Is potential energy real or fictious?
74 replies · 19K views
My god you people keep on arguing on what is real or not, even making me confused when I wasn't before.
Look, energy is force * distance. When you are repelled by an object, it exerts a force on you. Your kinetic energy is converted to potential energy, which determines how close you get to the object before stopping.
For god's sake.
A.T. said:
"Making sense" and "understanding" are rather vague subjective terms and quite irrelevant to the goal of physics: making quantitative predictions. The concepts allow us to do this. Whether the concepts are intuitive to some person is very individual.
Absolutely. √-1 makes very little sense to most people at first but it soon becomes meat and drink to those of us who have got over the initial "doesn't seem right" reaction. Some of the most abstract concepts get to feel at least as concrete as length and force when we use them regularly.
It's not unlike the taste of beer - which nearly all kids will gag at but most of us blokes find most acceptable.
Michio Cuckoo said:
For god's sake.
Deepest sympathy.
We do a lot of angels on pinheads here.:biggrin:
The problem is that your approach may be a bit too simplistic if you want to progress to higher levels of this game. For instance, your definition of Energy is usually regarded as the definition of Work.
That is perfectly fine, but then it isn't real in the sense that some of the other concepts in physics are, its bookkeeping.
All of physics is book keeping. What is a force except a number that is used to describe a change in momentum. It may seem more real because you can see something move. If you define that to be real, then you are correct.
Every physical system can be described in a formalism that uses only energy and not force. Very little modern physics considers forces at all. Instead, the formalism of Hamiltonian Mechanics is often used (I have to admit that a friend recently published a paper that heavily relied on forces for her analysis) which is based on kinetic and potential energy. Since the Newtonian and Hamiltonian Mechanics can both equally well describe the world without reference to the other, it seems to me that their basic components must be equally real.
Also, look up Aharonov-Bohm effect. It is certainly not the same thing, but since the relationship of force to force field is similar to energy to potential field it might help convince you. In short, this effect shows that the electromagnetic potential field can have measurable effects on particles where there is no electric field. Weird, yes. Also very real.
What level of physics have you studied? I expect that when you get to an upper level Mechanics course and QM, you will be better convinced that potential energy and forces are on the same level. As to using the word "real", leave it to the philosophy majors. They need something to do.
Nano-Passion said:
[..] I said the previous statement on the assumption that potential energy was supposed to be a type of energy that affects the system's behavior, but now I see that not everyone follows that paradigm.[..]
You may say so - I did not see all comments here, but that one looks fine to me - in that sense you could argue that potential energy (or at least, a difference or a ratio between potential energies) is "real". :-p
For example a clock at higher gravitational potential (cet.par.) is found to be ticking faster, but a clock with equally more kinetic energy is found to be ticking at the same rate* - which also goes to illustrate, as mentioned earlier, that kinetic and potential energy could be said to be equally "real". :smile:
*for references you can look up information about satellite clocks or clocks on the geoid in relation to GR.
I'm not sure who defined the definition for the goal of physics. Physics, for many, is the quest to understand nature. To understand nature, it would help to realize what is a derivative and what might be an inherent part of nature--not be a calculation monkey.
A.T. said:
The original question was whether potential energy is somehow "more made up to ensure CoE" than other forms of energy. It's not. All the formulas to calculate various forms of energy are designed to ensure of CoE. Without CoE the concept of energy would be useless.
Okay good point, see post below.
sophiecentaur said:
and many other quotes.
You are being very selective in your appreciation of Science. You base the above statement on a very narrow appreciation of the three example quantities. How can you be any more 'aware' of the presence of a mass or a charge other than by how they are reacting with you or something else? You drop a mass on your foot but its effect (how painful it gets) depends entirely upon its gravitational potential energy where you let it go. On Earth, it might break your toe but on the Moon it may just bounce off your shoe.
You are trying to impose a very personal view on all of this. Moreover, the further this thread goes, the more entrenched you seem to be getting. If you go away and think about this, rather than bouncing back with more and more arguments, trying to justify your view, then you may start to realize the advantage of thinking the way 'the rest of us' are thinking. When you do come to that conclusion, don't think of it as having been proved wrong. Just feel and enjoy the enlightenment. None of this is 'real'; it's just ways of thinking about things which allow us to make good predictions.
Okay I'll keep an open mind. But I don't understand why you choose to define the object's acceleration based on potential energy.
In this case, it can easily be described with kinetic energy and time. See I guess I don't have as much respect for potential energy because it seems to be a derivative, though I have no doubt that it is really useful.
Kinetic energy is very similar to potential energy in that they are both energies required to do work. But let us look closely at their definitions. Kinetic energy is the energy of an object in motion while potential energy is the energy stored, dependent on its position in a field.
Next thing, I'll define real as something that has a direct or indirect affect in a field.
So let us imagine a gravitational field and our choice of explaining gravitational acceleration is the graviton. Gravitons can give things kinetic energy, so long as there isn't an opposing force of equal magnitude. I realize that the definitions of energy are relatively arbitrary in a "real" sense, but you can describe the work being done on an object by kinetic energy alone. Gravitons can not however give something a potential energy, it is a more arbitrary definition. What the gravitons will do is increase an object's velocity, which we can arbitrary define as kinetic energy. However, gravitons will not increase potential energy, that only depends on an arbitrary reference point that are useful for calculation.
With this respect, kinetic energy is more real than potential energy.
I'm sure it has been said before in this thread, but I thought I'd chime in: Only differences in potential energy are physically meaningful.
For god's sake.
Absolutely. You can measure and perceive directly a force and a distance. The single step of multiplying them together, then labeling that quantity somehow causes some people great consternation.
Nano-Passion said:
Some things are more fundamental than others. This has been the case ever since we have looked for equations that describe the very small and ever since the search for unification.
Nonsense. Cite one prominent scientist who has ever referred to concepts that way.
I'm not sure why it is noted that kinetic and potential energy are on the same scale.
The kinetic energy "of an object is the energy which it possesses due to its motion. It is defined as the work needed to accelerate a body of a given mass from rest to its stated velocity.
Potential energy "is the energy of a body or a system due to the position of the body or the arrangement of the particles of the system"
Kinetic energy is more tangible in the sense that we can use it to describe a lot of everyday phenomena such as the energy imparted on a ball by a bat swing. Potential energy seems like an accountant's tool to make sure all the toys in the box and out count up to X.
I can use potential energy to describe a lot of everyday things as well, such as a car's behavior going up and down the hill -- not to mention you also need it when analyzing what happens between the bat and the ball. You have not provided an actual difference between the two: If one is an accounting trick, then the other is as well.
Again, all this is is your personal "feelings" about certain types of energy. There is no value here for physics.
I find that offensive, there are a large number of physicists who try to understand the laws of nature. Physics is more beautiful than book-keeping, which, in this respect, is a slightly offensive term that I used for potential energy. And I'm not talking about the romanticized view of physics either, calculations and problem-solving included of course.
Well that depends, just because something describes something else well does not mean its real. You only have to look at all the past false-leads in physics.
Also, look up Aharonov-Bohm effect. It is certainly not the same thing, but since the relationship of force to force field is similar to energy to potential field it might help convince you. In short, this effect shows that the electromagnetic potential field can have measurable effects on particles where there is no electric field. Weird, yes. Also very real.[/quote]
The Aharonov-Bohm effect puts a very good case on the table. One thing I noticed in physics is that many things can be redefined in different ways with a couple substitutions here and there (or even under a different paradigm). I wonder if that might be the case here, but given that I don't have the knowledge to dispute it, it is only fair to accept the phenomena.
Quite early in my study, I've studied some modern physics and a bit of classical mechanics (the work and energy section). But I'm still waiting to take modern physics next semester.
Yes, I'm aware of time dilation. Thing is though, I'm not completely fond of the potential energy concept to explain time dilation. Classical mechanics shouldn't take center-stage in this phenomena if you want to have a non-superficial understanding of the mechanics at work.
You can describe it after it has happened with kinetic energy and time, but unless you use potential energy, you can't calculate ahead of time what is going to happen [to an object you drop] without potential energy.
You keep repeating the definitions over and over as if there is a meaningful philosophical difference there: we keep telling you there isn't. Not to scientists/engineers.
Gravity can, of course, act to change an object's potential energy. That's what happens when you drop something. You can also use the potential energy of one thing to change the potential energy of another: that's what a seesaw does. Moreover, since there is more than one type of potential energy, you can use one to change another: gravitational potential energy to increase spring potential energy, for example.
I submit that you don't know what you are talking about. What you display here is a deep misunderstanding of what physics is and so it is pretty silly for you to claim to know how physicists think.
I'm not sure that the goal of Physics has ever been defined but I'm sure that it has never seriously been based an attempt to make people feel 'comfortable' with it. If it had then I'm sure QM would never have emerged. I should have thought that one of the main aims of Science is to challenge all those comforting old statements - like "heat rises" and to make them all stand up to scrutiny. You can bet your life that the cuddly concepts will be the first to fall under the cosh.
"Understanding"? As far as I'm concerned, that's just a feeling we get when we find that we can predict, to a reasonable accuracy, what will or should happen in some event or process. It's a word one should be careful with as it can easily lead to complacency. It's OK as long as it's treated as a journey and not a destination, in my view..
P.S. You are getting rather a lot of stick on this thread. Don't take it personally; it's all good fun and no more.
I wasn't talking about specific concepts with respect to the aforementioned statement. I was talking about the goal of some areas of physics in general.
Quantum mechanics is more fundamental than classical mechanics.
Relativistic mechanics is more fundamental than non-relativistic mechanics.
The search for a GUT is more fundamental than X.
And likewise for a TOE.
I don't have substantive evidence, but it might be the case that potential energy will become a derivative like classical mechanics.
I've replied to that point of argument in here (read last comment on post).
You don't need potential energy to explain the car's behavior going up and down the hill as noted in the link above. But explain what happens between the bat and the ball in terms of energy, I want to see your point of view more clearly.
If the argument is about what is of value for physics then I can assure you that there is a lot of value here. Not all physics is about calculation.
So by your accusation, there isn't a good number of physicists who don't try to understand the laws of nature. Not even ponder about it from time to time? That strikes me as odd.
Okay great, it is helpful to calculate. But that has never been the point of argument.
If there is to be an argument, we have to clearly define things.
You telling me "it isn't" doesn't change the fact that, at this present moment in time, I don't agree.
Yes, gravity can affect a myriad of things. Potential energy, kinetic energy, velocity, position, and even acceleration given enough distance. That is not the point. There are some things that are relatively fundamental in physics. That is,
Velocity, position, and acceleration.
Following on that premise, kinetic energy can ride along that boat. Potential energy, however, seems more and more to be useful for calculation with every point of argument you provide.
It strikes me odd that I'm more comfortable with the concepts of Quantum Mechanics than potential energy. :smile:
See the thing is, nature doesn't have to adhere to your intuition. In fact, it doesn't care at all. The quarrel here is what is a part of nature and what is useful because it helps us calculate. And I don't mean it in the literal philosophical sense. See post above where I argue that kinetic energy has more merit than potential energy. But hey, I'm not claiming I'm absolutely right, its part of the discussion. If someone comes with a good argument then I will accept it. One good argument was the Aharonov-Bohm effect.
It's all part of the love. :!)
Actually, it's not that strange. It could be a matter of 'distance lends enchantment' and 'familiarity breeds contempt'.
Are you aware that potential energy is a fundamental part of the Hamiltontan and Lagrangian, which are central to Quantum Mechanics?
Btw, I think that the problem with all questions of the form "is X real" is the concept of "real" rather than than the nature of X.
But I'm more familiar with PE than QM. Who knows though, maybe I'll change my mind as I progress in my study. I'll be sure to update this topic.
Yes.
To that, I plead ignorance. :-p
I can only talk about potential energy under things in classical mechanics. If you do suggest that we need to talk about quantum mechanics to argue about potential energy, then we should wait about a year or so.
It is probably better that way.
So you are saying that you have fewer problems with QM (about which you know very little) and classical PE, which you have studied formally?
When you know QM to the same level as your classical knowledge then you can make a valid comparison, I think, and not until.
I don't think that QM is essential for talking about PE, but PE is essential for talking about QM. So if you think that you are more comfortable with QM than with PE then I think you are kidding yourself.
I was speaking of the concepts in the QM, not the mathematical frameworks.
And no I am not kidding myself, nothing in nature says that it has to adhere to our intuition.
Can't argue with that.
Nano-Passion said:
[..] Yes, I'm aware of time dilation. Thing is though, I'm not completely fond of the potential energy concept to explain time dilation. Classical mechanics shouldn't take center-stage in this phenomena if you want to have a non-superficial understanding of the mechanics at work.
Science has little to do with fondness - it has more to do with what we learn from nature, if we like it or not. So, you may not like such ideas as energy, the relativity principle and the equivalence principle which indeed emerged from classical mechanics, but such things turned out to be very useful. Note that such concepts as energy only "explain" in a limited sense: they started out as book keeping concepts but turned out to be at least related to invisible but nevertheless physical entities. And I'm afraid that currently that's about as far as we can look "inside" - so that we have little choice but to stick to such superficial descriptions.
PE is a basic concept in QM. If you are uncomfortable with PE then you simply cannot be comfortable with QM. It has nothing to do with intuition, just logic. It is an illogical position to say that you are comfortable with QM but not with PE when PE is part of QM.
Velocity also depends on an arbitrary reference frame that is useful for calculation.
Define "more real".
A.T. said:
Define "more real".
More real is a bit less than really real.
Why does potential energy give mass to an object potential energy is only the "potential" for an object to have energy. How does being at a higher location cause an object to gain mass.
This is not a valid "Why" question. There are very few of those in Physics, aamof. Any answer will only take you a bit further down the road. It is possible to describe what happens but not why it happens. i.e. it's a completely different system that we're working with, here, and it is just not intuitive.
Do not get too hung up on the word "potential" and its meanings in other contexts. There are many Science words that are used differently by non -Scientists.
Mass and energy can be regarded as being interchangeable 'versions' of the same thing. Rather than saying that the object gains Potential Energy, it might be better to say that the Object-Earth system gains PE whilst the system loses a small amount of measurable mass. The only time this mass change is actually measurable is during nuclear reactions, in which the energy change is enough to produce a significant proportion of mass change (the Mass defect).
Nano-Passion said:
Kinetic energy seems more real than potential energy. Potential energy just says particle A has so and so potential.
Kinetic energy tells me that I can deal this much damage with a bullet with mass m and velocity v.
Kinetic Energy: 1/2(m(v)^2)
Potential Energy: mgh
I don't see why you'd think one is different from the other, shouldn't they both be just as fictitious? But you must account for the reference frame as well.
I don't understand what you are talking about, explain.
