesboneh3ad said:No offense, but I am reasonably sure that you don't know anything about supersonic or hypersonic flight, helicopters, or the challenges involved in designing such vehicles.
So how fast can we get this helicopter to on its rotors until the wings will create enough lift to support the transition, how big would they need to be without interfering with normal hover mode then their is how is everything going to fit in a certain mach angleairwolflover said:I think no one also did reasurch on mach angles created by the main fuselage and how blades would fit inside that angle/cone and as most of the blades stick past the fuselage they would be expost to even greater forces
Then there is the question how big can we make the wings how much speed need to create enough lift.Dominic Santini said:Well, the best we could possibly do for it would make it a rudimentary plane with very little surface control. It'd be functional; just wouldn't be as effective at dogfighting as planes would be. So, then the problem would be that we need to fill the time gap between folding the helicopter blades (it isn't going to be speedy-- the faster the rotors need to be, the bigger it also needs to get compensatingly so) with something to counter-act gravity with. I estimate that there may be three or four minutes of getting the rotors to cease rotation, and then another minute to fold it inwards. Perhaps less.
What on Earth is your point with that statement? LOTS of airframes would go over mach 1 if reshaped and with no rotors, just jets engines.airwolflover said:If you would take the hull of the comanche alone (reshape the nose and without rotors ) it would go like a misile over mach 1
No reshaping required. Anything of any shape can go supersonic with enough thrust.phinds said:What on Earth is your point with that statement? LOTS of airframes would go over mach 1 if reshaped and with no rotors, just jets engines.
Hell, if you reshaped me (it would take some work) and put a jet engine on me, I could probably go over mach 1.
Yes, but it would also fall apart rather quickly if it were not aerodynamic.boneh3ad said:No reshaping required. Anything of any shape can go supersonic with enough thrust.
https://www.physicsforums.com/searc...ter+++Red+Flag&c[users]=Bystander&o=relevanceboneh3ad said:No reshaping required. Anything of any shape can go supersonic with enough thrust.
Not necessarily. Space capsules are not what is traditionally considered "aerodynamic" and they don't fall apart.phinds said:Yes, but it would also fall apart rather quickly if it were not aerodynamic.
At least "no reshaping required beforehand",boneh3ad said:No reshaping required. Anything of any shape can go supersonic with enough thrust.
Hahaha if you would crash and burn at least it would be a exiting way to go out...phinds said:What on Earth is your point with that statement? LOTS of airframes would go over mach 1 if reshaped and with no rotors, just jets engines.
berkeman said:I see what you did there...![]()
Yes and my point was, so what? LOTS of fuselages are capable of that kind of speed. But not helicoptersairwolflover said:What i really meant was the main fuselage is capable off that kind of speed
Read my last postphinds said:Yes and my point was, so what? LOTS of fuselages are capable of that kind of speed. But not helicopters
