Is it possible to convert/transform Electricity to matter
The discussion revolves around the possibility of transforming electricity into matter for the purpose of creating thrust, particularly in the context of thruster technology. Participants explore theoretical and practical implications, including the feasibility of using electricity to generate ions or plasma for propulsion, as well as the limitations imposed by the laws of physics.
  • Experimental/applied
  • Some participants propose that transforming electricity into matter for thrust is theoretically interesting but may not be feasible due to the law of conservation of energy.
  • Others argue that while direct conversion of electricity to matter may not be possible, electricity can be used to create thrust through existing technologies like ion propulsion.
  • A participant mentions that creating plasma from electrical discharge does not require converting electricity into matter, suggesting alternative propulsion methods using Earth's atmosphere.
  • There are discussions about using pulse jets and electrical discharges to generate thrust without traditional fuel sources.
  • Some participants reference mass-energy equivalence and speculate about the potential for high-energy collisions to create thrust, including the role of magnetism in enhancing efficiency.
  • Concerns are raised about the efficiency of ionizing air for propulsion, with references to specific impulse as a limiting factor.
Participants generally agree that direct conversion of electricity to matter is not feasible, but multiple competing views remain regarding the use of electricity for thrust generation through other means, such as plasma and ion propulsion. The discussion remains unresolved on the practical applications and efficiency of these methods.
Limitations include the dependence on definitions of energy and matter, as well as the unresolved efficiency of proposed propulsion methods. Some participants express uncertainty about the practical implementation of their ideas.
Individuals interested in propulsion technology, physics of energy conversion, and advanced thruster designs may find this discussion relevant.
GurfX
Hello,
For a future development, Me and a friend of mine were talking about some thruster technology and we wondered if it was possible to transform electricity to matter to create some sort of chemical thruster or using the matter to create an ion and use it as the thrust. well at least something like that and if that wasn't possible (which law of conservation of energy says so) then i have something below. I also heard something about transforming light to matter and you make light from electricity right? so if you can do that then could you use the matter created to make ions
Anyways i have an energy source (however big it needs to be) and the thruster which needs to be able to lift something like 100kg, what is needed and how could it be done. if at all possible, what type of different approaches can it be done in.
I think you forgot this "energy can neither be created nor destroyed but transform form one form to the other. "
Yeah, its included in the law of conservation
The short answer is that no, you won't be able to transform energy, whatever its form, into matter. (I'm not saying it is not possible, just that it's not the answer to your problem.)
I don't know much about the subject, but I would venture to say that to lift 100 kg, you will need a chemical rocket, an airplane, or a helicopter.
The energy/matter rate of conversion of energy to matter is well known - and large by any practical measure.
I respectfully disagree (to some extent)
<< inappropriate source deleted by Mentor >>[/color]
But anyways if its not the answer could and electricity somehow be converted to a sort of thrust
Electricity is converted to low-level thrust in existing spacecraft . Can you research that please and post any specific questions about that reading?
Yes i have researched some information about spacecraft propulsion but my focus is not on outer atmosphere thrusters, rather in Earth's atmosphere but the only one i found usefull was using ion propulsion to creat thrust using electricity to make ions for thrust
You think you can do better than NASA in your design? :smile:
If you have a gas such as Earths atmosphere available, then the creation of a plasma by an electrical discharge would not require the conversion of electricity into matter.
Another technique could be to build something like a small pulse jet fired by a pulsed electrical discharge rather than a liquid fuel.
https://en.wikipedia.org/wiki/Pulsejet
haha no, not at this moment at least. but what I mean is that i don't want to use some of their projects because for example a solar sail *won't work on earth
So for the plasma thruster, you can just use electricity to create a hot plasma from the air and to use it as a propellant? If I'm correct...
And for the pulse jet, they do require fuel as shown in this diagram
Yes, traditional pulse jets do require fuel to burn with air containing oxygen and so produce hot combustion products. You should be able to use an electrical discharge to do the same, without any fuel, just the discharge. The pulse would be a discharge of plasma heated air. Inlet valves would allow cold air to enter the plasma chamber, the cycle would then repeat with the next discharge.
Perfect, my friend was thinking the same thing but without the pulse jet engine. Great idea, thanks.
In physics as per mass-energy equivalence we can convert. even at thigh temperature even photon -photon collsions lead to create mass I hope we can do the same in case of electric current but i hope even magnetism can play the role in it .
Brilliant question!
yep e=mc2 makes heat give the atom more mass virtually(if I am correct) so its why plasma or a hot gas can be used for propulsion, noticed it when welding and had a hot gas inside a cube with a hole, all the hot gas trying to escape made the cube move a little
By this do you mean using magnetism to speed up atoms to create more high energy collisions for more thrust efficiency?
Yes My friend.
Yes, a very good idea. hope to make this into practice soon
Well I think we need high energy for this purpose ..
haha yeah my next problem (ironman did it :smile:)
Thread closed for Moderation...
Thread will remain closed because of the low signal to noise ratio of the discussion.
To the OP -- please do some reading about Specific Impulse: https://en.wikipedia.org/wiki/Specific_impulse
You will find that trying to gain propulsion by ionizing air is extremely inefficient.
