Is gravity an infinite source of energy?
69 replies · 29K views
Xtensity said:
Iwhere did the notion that it's massless come from if we can only confirm that it is under a specific mass?
Theory.
When you are checking things experimentally you can only do the experiment with a finite accuracy. That means you can never say "exactly zero" but "zero within the accuracy of the experiment". Best experimental accuracy so far proved mass is below 10-18 eV.
Similarly - when talking about mass, we in fact talk about two different properties of matter, inertial mass and gravitational mass. Seems like they are identical - but experimentally we were so far able to prove it "only" with accuracy around 10-12 (that was result of Braginski & Panow from 1972, could be there are better results available now).
Astronomy news on Phys.org
Borek said:
Theory.
Yes I understand that, but I don't understand what's preventing smaller particles from existing. If the speed of light is the measured speed of a photon, to as much accuracy as we can measure, would lighter particles not travel faster? If not, why would they not travel faster. Btw please don't interpret this as me trying to "debunk" science, because that's what people have said that's what it appears I'm doing, but I am not, I am trying to get a clear picture, when thoughts/questions pop in my head on various subjects.
You want them to have mass lower than zero?
Massless photon is part of a theory that is already over 100 years old, during this time it was successfully tested over and over. It doesn't mean theory is 100% sure - single, reproducible experiment that will give results differing from predicted is enough to show the theory is limited. But there was no such experiment, quite the opposite - countless experiments proved theory is valid. So it is not only best we have, we are also trying it for over 100 years - and so far we fail to invalidate it.
Note that experiments that try to measure photon mass are in fact trying to invalidate the theory - IF the results of some experiment will be 7+/-2 it will be obvious we were wrong :wink: But so far it seems like photon is massless with a very high accuracy.
There's key words here though. Very high accuracy, "seems like". Of course with such its fragile size that we can not measure it perfectly, as the probability of that is very low. Though I am confused in the area of, if we are so sure that it is massless, then why is there that area of uncertainty?
I realize that the point of experiments is to try to disprove theories, meaning if these attempts to disprove keep failing then the area of certainty increases. When you simply look at the mass range we have confirmed that it IS under a certain mark, but how much lower can it go? Is there a scientific point that separates 0 mass from "> 0" mass? Numbers are an invention to quantify things in reality which has lead us to development of higher mathematics
Massless, means without mass, meaning 0. I very well see the point you are making but the speed of light is based off the photon which we have tested over and over again. How are we supposed to confirm 0 mass. We can't. All we can do is keep experimenting and testing with smaller and smaller numbers, into higher and higher decimal places. There's no doubt that the mass of a photon is under a certain mark, but I fail to see where such a level of certainty comes from that it is completely massless. Surely it would be unscientific to say that it is entirely massless? Of course we can agree that it is under a certain mark, which we can confirm and test, but saying it is completely massless, is a very big claim considering how small numbers can get...infinitely small... which almost represents a logical paradox in itself.
Think of it this way. As technology advances, we are able to measure to higher degrees of uncertainty as the numbers get smaller and smaller. Recently in the past 38 years the level of certainty about Light Speed had increased by 100x. Meaning, what is to prevent technology from continually advancing. We can keep estimating it smaller and smaller, but how small can we go? Do we just assume that it is massless because the range which we can measure it to be under is so small?
How can something that is massless be measured? The only thing we know with a very very high accuracy is that it is under a specific very small range, we can confirm this with test.
Countless experiments only prove that the theory is extremely accurate. For it to be proven 100% valid(that the photon is massless), we would have to be able to measure to infinitely small numbers, can we agree on this? That there IS a level of uncertainty. Meaning that there IS a chance that the speed of light is not top speed, but only the speed of particles with the mass of a photon. Meaning if there is a chance that the photon is not massless, then there could be particles which have less mass, meaning they travel faster. Can we agree on this part? You just said yourself, it doesn't mean the theory is 100% true and accurate, but it is extremely accurate. You must keep in mind how small values can actually go and how small we can currently quantify.
With this all being said, 'is' there a possibility that there could be a particle lighter than a photon, if the photon was not massless. We can't confirm masslessness, we can only confirm mass under a very small range.
Or if what I have said is all wrong, how have we jumped from "range that its beneath" to masslessness... and this can not be based off comparing measurements to light speed as the max speed, because the notion of light speed being the universal speed limit is founded on the notion that the photon is massless, which would in turn be circular reasoning. Also before you misunderstand me, I am agreeing with you on the fact that we can't measure to 100% precision, but we CAN measure it to a very small range... I'm just confused as to why we assume its massless(besides aforementioned speed of light reason)
Photon has energy. E = mc^2. Therefore photon has mass.
See this is where I get confused to a degree. That formula is based on a constant which is derived from a measured speed of a photon.
If c is just the speed of the photon, and the photon has a mass.. If there exist a particle lighter than a photon, then why would we still use C as what it currently is? Or am I misunderstanding something?
Edit: Would this insinuate that we do have a very accurate measure for energy, but the discovery of a lighter particle would also lead to discoveries of a higher speed, which would inturn lead to more accurate predictions of energy content(to higher decimal places)... Since the formula is the energy more or less as mass approaches the limit of 0?
That's just how science works: no measurement can ever be 100% accurate and no theory can ever be 100% proven. So the best we can do is 99.9999999999999% certain.
I realize exactly that, which is why we can only measure to a certain level of mass accuracy.
Does that not defy the Mass–energy equivalence formula to say that the photon is massless, when the formula says otherwise? We know the photon has energy.
Isn't it unscientific to say the speed of light is the top speed? Wouldn't it be more accurate to say it's the highest speed we can measure, but there very easily could be higher speeds if lighter particles existed that we don't have the current technology to measure? I'm sure everyone can agree it will always be unscientific to say we've reached the peak of universal discoveries.
Reading a physics book and understanding the theory first before jumping into doubts/conclusions can solve all your confusions.
What is discussed till now is 100 years old theory and if you comprehend it, you will be in a better position to ask right questions. All the best.
That formula is not saying the photon has mass. That's a common misuse of the formula.
Of course not! A theory predicts it, all evidence we have to date validates the theory, and no other theory exists that can explain the evidence. That's perfectly scientific.
Certainly not. There is no theory that predicts a non-zero mass for the photon that doesn't contradict the evidence we already have.
Of course. That's not what's being claimed. What you're claiming is no less profound: That a 100 year-old, exquisitely well proven theory is wrong. That would be Earth'shattering.
Russ I understand what you're saying, but why is there that area of uncertainty.
Yes there are countless test reverifying that the mass of a photon is very small. Just because no theory exist predicting otherwise does not mean that 'otherwise' isn't true. If a smaller mass, under the already known range, were predicted, that wouldn't contradict the current test done on the speed of light.
I'm baffled at the level of certainty that exist for something so small. I mean, I can completely understand the it being measured under <1×10−18 eV, because we can confirm this.
But we can not confirm masslessness, we can only predict really close to it, which is why it baffles me that we can just say, there is no mass. We can't verify no mass, it's logically impossible, we can only verify extremely small masses.
Edit: you also say
I'm not saying the proven theory is wrong. In fact, I wouldn't use the word proven. All the test that have been done only reassure us that it lies under a certain range. It does not prove massless, it only proves that it is under a certain range.
Or unless you know of a way to measure, the lack of mass. Which would have to go on the assumption that we can measure things infinitely small, which we can't, there's limits to our technology, this fact can not be argued, the method can though. So if you have some method I am unaware of for measuring masslessness or infinitely small numbers, please do post it.
We're starting to go in circles here: It is a combination of logic and measurement imperfection. The uncertainty in the measurement exists because it is impossible to have 100% measurement accuracy. At the very least, measurement devices are man-made and therefore have flaws that can never be completely eliminated.
And logically, the uncertainty in the measurement plus the fact that you can't ever measure the speed of every photon means that you can't ever prove that every photon moves at C.
Do not make the mistake of believing that this little opening is a place where scientists should be looking to build a theory of a massive photon. It's simply a demonstration of the level of scientific certainty and its limits.
Of course: Being 99.999999999% sure of one thing means there is a 0.0000000000001% chance that there is something being missed.
That's not quite right. First, the prediction is masslessness. I think you meant measurement: A measurement would say something like 0.01 +-.02, which verifies that the mass is somewhere between -.01 and +.03. .03 is an upper bound in the range. So the experiment verifies no mass (because 0 is inside that range) to within a certain accuracy.
We both agree there is that level of uncertainty. Can we agree that the possibility for a very small mass of a photon does exist, we just can't measure it? The theory of a "massive photon" would not contradict any theories, other than the notion of it being massless(which can't be 100% accurate obviously).
I'm not trying to establish any scientific theories here, just trying to establish that the possibility 'does' exist. It's talked about as if it's nonexistent, when it very well may be measurable in the future.
(also if you want to take the time, could you clarify why "That's a common misuse of the formula.", so I can understand for future references)
Isn't mass just energy in a different form? And a photon is just energy? Which would make it impossible for a photon to have mass(per definition that is)?
That would clarify a lot if true, but if that's true, then what is the entire point of attempting the measure the mass of a photon?
I think this shouldn't really be discussed here, but well. No theory can be 100% proven. The entire point of measuring the mass of a photon is in my opinnion that it would disprove the theory "directly".
And I think this is the mistake:
"The theory of a "massive photon" would not contradict any theories, other than the notion of it being massless"
The theory is not just one notion. Measuring the mass of a photon would disprove the entire theory of relativity, and probably some other things and concepts too.
It wouldn't disprove the theory of relativity because we have already tested it and can verify a large portion of it. It may alter the theory, but that's it.
If a photon mass was discovered then it could lead to the discovery of other particles, which would make it so there would be better numbers to use than c in the mass equivalence formula... but the overall measure of the amount of energy would only change slightly. It would expand the formula or open up another formula for use.
The discovery of a potential massive photon would not destroy all of the current theory of relativity, I don't understand how you can say that when a majority of it has already been proven. All it would do is redefine it and make it more accurate.
Edit: If you haven't realized, Massless is not an undefinable number, massless means 0. Think of it this way, if a mass was discovered for a photon(smaller than we can currently measure obviously), then it would just move the scale up slightly. I don't see how you can say it would destroy the entire theory.
I am not an expert on R.T., but am pretty sure it would destroy it, someone might back me on it. But again, it really shouldn't be discussed under this topic.
Also you should understand that no theory can be 100% proven, that's how physics works.
I understand no theory can be 100%.
If it would destroy it, I am curious as to why, because from my PoV that doesn't seem like it would happen, but I'm probably wrong..
Of course it's possible that photons have mass. It's also possible that I'll quantum-tunnel my way into your room after I make this post to tell you that in person.
I am not aware of any coherent theories that predict a massive photon. When you come up with one, let us know. Otherwise it makes no more sense to talk about a massive photon than it does to talk about a 5-headed unicorn that lives underneath the Gobi desert.
That wasn't what I was insinuating. If any mass was discovered, it would be so small that it wouldn't make a difference in any practical application.
When I was talking about the possibility, I was saying that numbers can get infinitely small. Meaning there could be several trillion+ smaller numbers that we simply can't measure to because we don't have the technology, a number which would infact represent the mass of a photon. Even if it did have a mass why would that matter... What's 0 compared to 0.0000000000000000000000000000000000000001? Any mass that the photon could have would be so small that it wouldn't make much of a difference in calculations. Of course a massless photon would allow the theory to work fine because most often no one deals with calculations that near the speed of light or in that potential decimal range of accuracy(if the photon had mass). Sure measurements are done all the time, but we can only be so accurate. Meaning if the speed of light was derived from a particle believed to be massless, and that particle ended up not being massless it wouldn't make much of a difference. We already know what we can do with the formula and the photon having 10x^-200 more mass than we thought it does isn't going to change anything, besides what we believe to be the fastest speed possible. The formula would just become more accurate.
I still don't understand how it would totally destroy the theory of relativity if we have tested it countless times so we KNOW for a FACT that we are in the right range and the calculations are accurate. Explain to me how a photon with even 10x^-200 mass more than 0 would destroy this theory.
Even if the photon had 10x^-200 more mass than we thought(0) then it still wouldn't make a difference because how often do scientist deal with numbers in the 200 decimal range?
Explain to me what point you're trying to make. You seem to just want to be contrarian for no reason at all.
? I'm not opposing anything really. I agree the photon has an immeasurable mass(with todays technology), but I simply feel that saying it is massless is quiet a jump considering how infinitely small decimal numbers in terms of mass could get.
I'm also curious how it would destroy the entire theory. That doesn't make any since when we can verify that the theory is extremely accurate for modern uses.
Just the part that's disturbing me the most is the notion that its massless when the chances are MUCH higher that it could just have a mass of an number very small(in the 50-200+ decimal range for say electron volts) or very hard to measure. I understand its accepted as massless for modern purposes, but to actually believe it has no mass it quite an assumption given the odds and the fundamental nature of numbers.
I'll address specific points when I have more time after work, but...
This posture you are taking of scouring the error margins of current experimental proof for a place to keep your emotion-based objection to a exquisitely well proven scientific theory is *highly* unscientific and will prevent you from ever learning how the universe works if you don't fix it.
I have no emotionally based objection. The entire reason I am forming this viewpoint is because of logic. It is logic which allows us to understand that numbers can be infinitely small. I am probably the most open minded person you will meet, but I still try to be logical with my opinions.
Last time I checked, it is highly unscientific to say any number is certain. It's like, if you have a graph, and you take the area under the curve to find the percentage likely hood of landing in that area, if you take 1 number, the chances are extremely slim. Which is why it is much more likely that it is in a range, and not at a specific number; this is basic statistics. It is also very likely that we simply can not measure numbers that small and the most accurate we can currently get is 0, saying we have perfect measurements is unscientific. It's like when they believed the atom was the smallest particle.
I am extremely open minded but I try to use logic when I form my opinions. I'll appreciate any effort you make to helping me understand this, but as far as I can currently see, the most rational choice in terms of probability is that the Photons mass is smaller than we can measure. It could be massless, but that's quite an unscientific assumption in terms of numeric probability and I fail to see how it would totally destroy the theory of relativity.I can assure you my opinion is not emotionally based, I am just not so suaded when I see more probable evidence. Regardless of what my opinion is on the subject, it won't effect my life in any way. If it's on a test, then I'll study what will be on that test.
The only reason I'm seeming so stubborn is because I don't comprehend how you can argue that its unscientific despite the odds. Everyone past 6th grade math should understand numbers can be infinitely large and infinitely small.
In Relativity there is a huge difference between 10^-200 and 0 when it comes to mass. Only particles that have exactly zero mass are required to travel at c and only at c. The smallest amount of mass whatsoever means that the particle is allowed at any speed from 0 to almost c. If photons had any mass at all they could travel at any speed. However, we only measure photons as moving at c. We never measure any photons (in a vacuum) traveling at 0.99c or 0.1c or 5 km/hr.
No, a photon does not have mass. You are using the wrong formula. Try using the complete and correct forumula:
[tex]E^2 = m^2c^4 + p^2c^2[/tex]
CS
Thank you.
Very informative, something very obvious that wasn't so apparent to me.
That 1 post just practically solved the entire thread and my confusion, and it's basically what I was asking for the whole time. Thank You again. I don't see why it takes 4 pages of asking why and why not to get that kind of simple explanation.
I had to register and comment on something somebody said on page 1.
They said that tidal energy harnesses the rotational energy of the earth. If the Earth were not rotating at all, the tides would still be affected by the rotation of the moon.
The Earth would have to be rotating in sync with the moon for there to be no tides. If the Earth were rotating faster opposite to the moon, the tides would be faster.
So where does the energy come from? the moon's kinetic energy? or the difference in rotation between the Earth and moon?
If you were to harness both the "ebb" and "flow" would the supposed rotational impact cancel out? When the moon is directly above you, does it create "anti-gravity" in relation to objects on the earth? do objects become lighter in relation to the earth?
When the moon is on the direct opposite side of the earth, does gravity increase for objects on the opposite side of the earth? do objects become more heavy?
