Is arcsec = 1 divided by arccos ? Arcsec = 1/arccos
  • Level: Undergrad
  • Thread starter Thread starter Vividly
34 replies · 6K views · last reply
Vividly
TL;DR
Im confused about what 1/arccos is equal too.
Im not sure what 1/arccos is. I looked online and all I have found is y=arccos(1/x) and I am not sure if that's the same thing. I tried to make a triangle to decipher the answer. However when I looked at the answer when I finished it was incorrect. I got 1/xsqrt(x^2-1) and the answer is 1/(arccos)^2 sqrt(1-x^2)
Mathematics news on Phys.org
You could try putting some angles into a calculator or spreadsheet and checking whether ##arcsec \ x = \frac 1 {\arccos x}##.
Alternatively, if we let ##y = \arccos x## and ##z = arcsec \ x##, then ##\sec z = x## ... Can you finish it from there?
You seem to confuse reciprocal and inverse function. Say
[tex]y=\frac{1}{\arccos x}[/tex],
[tex]x=\cos(\frac{1}{y})[/tex]
Say
[tex]y=arccos(\frac{1}{x})[/tex]
[tex]x=\frac{1}{\cos y}[/tex]
I am confused about why you have all those number signs. Is it for a formula in excel? If your say that z=arcsec divided by x is equal to some number or 1/secz=x then x = cosz
Are you saying reciporal and inverse functions do not equate to one another? So 1/arccos(x)≠ arcsec(x) ?
What's a "number sign"? You mean variables ##y, z##?
You do understand that IF ##arcsec \ x = \frac 1 {\arccos x}##, then this is true for any angle ##x##?
That means that:
##arcsec \ 0.1 = \frac 1 {\arccos 0.1}##
##arcsec \ 0.5 = \frac 1 {\arccos 0.5}##
##arcsec \ 1.0 = \frac 1 {\arccos 1.0}##
Etc. Did you try those on a calculator to see whether they really are equal?
Vividly said:
If you’re saying that z=arcsec divided by x is equal to some number or 1/secz=x then x = cosz
I am not used to arcsec function in RHS. I assume it means
[tex]x=\sec y = \frac{1}{\cos y}[/tex] right ?
LHS function means
[tex]x=cos(\frac{1}{y})[/tex]
They are different functions.
That means that:
Arcsec(0.1) =error
I/arccos(0.1)=.6799811946
with that being said they’re not the same. So inverse trig functions have no relation, well at least in this regard. So how can I solve the problem? I don’t understand how to make it possible. I can try the quotient rule but not sure if that will work.
Vividly said:
Arcsec(0.1) =error
So, they don't even have the same domain. Not much chance of being the same function then.
What about? $$arcsec(\frac 1 x) = \frac{1} {\arccos x}$$Does that look better?
Vividly said:
Arcsec(0.1) =error
They both show up as errors. So what would make them show up as actual numbers?
They shouldn't have. Let's try to prove this anyway:
Let ##z = arcsec(\frac 1 x)##, then ##\sec z = \frac 1 x##, and ##\cos z = \frac 1 {\sec z} = x## and ##z = \arccos x##.
So, it seems that we what really want is: $$\arccos x = arcsec(\frac 1 x)$$
I guess what I am asking is how to find the derivative of y=1/arccos with a triangle. I am not sure how to put x=cos(1/y) on a right triangle to find the Hypotenuse, Opposite and Adjacent like I did for this problem.
An interesting idea. If you differentiate ##y = \frac 1 {\arccos x}##, you must get an ##\arccos^2 x## term in the denominator. It's not going to come out as a polynomial in ##x##.
Yes, that's what I don’t understand how that came to be. The answer I get is 1/xsqrt(x^2-1). Did you do the quotient rule or did you do the power rule and bring arccos to the top then take the derivative?
That can't be right. That's the derivative of ##\arctan(\sqrt{x^2 - 1})##.
This sounds like you are seeing the LaTeX code rather than the resulting equations that are rendered. Refreshing the screen may help. Those do not always render properly -- though they showed up well for me.
Also, if you are responding to a post, the LaTeX code is helpfully presented in code form, rather than rendered form. This allows you to see how @PeroK composed the equations so that you can retrieve that quoted code and modify it to use in your response. See the LaTeX Guide below the editing window.
Yes, I made a mistake because supposedly 1/arccosx ≠arcsec. I will try to write out my thoughts again and show you
There's no supposedly about it. They are definitely not the same thing.
Well with that being said, I am trying to figure out how to make it into a triangle so I can know how to solve it from scratch without memorizing. Did you do the quotient rule or reciprocal rule to solve it? I am want to figure out how to get the polynomial under the square root.
There's nothing to memorise to get inverse trig derivatives. You just use the chain rule: $$f^{-1}(f(x)) = x \ \Rightarrow \ (f^{-1})'(f(x))f'(x) = 1 \ \Rightarrow \ (f^{-1})'(f(x)) = \frac 1 {f'(x)}$$ For example:$$f(x) = \tan x \ \Rightarrow \ f'(x) = \sec^2 x = \tan^2 x + 1 \ \Rightarrow \ (\tan^{-1})'(\tan x) = \frac 1 {\tan^2 x + 1}$$$$\Rightarrow \ (\tan^{-1})'(x) = \frac 1 {x^2 + 1}$$
I figured it out
PeroK said:
You have the wrong sign there. The derivative should be positive.
Yes the negative on top and the one at the bottom cancel. I just didn’t show it canceling. Thank you for the help.
What do you get when you put it in a calculator? I tried to resolve the problem but with arcsec(1/x) and got a different answer than the derivative of 1/arccosx
Say
, calculation of its derivative is :
[tex]x=\cos\frac{1}{y}[/tex]
[tex]dx=-\sin(\frac{1}{y})\ \ (-\frac{dy}{y^2})[/tex]
[tex]\frac{dy}{dx}=\frac{y^2}{\sin\frac{1}{y}}=\frac{(\arccos x)^{-2}}{\sin(\arccos x)}=\frac{(\arccos x)^{-2}}{\pm\sqrt{1-x^2}}[/tex]
arccos function is a multi-value function so we should be careful.
What calculation did you do?
For all ##x \in [-1, 1]## we have:$$\cos (\arccos x) = x$$$$\sin(\arccos x) = \sqrt{1-x^2}$$And, for ##x \in [0, \pi]##$$\arccos(\cos x) = x$$But, for ##x \in (\pi, 2\pi]##$$\arccos(\cos x) = 2\pi - x$$
Its completely different. Not sure what I am doing wrong. Unless arccos(x) ≠arcsec(1/x) like I stated at the top right of the board.
