Is Newton's 3rd law sufficient to explain buoyancy force?
The discussion centers around the physics mechanism that results in the buoyancy force, specifically examining whether Newton's Third Law is sufficient to explain this phenomenon. Participants explore the relationship between forces exerted by water and the concept of pressure differentials in a fluid context.
  • Some participants assert that while Newton's Third Law describes the interaction between the object and the water, it does not fully explain buoyancy, which requires an understanding of pressure differentials in a hydrostatic situation.
  • One participant suggests that the upward force on the object is a result of the pressure differential, where the forces on the top of the object are less than those on the bottom, leading to a net upward buoyant force.
  • Another participant emphasizes the importance of not confusing third law pairs with forces in equilibrium, indicating a nuanced understanding of how these concepts interact.
  • A later reply mentions the mathematical approach to calculating buoyancy force through integration of the stress tensor over the surface of the body in contact with the fluid.
Participants express differing views on the sufficiency of Newton's Third Law to explain buoyancy. While some acknowledge its role in the interaction, others argue that a complete explanation necessitates consideration of pressure differentials, indicating that the discussion remains unresolved.
Participants highlight the need for a hydrostatic assumption and the complexity of forces acting on different points of the object, which may not be fully captured by Newton's Third Law alone.
PhysicsNowApple
I assigned a question: Explain the physics mechanism that results in the buoyancy force.
Some students replied: The floating object is interacting with the water. Therefore it exerts a downward force on the water. The water then exerts an upward force on the object due to Newton's Third Law. This force balances the weight of the object. I was looking for the standard: variable depth pressure causes a pressure differential that results in the buoyancy force.
Now I feel that their explanation is not sufficient but I was wondering how to go about addressing their answer because I feel like if I am not careful I might obfuscate their understanding of Newton's 3rd Law.Thank you,
The 3rd law just states that the force of the water on the object is the negative of the force of the object on the water. To actually explain buoyancy you need the pressure differential, which in turn results from assuming a hydrostatic situation in a gravitational field.
Hmmm, so perhaps to address this I should point out that technically the water is exerting a force along all points on the object, so using Newton's third law I cannot find a net force upward. Only by using the pressure differential, do we see that the forces exerted on the top of the object are not as large as the forces exerted on the bottom of the object and then we are able to get a net buoyant force?
https://en.wikipedia.org/wiki/Buoyancy said:
The buoyancy force exerted on a body can now be calculated easily, since the internal pressure of the fluid is known. The force exerted on the body can be calculated by integrating the stress tensor over the surface of the body which is in contact with the fluid:
d53e8b6668b8f0850ba54ec5999a6b04d8256cb4
The surface integral can be transformed into a volume integral with the help of the Gauss theorem:
59aa810e63b67d23daabe691fbd06e8879d425b5
where V is the measure of the volume in contact with the fluid, that is the volume of the submerged part of the body.
It is vital not to confuse the idea of third law pairs and Forces in Equilibrium (which is a special case).
  • · Replies 17 ·
11K
17K
  • · Replies 24 ·
