Is Enthalpy a Valid Concept Despite Dimensional Mismatch?
  • Context: Undergrad
  • Thread starter Thread starter Sailor Al
    Enthalpy
The discussion centers on the validity and relevance of enthalpy in thermodynamics and aerodynamics. Participants clarify that while enthalpy is not a fundamental parameter like internal energy (U) or entropy (S), it serves as a useful shorthand for the combination of U and pressure-volume work (PV). The conversation highlights the importance of enthalpy in aerodynamics, particularly in the context of stagnation points and compressible flow, as outlined in Anderson's textbook on aerodynamics. The consensus is that enthalpy is indeed relevant for analyzing airflow around bodies, especially at speeds approaching Mach 0.3.
  • Understanding of thermodynamic properties: internal energy (U), entropy (S), and enthalpy (H)
  • Familiarity with the ideal gas law and its implications in thermodynamics
  • Knowledge of dimensional analysis in physics
  • Basic principles of aerodynamics, including stagnation points and compressible flow
  • Study the role of enthalpy in compressible flow dynamics
  • Explore the derivation and application of stagnation temperature in aerodynamics
  • Learn about the relationship between pressure, volume, and temperature in ideal gases
  • Investigate the significance of enthalpy in various thermodynamic cycles and processes
Aerodynamic engineers, thermodynamics students, and professionals involved in fluid dynamics who seek to understand the application of enthalpy in real-world scenarios, particularly in aerodynamics and energy systems.
  • #31
Sailor Al said:
I think you will find that the temperature rise from the compression of air on airplane wings and fuselages is not a chemical process and so is not exothermic.
You're quibbling over words. There is heat exchange between the air and the airplane's fuselage and wings. That is precisely the kind of case for which using the enthalpy of the air in the analysis is useful.
Science news on Phys.org
  • #32
I do not think that distinguishing between a physical change and a chemical change is quibbling. In fact, I think it is an important distinction to make, as it can help us to understand the nature of matter and how it can be transformed.
  • #33
Yes, it is. The atoms don't know that they're supposed to be doing "chemistry" instead of "physics" and adjust their heat exchange behavior accordingly. The heat exchange between the air and the airplane's fuselage and wings is the same whether you label it as "chemistry" or "physics".
Which, even if it is true (and you would need to give some very good references to back up your claim here--but that would be a separate discussion), has nothing to do with what we're discussing in this thread. You asked about enthalpy, and you have been given multiple examples now of when and how it is useful. That's what this thread is about.
  • #34
Sailor Al said:
The problem was, as I indicated then in response to his explanation:
and to niels nielsen on the same thread:
As there were no responses to my inquiries on Stack Exchange, I am hoping that Physics Forums may be able to provide an answer.
But the pressure changes are big enough to provide the lift, so while they may be small compared to the atmospheric pressure, they are still very significant and thus will generate temperature changes (PV = nRT). It's not the use of thermodynamics that I am questioning. It's the use of enthalpy that I'm questioning.
The question is a repeat and the answer hasn't changed so there was no need to repeat it: you can use enthalpy or not - it's up to you.
What is the point of all this though? Why does this question matter so much to you? What's wrong?
  • #35
Yes, indeed, the atoms don't care if it chemistry of physics. The only way to influence the atoms is by plasma physics or nuclear physics. But the molecules do care, and that's the vital difference between chemistry and classical physics. Chemical processes alter the composition of the molecules in the system. Physical processes, such as those occurring in aerodynamics (sub-sonic, atmospheric conditions), don't alter the molecular composition of the air. The molecules of the air (O2,N2, etc.) have the same composition before and after any aerodynamic process. When discussing enthalpy, it is important to distinguish between chemical and physical processes. This is not a matter of quibbling, as the nature of the process can have a significant impact on the enthalpy change.
  • Sad
9K
