Is the Configuration of Magnetic Fields Only a Convention?
The discussion revolves around the nature of magnetic fields and whether their configuration is merely a convention. Participants explore the historical development of electric and magnetic fields, referencing Faraday and Ampere, and consider the implications of defining magnetic fields based on different perspectives, such as the force on test currents versus source currents.
  • Some participants suggest that the concept of magnetic fields could have been developed differently, such as by considering the force on one electric current in the presence of another, similar to Ampere's findings.
  • Others argue that changing the convention of magnetic fields would require altering Maxwell's equations, indicating a dependence on the established framework.
  • It is noted that the direction of magnetic fields is a convention, which can be altered by changing the right-hand rule or the order of cross products.
  • Some participants express uncertainty about the implications of defining field lines based on the force between currents, suggesting that this could lead to fields that do not reflect the actual behavior of currents.
  • There is discussion about the magnetic vector potential and its relationship to magnetic fields, with some proposing that auxiliary fields might be introduced for computational ease.
  • Participants highlight that the direction of the magnetic field could be well-defined, but there is contention regarding whether this definition aligns with the forces experienced by test currents.
Participants do not reach a consensus on whether the configuration of magnetic fields is merely a convention. Multiple competing views are presented regarding the implications of defining magnetic fields based on different criteria.
Some discussions involve assumptions about the nature of magnetic fields and their dependence on historical conventions, which may not be universally accepted. The complexity of relating field lines to the forces on currents introduces additional uncertainty.
cg0303
If I understand correctly, the concept of electric and magnetic fields originated with Faraday and was developed by reconceptualizing forces acting at-a-distance.
For example, the electric field concept was developed by looking at the force on a test charge in the presence of a source charge rather than looking at the force between two charges (i.e. Coulomb’s law). The magnetic field was similarly developed by looking at the force on iron filings or compass needles in the presence of a magnet or electric current.
But could Faraday have equally developed the concept of magnetic fields by looking at the force on one (test) electric current in the presence of another (source) electric current, per Ampere’s discovery of the attraction/repulsion between currents? If so, wouldn’t that make the configuration of magnetic fields only a convention, in somewhat the same way that positive/negative signs are just a historical convention due to Franklin?
You may change convention of magnetic field to inverse one if you change also B to -B in Maxwell's equations. If you want to keep Maxwell equations as they are, you should keep current convention.
The magnetic field direction is only a convention anyway. You can flip the direction of all magnetic fields either by changing the right hand rule to a left hand rule, or by flipping the order of the cross products.
True, but that's only with respect to whether the direction of the field line is positive or negative. But if the field lines were based on the force between currents, the field lines would diverge from currents rather than curl around them.
Oh, I see what you are saying.
I have not considered this in detail, but I don’t think it would work. If the field lines radiate out from the current then you will have the same field regardless of which direction the current flows.
I am having a hard time visualizing the direction you want this to point, other than "not in the direction of the B field". Well, there are really only two choices.
One is the magnetic vector potential. One can always use this, since ∇×A= B. However, I suspect that had things evolved this way, it would not be long before we introduced an auxiliary field that was the curl of the A field to ease calculations.
If that's not it, it would be some field like B×A so that it was perpendicular to both. I am pretty sure that this would work, but it would be computationally horrible.
Why? We could choose one direction to be 'outwards' and one 'inward', the same way we chose the positive charge to be outward and negative to be inward. The only difference is that that with electric charges opposites attract, while with currents opposites repel.
The field line would point away from an electric current.
I'm not sure what the magnetic vector potential of a current would look like. Could you post a diagram that would help?
By symmetry. The laws of physics are invariant under rotation, including specifically a 180 degree rotation. Start with a current ##\vec J## that produces an outward field. By symmetry a 180 degree rotated current ##R_{180}(\vec J)## must also produce an outward field. But ##R_{180}(\vec J)=-\vec J##. So ##\vec J## and ##-\vec J## produce the same field.
I could, but I posted a link with diagrams.
  • Haha
While what he proposing is still pretty vague, I think he means that clockwise current gives an outward field and counterclockwise gives an inward field. (Or the reverse)
Which is the same issue since a clockwise current rotated 180 degrees becomes counterclockwise.
I was after something different than what was contained in the link, but I think I was able to get what I needed from it.
If I understand you correctly, it would be this.
Then it would be computationally horrible.
Fair enough
Take a look at the Wikipedia page, which has a toroid. B is drawn, A is drawn, and their cross-product is outward from the current. So I think the direction is - or at least can be - well-defined. The OP's description still kind of confuses me (sometimes it sounds like A, sometimes perpendicular to A) so I am not sure that it is well-defined. But I think something like he wants could be well-defined.
Agreed. The direction can be well defined and with your formula it is always outward.
The problem is here:
So we have a test current and a source current. The field always points outward from the source current regardless of which direction the current is flowing. So the field at the test current is the same regardless of which direction the current flows. But the force on the test current is not the same. So this field is not and cannot be directly related to the force on the test current.
In order to distinguish the direction of the force would indeed be computationally horrible and would probably wind up solving for B at some point anyway.
Well, in fact I think historically there was a lot of confusion about the potentials in the beginning. It's a tricky concept as we know today, because it's not the potentials which uniquely describe an electromagnetic field but only an equivalence class, i.e., "the potentials modulo a gauge transformation". That is, because the Maxwell equations for the potentials do not uniquely determine these potentials given some physical initial (and maybe boundary) conditions, while of course the Maxwell equations for the field(s) ##(\vec{E},\vec{B})## have unique solutions under given initial/boundary conditions, and indeed ##\vec{E}## and ##\vec{B}## are what's operationally defined via the forces on test charges.
I agree. I believe that the thing that is most likely being discussed works out to be ∇(A2/2)−(A⋅∇)A. One would need to solve for A and take it's curl to get anything that looks like a force.
@vanhees71 is right that A is determined by B only up to a gauge transformation. I think the monster above is also determined by A up to a gauge transformation, and some care might be needed to make sure that one chooses a consistent set. I haven't worked this out, but can see how one might screw this up.
Excellent understatement!
  • Haha
My beautiful Latex was destroyed. (Greg, is there a Purple Heart badge for this?) I tried to write:
[tex] \nabla (A^2/2) - ({\bf A} \cdot \nabla){\bf A}[/tex]
What's a vector and what is not is important.
All you have to do is invert this. :wink:
What do you want invert here? It's not an equation. So far the great feature of classical electromagnetism was that you get very far with linear laws. What should this non-linear expression help (whatever the missing right-hand side of the equation reads).
I have no idea why anybody would want to add this much complexity.
[tex] \heartsuit (A^2/2) - ({\bf A} \cdot \heartsuit){\bf A}[/tex]
There, I fixed it for you. And you're welcome. :smile:
1. It might only be complex with respect to its definition with respect to the vector potential. However, if we were starting from scratch (not that we would want to) and are defining B for the first time, it may not be as complex. I'm not using the words 'might' amd 'may' because I really don't know. My grasp on the maths here is at at a beginners level.
2.
I’ve read and thought a little more about this question, and I think the question can be strengthened somewhat. However, I think it ultimately can be resolved. Please bear with me.
I came across the following chapter which explains the history: https://link.springer.com/chapter/10.1007/978-1-349-11139-8_6
As a quick digest of the chapter, Faraday and Ampere disagreed about two main issues:
a) Ampere conceived of magnetism in terms of Newtonian forces acting at-a-distance, while Faraday thought in terms of fields.
b) To Ampere, the attractive/repulsive forces between two current carrying wires was the fundamental fact about magnetism, and could explain all other magnetic phenomena. He believed that all magnetic phenomena were caused by miniature electric currents that existed inside magnetic materials. He struggled to find a model that was consistent with experiment, and so Faraday rejected his view.
Faraday’s field view (issue 1) prevailed. Regarding issue (2), it seems that Ampere’s view prevailed to a certain extent, as we now explain the properties of magnetic material as result of the motion of the electrons inside their constituent atoms. This latter point seems to strengthen my original question. Faraday, given the scientific knowledge at the time, would not have developed the concept of magnetic fields by looking at the force on a test electric current (or moving charge) in the presence of a source electric current (or moving charge). He had no reason to see currents as the fundamental fact of magnetism, and therefore constructed the concept of magnetic field by looking at the force on iron filings. However, that is merely a historical artefact, since today we know that the motion of charge within a material is what makes gives it its magnetic properties. If Faraday were to construct the concept of magnetic fields today, he may have based it on the forces between currents.
Now, here’s where I think why it wouldn’t work.
In a uniform magnetic field, a moving charge experiences a force which causes it to move in a circular path.
(taken from https://openstax.org/books/college-...in-a-magnetic-field-examples-and-applications)
A magnetic field constructed from the force between currents would not be able to produce such a force (as far as I can tell).
Thoughts?
Are you saying that you can't follow our math, but you're sure we're wrong?
Are you sure that's the path you want to go down?
Not at all!
All I was trying to say is:
a) There seems to be a historical motivation for the suggestion in the OP
b) I don't see how Amperian forces between currents/moving charges could account for the circular path.
Maybe I worded post #26 too strongly (although I kept saying 'I think' and 'may'), but that's all I was trying to say.
One should note that Ampere hasn't had yet the full dynamical knowledge about electromagnetism. This came later with Maxwell's addition of the socalled "displacement current" making, unknowingly of course, electromagnetism the paradigmatic example for a relativsitic field theory. Ampere's (and Weber's) theoretical framework was based on the action-at-a-distance picture, which you get from assuming magnetostatics and neglect the displacement current and retardation effects.
Given that the electromagnetic field is operationally defined via the forces on charges and currents, one could think that it is just an auxilliary quantity which may be eliminated from the physical laws, leading to a description of systems of charges and currents with direct action-at-a-distance forces.
Let's do this for two currents in thin two wire loops (of arbitrary shape) at rest carrying somehow currents ##I_1## and ##I_2##. Let the closed curves describing the wires be ##C_1## and ##C_2##. Let's start from the modern field view, which simplifies the analysis considerably. There the idea is that ##C_1## leads to a magnetic field, which can be described (in the static approximation) by Biot-Savart's Law,
$$\vec{B}(\vec{x})=\mu_0 I_1 \int_{C_1} \mathrm{d} x_1 \times \frac{\vec{x}-\vec{x}_1}{4 \pi |\vec{x}-\vec{x}_1|^3}.$$
The total force on ##C_2## then is
$$\vec{F}=I_2 \int_{C_2} \mathrm{d} \vec{x}_2 \times \vec{B}(\vec{x}_2).$$
Plugging the above formula for ##\vec{B}## in this you get
$$\vec{F}=\frac{\mu_0 I_1 I_2}{4 \pi} \int_{C_2} \mathrm{d} \vec{x}_2 \times \int_{C_1} \mathrm{d} \vec{x}_1 \times \frac{\vec{x}_2-\vec{x}_1}{|\vec{x}_1-\vec{x}_2|^3}.$$
Here you have a form, where the magnetic field is eliminated at the prize of a complicated non-local law.
It's also possible to do something similar for the general case of the full electromagnetic theory with taking into account the full relativistic effects of retardation. The elimination of the electromagnetic field then leads to quite complicated non-local dynamical laws. A famous example is Feynman's and Wheelers "absorber theory". It's called absorber theory because you must use an reinterpretation of the field picture to make "causal sense" of the necessity to introduce "half retarded and half advanced Green's functions". The original idea was to eliminate the fields and then make a pure "particle quantum theory" for point particles out of it by somehow "quantizing" this non-local classical particle symmetry.
This, however, never worked out, and the key of electromagnetism in quantum theory (both non-relativsitic quantum mechanics of point particles in classically treated electromagnetic fields, the socalled semiclassical approximation, as well as the full relativistic quantum field theory , quantum electrodynamics) are to use the potentials and gauge invariance and staying with strictly local laws. From the modern point of view this lesson teaches us that the most fundamental description of Nature seems to be closer to a local field-theoretical point of view than a point-particle action-at-a-distance point of view.
  • Love
Just to clarify, the suggestion in the OP was not that we could eliminate fields in favour of forces acting-at-a-distance. Rather, it was that the definition of the magnetic field could be based on the force between currents, much like the definition of the elctric field is based on the forces bewteen charges.
  • · Replies 20 ·
  • · Replies 42 ·
13K
  • · Replies 24 ·
