Is the constant A = i in this hydrogen atom wave function correct?
11 replies · 2K views
gfxroad
I solved the Schrödinger equation, obtaining a wave function in terms of Radial and the spherical harmonics as follows:
$$Ψ(r,0)= AR_{10} Y_{00} + \sqrt{\frac23} R_{21} Y_{10} + \sqrt{\frac23} R_{21} Y_{11} - \sqrt{\frac23} R_{21} Y_{1,-1}$$
The constant A is equal to i; is this result right or not?
Please provide a problem statement.
But I doubt the constant is going to be imaginary - what is your reasoning?
The states is more to write but I make a print screen.
http://www.gfxroad.com/print-wf
I can see why you didn;t want to write that down ;)
See the line below the equation where it says "where A is a real constant..."?
Your question:
... is answered.
You seem to be trying to answer part (b).
What is the condition that must be satisfied for ##\psi(\vec r,0)## to be normalized?
Very good ... imagine you had ##\psi = a\psi_a + b\psi_b## ... where ##\psi_a## and ##\psi_b## are already normalized. In order for ##\psi## to be normalized, ##a## and ##b## need to satisfy a condition ... what is it?
Well done.
Technically: ##a^*a+b^*b=1## in case you have complex coefficients.
Now imagine you have:
##\qquad \psi = a\psi_a + \sqrt{\frac{2}{3}}\psi_b + \sqrt{\frac{2}{3}}\psi_c - \sqrt{\frac{2}{3}}\psi_d##
... now your problem is that to get ##|\psi|^2=1## it looks like you have ##a^2+2=1 \implies a=\sqrt{-1}##
But you are told that ##a## is real so this is a contradiction.
Anyway, if ##a=i##, then ##a^*a= (-i)i = -i^2=1## not the -1 you were looking for.
In fact, is there even a solution for ##a^*a=-1##?
Therefore - what does this tell you about your approach?
Did you properly account for the R and Y functions?
i.e. is ##\psi_{nlm}=R_{nl}Y_{lm}## normalized already?
... did you do part (a) correctly?
Yes, I thought part a was done correctly like:
http://www.gfxroad.com/print2
Yeah, I'm getting the same thing ... I have a nagging feeling there's a wrinkle here I'm missing but on the face of it the textbook problem has no solution.
It may be that the text-book has a typo.
What's about e branch, is there any starting point or equation for this, because I don't know where can I starting. The other branches solved correctly.
For (e) ##\text H\psi_{nlm}=E_n\psi_{nlm}##
What do you mean "correctly"? Do you have model answers?
