Is dielectric constant calculated from capacitance normalized to thickness and area?
2 replies · 3K views
CNC
This may seem like a dumb question, but is a dielectric constant calculated from a measured capacitance normalized to thickness and electrode area, I’m having a brain fart.
I'm in a bit of a hurry right now but here are some links.
The dielectric constant k is the relative permittivity of a dielectric material. It is an important parameter in characterizing capacitors. It is unfortunate that the same symbol k is often used for Coulomb's constant, so one must be careful of this possible confusion. It is more typical of physics texts to use the form 1/4πε0 for Coulomb's constant.
http://hyperphysics.phy-astr.gsu.edu/hbase/tables/diel.html"
In electromagnetism, permittivity is the measure of the resistance that is encountered when forming an electric field in a medium. In other words, permittivity is a measure of how an electric field affects, and is affected by, a dielectric medium. Permittivity is determined by the ability of a material to polarize in response to the field, and thereby reduce the total electric field inside the material. Thus, permittivity relates to a material's ability to transmit (or "permit") an electric field.
The permittivity of a medium describes how much electric field (more correctly, flux) is 'generated' per unit charge. Less electric flux exists in a medium with a high permittivity (per unit charge) due to polarization effects.
http://en.wikipedia.org/wiki/Permittivity"
Welcome to PF!
Hi CNC! Welcome to PF! :smile:
From http://www.microwaves101.com/encyclopedia/Measure_dielectric.cfm"
There are many ways to measure dielectric constant of a material or effective dielectric constant of a media. You can actually make a career out of this measurement, once you know all the nuances and practice a bit. …
Before we attempt describe any methods in various amounts of detail, let's first point out that 1. dielectric constant can vary with frequency (but usually not a lot) and 2. the measurement techniques can be fraught with errors, which we'll try to explain.
