Is the Force F Conservative? Determining Work Along Different Paths
The discussion revolves around determining the work done by the force F = yi(hat) - xj(hat) on an object moving from point A (a,0) to point B (-a,0) along different paths: an elliptical path and a straight line. Participants are exploring the implications of these calculations on whether the force is conservative.
  • Participants attempt to calculate the work done along an elliptical path and a straight line, raising questions about the integration process and the roles of the parameters involved. There is confusion regarding the correspondence of variables and the limits of integration.
Several participants are actively engaging with the problem, sharing their attempts and questioning each other's reasoning. Some guidance has been offered regarding the parametrization of the paths and the interpretation of the limits of integration, but no consensus has been reached on the final calculations or the nature of the force.
Participants express uncertainty about the definitions of parameters a and b, as well as the implications of their calculations on the conservative nature of the force. There is a noted lack of clarity on the integration limits and the relationship between the variables involved.
mattyc33
Determine the work done by the Force F = yi(hat) - xj(hat) on an object that travels from point A (a,0) to point B (-a,0)
a) along an elliptical path described by x=acosθ, y=bsinθ
b) along a straight line from A to B
c) From these results, can we determine whether or not the force is conservative?
W=∫F ° dl
dl=dxi(hat) + dyj(hat)
a) W=∫(a to -a) bsinθi(hat)dl - ∫(0 to 0) acosθj(hat)dl
so that just gives me ∫(a to -a) bsinθi(hat)dl which equals 0. This doesn't seem right to me. What's mainly confusing me is that the y is corresponding to the i(hat) vectors and vice versa for the x. I don't really know what to do with the b.
b) dl = dxj(hat)
W = ∫(a to -a) xdy = 0
c) I know that you can tell if a force is conservative if the work depends on the path. Therefore this is probably not conservative.
W=∫F ° dl
Use your two relevant equations, what is \mathbf{F}\cdot d\mathbf{l} if \mathbf{F} = y\mathbf{i} - x\mathbf{j} and d\mathbf{l} = dx\mathbf{i}+ dy\mathbf{j}?
So then I would get ∫ydx - xdy.
How would I integrate y with dx and x with dy?
I'm sort of behind on this stuff and this may seem simple and I'm sorry for that.
You have equations for both x and y in terms of a single parameter, \theta, use them and remember that dx =\frac{dx}{d\theta}d\theta
So I would get an equation that looks like ∫bsinθ(dx/dθ)dx - ∫acosθ(dx/dθ)dθ
which yields:
-bcosθ - bsinθ
Would that be my answer? Or are there further steps pertaining to points A and B?
Don't you mean \int_{\theta(x=a, y=0)}^{\theta(x=-a,y=0)}\left(b\sin\theta \frac{dx}{d\theta} - a\cos\theta \frac{dy}{d\theta} \right)d\theta?
which yields:
-bcosθ - bsinθ
I get something different, can you post your steps?
Work done is the path integral from A to B, so you should have a definite integral where the limits are the value of \theta at each endpoint.
Sorry I seemed to have misplaced a dx with what should have been dθ.
Continuing on:
I split the integrals:
∫bsinθ(dx/dθ)dθ - ∫acosθ(dx/dθ)dθ with the limits a to -a.
If I integrate bsinθ I get -bcosθ and if I integrate acosθ I get a sinθ (another mistake in my previous answer)
Therefore the expression would be:
-bcosθ - asinθ from the limits a to -a
resulting in:
(-bcos(-a) - asin(-a)) - (-bcos(a) - asin(a))
I think I may be integrating the original equation incorectly with the due to confusion by the dθ's and dx's.
Continuing on:
What happened to \frac{dx}{d\theta} and \frac{dy}{d\theta}? Why would the limits be a to -a? What is the value of \theta at the point A? What about at point P?
I made another mistake in writing the final equation down so the final equation from before would be:
∫bsinθ(dx/dθ)dθ - ∫acosθ(dy/dθ)dθ with limits a to -a
This doesn't really change much though.
Well technically it's θ to θ but since there is no y component wouldn't the limits just be the x components?
I'm extremely confused at this point on how I would find the θ in point A or B because I have no idea what "a" means.
"a" and "b" are just numbers. Plot out your parametric equations as you range theta from 0 to 2pi... what value of theta gives you x=a and y=0? What value of theta gives you x=-a and y=0?
As for dx/dθ and dy/dθ, you will need to calculate them...
Well for sinθ y=0 at 0, ∏ and 2∏ Therefore would "a" be pi/2 and theta be 0, 180 or 360?
for cosθ y=0 at ∏/2 and 3∏/2 so b would be pi/2 or 3pi/2 and theta be 90 or 270...
I am just really confused at this point as I feel like I need to review basic geometry however this question is one of the only ones I don't understand in my textbook chapter.
Why ask me? You have y(\theta)=b\sin\theta, so what is y\left( \frac{\pi}{2} \right)?
Huh?:confused:
You have x(\theta)=a\cos\theta, what are x\left( 0 \right), x\left( \frac{\pi}{2} \right), x\left( \pi \right), etc?
I think you should review linear algebra, especially curves and parameterization.
Then y=b at theta = pi/2.
y=0 at theta = 0 as well
x=a at theta = 0
x=-a at theta = pi
Therefore the values that I am looking for are theta = 0 and pi.
I don't understand what the limits for this integral would be though. As well as what I am doing with these values of theta.
x=a at theta = 0
x=-a at theta = pi
You are integrating along an eliptical path from point A to point B. When you parametrize that path in terms of \theta, you find that \theta=0 corresponds to point A and \theta=\pi corresponds to point B, so those values of \theta are your lower and upper limits.
So if I complete the integral:
∫(bsinθdx/dθ - acosθdy/dθ)dθ From 0 to pi
= -bcosθ - asinθ from 0 to pi
= b-1
Would b-1 be my final answer for work? That doesn't seem right to me, did I misplace a number that I can substitute in for b?
sorry 2b*
= b-1
No, \int_0^{\pi} b\sin\theta \frac{dx}{d\theta} d\theta \neq -b\cos\theta, what happened to \frac{dx}{d\theta}?
I actually got help from a TA but thank you so much for your help until now.
