Is Fluorescent Lighting Polarized?
  • Thread starter Thread starter cchan
    Light
Fluorescent lighting, commonly found in energy-saving bulbs, is not polarized. The light emitted results from stimulated emission from phosphor coatings inside the tube, which is excited by ultraviolet photons generated from mercury vapor. These photons strike phosphor atoms, causing them to emit visible light in a random direction. Since the initial photons are random, the resulting white light lacks polarization. Therefore, fluorescent lighting does not exhibit polarized properties.
cchan
Hi,
I've tried looking everywhere for the answer to this, and would be fantastic if anyone could help me.
Is fluorescent lighting (found in energy saving light bulbs/lamps) polarized?
Thanks
Science news on Phys.org
Surely you can buy a cheap polarized filter and see for yourself?
No ..
The light we see from a fluourescent is due to stimulated emmission from the atoms of a phospher coating on the inside of the tube. Photons in the ultra violet are generated by the electrical excitation of mercury vapor inside the tube, these photons strike the phosphers atoms, raising their energy state forcing them to emit photons in the same direction as the photon that struct them in the visible light range. As the photons created by the excitation of the mercury are random .. the resulting "white" light is random as well .. hence not polarized ...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
