Is my attempt to derive Gauss' law correct?
9 replies · 2K views
SothSogi
Hi there. I am trying to derive Gauss's law from the divergence. I would like to know if it is correct:
The divergence is defined as (I saw this on Fuller & Byron "Mathematics of classical and quantum physics")
\nabla\cdot\textbf{E}=\lim_{\Delta\tau\rightarrow0}\frac{1}{\Delta\tau}\int_\sigma\textbf{E}\cdot d\boldsymbol\sigma
Then I made the following
\nabla\cdot\textbf{E}=\lim_{\Delta\tau\rightarrow0}\frac{1}{\Delta\tau}\int_\sigma\textbf{E}\cdot d\boldsymbol\sigma=\frac{1}{d\tau}\int_\sigma\textbf{E}\cdot d\boldsymbol\sigma
So then, for a point charge and taking the dot product for a spherical surface element
\nabla\cdot\textbf{E}=\frac{1}{d\tau}\int_\sigma\frac{q}{4\pi\varepsilon_0\vert\textbf{r}\vert^2}d\sigma=\frac{1}{d\tau}\frac{q}{4\pi\varepsilon_0\vert\textbf{r}\vert^2}\int_\sigma d\sigma
\nabla\cdot\textbf{E}=\frac{1}{d\tau}\frac{q}{4\pi\varepsilon_0\vert\textbf{r}\vert^2}\left(4\pi r^2\right)=\frac{1}{d\tau}\frac{q}{\varepsilon_0}
Now ##
q=\int_V\rho d\tau
So
\nabla\cdot\textbf{E}=\frac{1}{d\tau}\frac{1}{\varepsilon_0}\int_V\rho d\tau=\frac{1}{\varepsilon_0}\int_V\rho\frac{d\tau}{d\tau}
So
\nabla\cdot\textbf{E}=\frac{1}{\varepsilon_0}\rho
##Thanks for taking the time to read it.
Hi,
Thank you so much for putting your equations in Tex form!
There are two forms of Gauss's law (see Wikipedia https://en.wikipedia.org/wiki/Gauss's_law), the integral form and the differential form. From your conclusion, it sounds like you are trying to prove the differential form, ##\nabla\cdot\textbf{E}=\frac{1}{\varepsilon_0}\rho##
It looks like you are supposed to use Coulomb's law.
Your solution looks basically OK, following the correct logic. You use of infinitesimals such as ##\Delta \tau## and ##d\tau## seems a little off. For example, you write ##\int_V\rho\frac{d\tau}{d\tau}##. This expression is malformed. ##\frac{d\tau}{d\tau}## is unity and the integral becomes ##\int_V\rho##, which doesn't make sense.
Hi,
I am not an expert but if you assume that the E field is that of a point charge then how would this be a general derivation? Personally, i like the derivation using solid angles method but it gives the integral form of Gauss law.
Yes, Pumpkin, I see what you mean. Do you think the assignment is to derive the differential form starting with the integral form? I mean, we have to start with something. It seems we could also start with a general form for the electric field, as below. Do you think that is the starting point the instructor intended?
##E(x)=\int_V \frac{\rho (x^\prime) (x-x^\prime)}{|x-x^\prime|^3}d^3 x^\prime##
Yes, i think you should use that Expression instead.
Does your course include the use of delta functions? If we take the divergence of the integral we will get an expression involving delta functions.
Well, I don't know much about electrodynamics but once you have the integral form it's pretty easy to switch to derivate form:
$$\int_S (\mathbf E⋅\mathbf n) dA = \frac Q {\epsilon}$$
$$ \int_S (\mathbf E⋅\mathbf n) dA = \frac 1 {\epsilon} \int_V \rho dV$$
Using the divergence theorem
$$ \int_S (\mathbf E⋅\mathbf n) dA = \int_V ∇ ⋅ \mathbf E dV $$
so
$$\int_V ∇ ⋅ \mathbf E dV = \frac 1 {\epsilon} \int_V \rho dV $$
Since ##\epsilon## is constant the above equality is true only if
$$ ∇ ⋅ \mathbf E = \frac {\rho} {\epsilon} $$
Ok, thank you very much to all! There are some things you mention that I honestly do not know, like for instance the delta functions. But it is now clear where my mistakes were and how to derive it using other methods.
Thank you.
