Is R with the cofinite topology path connected?
  • Thread starter Thread starter ice109
    Path Topology
The discussion centers on the path connectivity of the real numbers R with the cofinite topology (cf). Participants argue that any two points a and b in R can be connected by a continuous path, leveraging the continuity of the identity function from the usual topology (u) to the cofinite topology. A key point raised is that since no subset of the image [a,b] is open in the cofinite topology, all functions mapping into it are continuous. However, caution is advised regarding the definition of continuity, as examples are provided to illustrate potential pitfalls in applying the continuity definition incorrectly. Ultimately, the conversation emphasizes the importance of understanding topology and continuity in the context of different topological spaces.
ice109
u is the usual topology, cf is the cofinite topology.
yes
proof:
pick a and b in (R,cf)
((0,1),u) ~ ((a,b),u). then the identity on (a,b) is continuous is because (R,cf) \subset (R,u). map 0->a and 1->b. the fn is continuous at the end points because no subset of the image is open in (R,cf). therefore their exists a path between any a and b in (R,cf).
is this a valid proof?
Mathematics news on Phys.org
I didn't quite get that bit - the image of the map is [a,b] with cofinite topology, which has many open sets - whether or not they're open in the ambient space doesn't affect the continuity of the map in question?
A clearer approach could be as follows. The identity \iota:(R,u)\rightarrow(R,cf) is continuous. Any path from a to b in the usual topology is given by a continuous function f:I\rightarrow[a,b]. Thus the composition \iota\circ f:(I,u)\rightarrow([a,b],cf) is continuous.
whats the definition of continuous fn? my book has: a fn is continuous from (X,a) ->(Y,b) iff every b open image has an a open preimage in X. hence since no subset of [a,b] is cf open all functions are into [a,b] are continuous.
i actually think that i was being redundant. i think any function s.t. f(0)=a and f(1)=b is a path in (R,cf) .
yea yours is good too.
You have to be careful when dealing with functions onto a subset of the second space.
For instance, take the set X=R-\{0\} with the topology \tau=\{\emptyset,R^+,R^-,X\}. Then using your definition the interval [a,b]\subseteq(X,\tau) has no open sets, so any function f:(I,u)\rightarrow[a,b] is continuous. Hence (X,\tau) is path connected, which implies it is connected. But the disjoint open sets R^+,R^- cover X, a contradiction.
The problem here is that a function f:(X,\tau)\rightarrow(Y,\mu) is continuous if every open set in f(X) with topology inherited from Y has open preimage.
As another example, let's work with the usual topology on R. Consider the function function f:R\rightarrow R which maps x to the first digit of its decimal expansion (e.g. 1.2->2, 0.5->5 etc. ) Then in fact this is a mapping f:R\rightarrow N. But the natural numbers contain no open sets of R, so your definition seems to suggest f is continuous. Of course it's not, at each integer there is a discontinuity (draw the graph). Can you prove f is not continuous using the definition I just gave?
yea you're right thanks for clearing that up for me. good counter examples btw.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
