Is More Work Done By Lifting an Object Diagonally or Straight Up?
In summary, the conversation discussed whether more work is done by lifting a 2.3kg mass diagonally or straight up from a resting place on a table. The correct answer is false, as the same amount of work is done in both cases, but in the diagonal case, some additional work is done to give the object horizontal velocity. However, this additional work does not contribute to the change in gravitational potential energy and is eventually cancelled out when the object comes to a rest. Therefore, in an ideal scenario without friction, no net work is done when lifting an object horizontally.
Morhas
23
True or False: To raise a 2.3kg mass from its resting place on a table, more work is done by lifting it diagonally than lifting it straight up.
w=fd
True: I argued that although the same amount of force is being applied vertically, some force needs to initially be applied in the horizontal component, thus making the overall work greater.
Correct answer is false
Gravity is a conservative field.
Work goes to potential energy which is given merely by the m*g*Δh without regard to the path it took to get there.
Your argument is actually a pretty good one. Some work is indeed done by the force applied initially. But that is not the entire story - what happens after you lift the mass?
The question didn't even specify it was a frictionless system, so there would be air resistance as well.
@Lowly Pion: I'm not sure I understand. Although work is still being done and converted to gravitational potential energy, wouldn't an additional force have to be applied to start horizontal translation. I guess you could say that it would be an infinitely small force over an infinitely small interval of time, but it is still a force nevertheless.
@Naresh: What does happen after you lift the mass? In both cases they would have the same gravitational potential energy, just in one case slightly more work was done to achieve it.
If there is air resistance, you obviously do some additional work since the field is not conservative - but let us ignore friction for now.
So you did some additional work and gave the object some horizontal velocity. What happens to that horizontal velocity? The additional work you did was not to achieve the change in gravitational potential energy..
I agree.
Since the force vector is always pointing donwards, due to acceleration produced by gravity, then the work that is being done in both cases is the same.
I'm afraid I don't understand that argument.The horizontal velocity will remain constant, but I don't see that being relevant since a force was still required to start it. While the additional work done didn't achieve any gravitational potential energy, additional work was done.
It doesn't matter. Look at the equation:
W=F*d
If you lift it a certain distance straight up, the force required will be greater than if you had to lift it diagnally. However, if you lift it diagnally, less force is required, HOWEVER, you cover a greater distance, which compensates for the smaller force.
So if I lift a brick a foot off the ground diagonally over a 1000m distance, it would take the same amount of work to lift it straight up?
I have done the same work vertically, but I have also done fd horizontally. (Sorry that was poorly worded)
Just looking at the horizontal component of the displacement, force, velocity etc.:
Initially you apply a small force to get the object moving in the horizontal direction. This does work, and in the absence of friction, imparts some velocity to the object. The work, therefore, has gone into increasing the kinetic energy of the object.
When the object eventually comes to a rest, it has no horizontal velocity. Its kinetic energy has been removed, therefore some negative work has been done on it. This means you applied a force in the reverse direction. Again, in the absence of friction, the negative work done to stop the object is equal in magnitude to the work done to get the object moving horizontally. Therefore, if you move a brick a km horizontally, you don't do any net work. (In your equation W = F.d, F is not constant, it changes sign). The only work done goes towards increasing the potential energy of the object.
This may be hard to imagine because there is always friction in the real world, so one is always doing some work to overcome energy dissipation. But in an "ideal" world, there is no work done when something is moved horizontally.
Related to Is More Work Done By Lifting an Object Diagonally or Straight Up?
1. What is the difference between classical physics and modern physics?
Classical physics refers to the laws and principles that govern the behavior of macroscopic objects, while modern physics deals with the behavior of subatomic particles and the laws of quantum mechanics.
2. How does Newton's first law of motion apply to everyday life?
Newton's first law, also known as the law of inertia, states that an object at rest will remain at rest and an object in motion will continue in motion with a constant velocity, unless acted upon by an external force. This can be seen in everyday life, for example, when a car comes to a stop when brakes are applied or when a ball continues to roll until friction brings it to a stop.
3. What is the difference between speed and velocity?
Speed is a measure of how fast an object is moving, while velocity is a measure of how fast an object is moving in a specific direction. This means that an object can have a high speed but a low velocity if it is changing direction frequently.
4. How does gravity work?
Gravity is a force of attraction between two objects with mass. The greater the mass of an object, the stronger its gravitational pull. This is why larger objects, like planets, have a stronger gravitational pull than smaller objects.
5. How does the concept of energy relate to physics?
Energy is a fundamental concept in physics and is defined as the ability to do work. It is closely related to the laws of motion, as work is defined as a force acting on an object to cause a displacement. In physics, energy can exist in different forms, such as kinetic energy, potential energy, and thermal energy.
