Is it possible to integrate acceleration?
5 replies · 2K views · last reply
Madtasmo
Alright so I was just messing around with Lagrangian equation, I just learned about it, and I had gotten to this equation of motion:
Mg*sin{α} - 1.5m*x(double dot)=0
I am trying to get velocity, and my first thought was to integrate with dt, but I didn't know how to. And I'm not even sure it's possible, anyways, thanks!
##\int \sin(x) dx = -\cos(x)##
That is the general form for integrating ##\sin(x)##.
Turns out it's possible to do so;
X(dot)=2/3*gt*sin(α)
Surely you’ve seen ##\ddot x = ## constant.
To find ##\dot x## you use ##\ddot x =\frac{d}{dt}\dot x## and separate.
Another common trick worth knowing is from the chain rule:
$$ \frac{d^2x}{dt^2} =\frac{d\dot x}{dt} =\frac{dx}{dt} \frac{d\dot x}{dx} =\dot x \frac{d\dot x}{dx} $$
For example, if you have Newton’s law in the form ##m\frac{d^2x}{dt^2}=F(x)## then the chain rule makes it separable, from which we get the (1-D) work energy theorem (for point masses).
Isn't your alpha a function of time too? If alpha were constant, integrating would be trivial. But is'it? What is the physical system described by the equation?
